Old 04-28-2017, 07:30 AM   #29
Esseff
Drives: 2017 BRZ Ltd White
Originally Posted by nico_rsx View Post
See my post above, I explain it all.
The Full auto mode control 4 functions (fan speed, vents positions, recirc and AC). If you manually adjust any of those function you go to auto mode instead of full auto, and the car control the 3 remaining functions (plus the temperature). You need to manually adjust all 4 to remove completely the Auto mode.
Ohhhhhh, awesome!
So I turn the system on with the unlabelled fan dial. Then turn off the AC button, turn on, then off the recirculate button, adjust the fan speed, cycle thru the vent options to get it back to top vents only, and voilà. I have manual fan.
AWESOME!!! So easy and soooooo obvious. (and yes more sarcasm intended)
Esseff is offline   Reply With Quote
Old 04-28-2017, 07:54 AM   #30
They just need to bring over the system from the 17 Impreza.
Push button on steering wheel.
Say "set driver's temperature to X degrees", "Fan on low" or whatever else you want it to do.
It repeats what you told it and changes the settings for you.
Not sure I know where the actual controls even are on the wife's car.
Originally Posted by Gil Scott Heron View Post
When the cars are fully autonomous, you will be able to travel to your programmed destination and simultaneously watch an instructional video about operation the HVAC system.
My first ride (1951 Ford F-1 truck) had the good ol' cowl vent as depicted in humfrz's picture, as well as the radiator in the passenger footwell for heat.
No need to watch a video. Just tell the car what you want.
Old 04-28-2017, 10:40 AM   #31
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
Originally Posted by Esseff View Post
On 99% of devices the Off button also does On.
The buttons you're thinking of are labeled as "On/Off" or "Power"
Ohhhhhh, awesome!
Adjust the climate control to whatever you like. Stop hitting the Auto button. Auto wont come back on. Yea its pretty easy.
RTFM
PandaSPUR is offline   Reply With Quote
Old 04-28-2017, 12:25 PM   #32
PetrolioBenzina
PetrolioBenzina's Avatar
Drives: 17 86
What's a stupid mess ?? ........
humfrz
Dual-zone climate control in a car this small, with what appears to be controls designed by Goldberg.
PetrolioBenzina is offline   Reply With Quote
The Following 4 Users Say Thank You to PetrolioBenzina For This Useful Post:
Gil Scott Heron (04-29-2017), humfrz (04-28-2017), Tcoat (04-28-2017), wireman957 (04-28-2017)
Old 04-28-2017, 10:24 PM   #33
nico_rsx
Drives: BRZ 2017 Pure Red, MT
Ohhhhhh, awesome!
Exactly, you got it!
I didn't say it was convenient, just how it worked, haha
I'll probably try to get used to the automatic control, instead of trying to fight it...
nico_rsx is offline   Reply With Quote
Old 04-29-2017, 01:41 AM   #34
extrashaky
Drives: 2014 BRZ Limited
You can usually walk both ways through a door marked "out" also. But then sometimes there's no handle on the wrong side! My god, what will you do? WHAT WILL YOU DO?
You would also assume so...
On the contrary, I would never, ever assume that a button marked "OFF" turns things on. The idea that one would read something and think it means its exact opposite is completely foreign to me.
Well, after more investigation I have finally worked out how to turn off all the Auto modes... you switch the Recirculate button on then off.
Oh praise Jesus, Buddha and Allah. Our national nightmare is finally over.
Old 05-01-2017, 07:05 PM   #35
frsq5
Drives: 2014 Scion FR-S Monogram
Wait until you sit in any BMW and try to work with AC in that car...
Normally if a button says OFF it means off only. It'll have on button or something else that turn the device on as a separate function.
I think you are confusing on/off button as OFF only buttons
Get used to this style off AC operation if you want multi-zone climate control in ANY car, because this is the standard.
frsq5 is offline   Reply With Quote
Swap Aircon HVAC controls from BRZ/GTS to FRS/GT MudithJ Cosmetic Modification (Interior/Exterior/Lighting) 3 08-04-2016 11:13 AM
Subaru BRZ - Dual Zone Climate Temperature - Wrong? Nourdmrolnmt1 Issues | Warranty | Recalls / TSB 21 03-22-2015 02:11 PM
Tiny amount of engine oil smell passing through aircon? Mim Issues | Warranty | Recalls / TSB 9 01-18-2015 01:11 PM
AFR's Danger zone!? Brick Software Tuning 20 02-24-2014 07:14 PM
DRL + "Eyebrow strip" dual operation? Weeber BRZ First-Gen (2012+) — General Topics 3 11-26-2013 02:35 PM
