Old 04-09-2017, 02:22 PM   #29
Pure Automotive
Pure Automotive's Avatar
Drives: 2013 FRS Whiteout
Originally Posted by MRS-Colin View Post
Has pressure compensation etc been built in? I know this can be a hassle since GM used a few different sensors etc.
Yes, we tested it under different conditions and played with pressure to make sure that it would cycle the compressor properly as well as react in an over-pressurization situation. The easiest/safest way is to use as much of the FRS AC lines as possible, that way the total system fill is as close to stock as possible. We use the FRS pressure sensor as well since it's already pinned into the body harness.
Pure Automotive is offline   Reply With Quote
The Following 4 Users Say Thank You to Pure Automotive For This Useful Post:
Drakiv (04-09-2017), DustinS (04-18-2017), ILLSMOQ (04-09-2017), SmsAlSuwaidi (04-10-2017)
Old 04-30-2017, 04:26 PM   #30
Pure Automotive
Complete harness, jumper, and m130 in hand, should be installing and starting this week!
DustinS (05-01-2017), ILLSMOQ (04-30-2017), R2RO (06-07-2017), Sportsguy83 (05-01-2017)
Old 04-30-2017, 11:10 PM   #31
ILLSMOQ
Drives: 2017 WR BLUE BRZ
Nice! Can't wait to see it running!
ILLSMOQ is offline   Reply With Quote
The Following User Says Thank You to ILLSMOQ For This Useful Post:
Old 05-05-2017, 06:51 PM   #32
Godzilla35
Drives: Nissan GT-R
Subbed. I'm so torn between doing LS and 2J
Godzilla35 is offline   Reply With Quote
Old 05-05-2017, 07:58 PM   #33
ILLSMOQ
Flip a coin man...they're both bad ass!
Godzilla35 (06-20-2017)
Old 05-06-2017, 12:22 AM   #34
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
Old harness built by a company a couple years ago vs new plug and play harness. Car ran, but absolutely nothing oem related worked. Now everything works
after the old harness was out, about 30 minutes worth of install on the new harness and did the first start with a bench test firmware. now we can finish the firmware and base map tune in the actual car
[ame="https://www.youtube.com/watch?v=2AWVukPTlnM"]Frs/Brz/GT86 pure automotive performance LS plug and play first start - YouTube[/ame]
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
The Following 6 Users Say Thank You to spitfire481 For This Useful Post:
CxG (06-05-2017), Drakiv (07-11-2017), ILLSMOQ (05-06-2017), Lonewolf (06-06-2017), Sportsguy83 (05-06-2017), tirespin782 (05-07-2017)
Old 05-06-2017, 11:11 AM   #35
ILLSMOQ
Awesome! Can barely even pick out the wire harness on the motor...very clean great job!
Old 06-02-2017, 12:00 PM   #36
Pure Automotive
[ame]http://youtu.be/H2oq7VIOUuI[/ame]
The Following 7 Users Say Thank You to Pure Automotive For This Useful Post:
CxG (06-05-2017), DHitHim (06-07-2017), Drakiv (07-11-2017), ILLSMOQ (06-02-2017), R2RO (06-02-2017), Sportsguy83 (06-02-2017), The Racers Line (11-06-2017)
Old 06-02-2017, 12:20 PM   #37
ILLSMOQ
Great news! Thanks for the update! I'm pumped to get started on mine!
Old 06-02-2017, 09:25 PM   #38
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by Pure Automotive View Post
Can't wait to get it!!
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Old 06-06-2017, 01:19 PM   #39
sirsol66
Drives: 2013 FRS- Hot Lava
So are there two versions, one for with push start and one without? From the video, looks like air bag/ VSC/ ABS lights are on. If you did not have an aftermarket steering wheel, can air bags be retained? I dont mind losing VSC or ABS. What about TPMS?
sirsol66 is offline   Reply With Quote
Old 06-06-2017, 02:51 PM   #40
Sportsguy83
Drives: Limited BRZ
Yes, it works with either push start or key in.
As far as I've learned, (my LS plug and play package is already bought and underway) the airbags are controlled almost completed independently by its own controller and will work with stock steering wheel and stock airbag. Motec implements traction control superior to OEM one that with the plug and play package you can control with the stock traction buttons. Additionally, ABS does fully work with this package. TPMS is a good question, I think it still work but not 1000% sure.
The Following 3 Users Say Thank You to Sportsguy83 For This Useful Post:
all4spl (06-06-2017), CxG (06-19-2017), ILLSMOQ (06-06-2017)
Old 08-21-2017, 10:29 PM   #41
Shibby
Drives: 2013 WRB BRZ
so what's going on with this? Just spun a bearing on my FA20 with only E85 lol. Looking for a swap but 2jz is too heavy for my liking.
Shibby is offline   Reply With Quote
Old 08-22-2017, 02:39 PM   #42
spitfire481
Drives: 2JZ FRS
Harness is built to order depending on your specs and the firmware package is done. we have 2 kits already shipped out awaiting install, and we have the lsa swapped frs complete here at the shop
MoTeC
Build Thread
@spitfire481
Pure Automotive Performance's White Street Fighter- 2JZ Swap - Formerly the FRSS LS2! Pure Automotive Member's Car Journals 53 03-05-2015 07:11 PM
Motec M1 Plug N Play FullBlown Forced Induction 89 05-09-2014 01:45 PM
The New Consolidated Install Thread @Pure Automotive Performance, FT86 Specialists! Pure Automotive Mid-Atlantic 14 09-26-2013 11:28 PM
**The Eibach Thread** Springs, Coilovers, Sway Bars @ Pure Automotive Pure Automotive Brakes, Suspension, Chassis 1 02-06-2013 03:32 PM
*Pure Automotive Performance: Project Whiteout FRS Build Thread* Pure Automotive Member's Car Journals 6 01-18-2013 12:34 PM
