Old 05-04-2017, 10:34 AM   #29
Dialkyl
Drives: Silver 2013 Subaru BRZ
Originally Posted by ILLSMOQ View Post
And a Full Blown 8.8 rear end w/3.55 gears.
Almost ready to start tearing into it!
They managed to fit that in a priority mail box? Impressive
Dialkyl is offline   Reply With Quote
Old 05-04-2017, 02:38 PM   #30
ILLSMOQ
Drives: 2017 WR BLUE BRZ
Hahaha. Nah it came fed ex...that was fromanothe shipment and I didn't want to damage the wood floor in my office!
ILLSMOQ is offline   Reply With Quote
Old 05-26-2017, 09:14 PM   #31
ILLSMOQ
Two big boxes arrived this week!
Most of the hardware is here...looks like the Vorshlag headers have been redesigned and the ETA has been pushed back a bit...no biggie...almost ready to start in on the rear end.
Old 08-14-2017, 09:52 PM   #32
ILLSMOQ
So all my pics are dead oh well.
So finally...I started in on my LS swap project this weekend!
Swapped out the stock 4.30 diff for a 3.55 8.8 Ford rear diff from Full Blown Motorsports.
I also went to solid SPL subframe bushings, all the SPL arms and links, Whiteline sway bar with reinforcements and links, solid polyurethane rear diff bushings, and the MCS coilovers with vorshlag mouthing plates.
The subframe bushings were super hard to remove...I remembered reading about people stripping subeframe bolts as well so I was cautious about tightening the bolts when I was putting it back in. The factory bushings have ovaled holes so the subframe can move to allow the bolts to be threaded properly. These solid bushings just have a round hole so it was difficult to get all four bolts threaded right. I made sure I had all four bolts started a few turns then jacked the subframe up the last half inch or so into place and tightened the bolts. The lack of "slack or play" in these new bushings makes it hard to get them threaded and tightened. If I didn't know to be cautious, I probably would have stripped one or damaged the threads a bit.
The SPL arms and links are pretty straight forward. It's gonna be a chore to get them all adjusted since I changed every arm but not as bad as I originally thought it would be...you initially adjust them to be the same length as the part you're replacing and then adjust from there.
I gotta find a place to run the line for the reservoirs on the coilovers into the car. I want it to be clean and accessible from the trunk.
Anyways good start to this project.
The diff also went in pretty easy....so far, this part of the project was tedious but easy.
Beefy axles shafts
Pretty sure I installed the rear sway bar upside down but I don't see how it could cause any problems this way. It's clear of everything...any thoughts or input?
Old 10-01-2017, 02:19 PM   #33
ILLSMOQ
Finally an update.
All the suspension, the brakes and the wheels and tires are on. Handles awesome seriously needs some power!
Old 10-04-2017, 09:41 AM   #34
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Jealous of those brakes! Well and the Coilovers... and the Diff... Glad to see updates. Can't wait till you start the swap. Car will be awesome.
DustinS is offline   Reply With Quote
Old 10-04-2017, 10:02 AM   #35
ILLSMOQ
Thanks man! I talked to Jason at vorshlag the other day, they are still designing the headers. He said it will probably be mid December before I have a set of headers in my hands. Damn! Haha
Old 10-10-2017, 05:06 PM   #36
Iceman
Iceman's Avatar
Drives: GT86
Awesome build, that's all i can say. Love it!
Youtube channel: https://www.youtube.com/c/ÓscarFaraday
IG: @oscarfaraday
Iceman is offline   Reply With Quote
Old 10-10-2017, 05:35 PM   #37
ILLSMOQ
Thanks brother! It’s been s fun project and the modifications made so far have already been rewarding. Seriously can’t wait to get the drivetrain in it!
Old 10-20-2017, 09:58 AM   #38
ILLSMOQ
Here we go!
Old 10-20-2017, 10:35 AM   #39
DustinS
DustinS's Avatar
Woo! Good Luck! You might look at removing the bumper/radiator support/radiator. Makes the entire front open and installing/removing engine/trans so much easier. Also gives a lot of room to work around things.
Old 10-20-2017, 12:02 PM   #40
ILLSMOQ
Kind of didn’t want to do that but yes I can see how it would make everything way easier and will probably be necessary... Read a bunch of things about the bumper cover not going back on as tight after it’s been pulled how has yours been?
Old 10-20-2017, 12:08 PM   #41
DustinS
DustinS's Avatar
Apparently the new bumpers aren't as bad as the old ones. Definitely a good reason not to though. Mine fits like junk.
Old 10-20-2017, 01:24 PM   #42
imnotsureaboutbrz
Drives: between cars...
WOW! How have I missed this thread! First 2 pages were a tease, but it got better! so awesome!
imnotsureaboutbrz is offline   Reply With Quote
Started my car and... zephyr69 Issues | Warranty | Recalls / TSB 8 07-15-2013 03:55 PM
FRS/BRZ Bottom End UNDR8D Engine, Exhaust, Transmission 11 06-19-2012 09:36 AM
This Subaru Started After Sitting On The Bottom Of A Lake For Three Months BRZ'ed Other Vehicles & General Automotive Discussions 3 06-06-2012 02:06 PM
