| Member's Car Journals Car journals by our members. |
#29 | |
Drives: 2013 FRS
#30 |
Drives: 2014 FR-S
The thing to remember is that most will quiet down over time as they get loaded up with soot. At 20k/year, you'll see a big quiet down after just a couple weeks.
-Mike
#24 CS/CSR |
#31 |
Drives: Yes
I like the sound of the Nameless delete that I've run for 4+ years, but I'd like to try something else because it was not that ideal and might have become more droney over the years.
It's nice to see your progress. I was on the other side of you at the Devens event and glad to see you fixed the positive camber. I like the look of the single Ft86 Factory system, but I heard it might be droney too? |
#32 | |
Drives: 2017 Toyota 86
And ya I had been looking at reviews for the nameless delete and I'm just too paranoid about the drone, if I can find the flange anywhere local I might just weld a 2 inch pipe downward to see how bad it is for race days. Although I'm sure I wont want to take that stock exhaust on and off too many times.
2017 Toyota 86 - Whiteline 20mm Front Bar | Crash Bolts | 235/45/17 RE-71R | 17x7.5 OZ Omnia | OFT Stage 1 For Street Driving | Trackpipe for AutoX | Not enough camber.
#33 |
Update time!
So after a lot of really good events the car is finally starting to feel planted in transitions and is really a joy to drive. I also found that on my 235s If I go much below 35 up front, then on pretty much any turn, my car understeers like crazy, and does the front tire "shudder". 35-37 up front seems to be giving me the best response and times. Whereas the rears are typically at 29-30. I think this is because of a couple of things, the first being that I was only able to get 1.2 degrees of camber up front with the stock bolts and with loosening EVERYTHING so I feel as though my car is just camber limited. The second reason I think is because of my 20mm bar on full stiff. I might try an event with it on the softer setting to see if it feels any better at lower pressures. But all of this season has showed me that I really want to go to STX next year, so I already picked up the OFT and I'm going in for a baseline stock dyno on Wednesday before I start throwing on power parts. I'll probably test out the OFT at a few of the lax events, mainly for the rev limiter to try and get my top 2nd gear speed up a bit. My goal is todo a budget STX build, under 6k I think, which won't get me first at nationals, but I feel should be competitive. That's all for now!
#34 |
btr.life
Drives: 2022 GR86
I switched to a Blitz Nur-SPEC VSR dual exit exhaust. It weighs a bit more than the Tanabe but is really quiet with no drone. The extra weight is not a huge deal...
Also, I would put the money into the suspension/wheels first. Do engine stuff last. OFT/tune is probably the best upgrade for the engine for short term.
| Review: Project Mu HC+ 800 Street/Track Pads | spitz | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 65 | 11-30-2019 02:58 PM |
| C Street Guys with 2017 PP What size tires? | imnotsureaboutbrz | Tracking / Autocross / HPDE / Drifting | 19 | 04-15-2017 12:21 PM |
| Boost Festival 2017: Feb 25, 2017 Willow Springs GTA, JustDrift, Drift | ModinJapan | Southern California | 1 | 01-25-2017 01:46 AM |
| Tein Street Flex/Bridgestone Summers 18in/Project Kics/Morimoto HID Kit | CreinCrein | Canada Classifieds | 23 | 04-15-2016 11:06 PM |
| Megan Racing Coilovers - Street / Track / EZ STREET - Starting at $699 Shipped | GuerillaRacing | Brakes, Suspension, Chassis | 149 | 05-12-2015 06:53 PM |
