Old 03-23-2017, 11:53 AM   #29
Gunman
Drives: 2019 Mazda Miata RF
Originally Posted by nextcar View Post
3) Light wheels can flex more contributing to slower lap times - ideally you want very strong, light wheels.
At a former team that I worked for, we tested different wheels, and with multiple drivers, running multiple laps, and not telling the driver which wheels were on the car. The lap times, and driver feedback showed a clear difference in how the car reacted to different wheels, stiffness being the difference.
Gunman is offline   Reply With Quote
Old 03-23-2017, 12:33 PM   #30
DAEMANO
Time Traveller
Seconded. Everything that I've read suggest the same. STRONG wheels are the fastest. Light mostly only countss if also strong (unsprung weight matters though, so LIGHT + STRONG is best).
Old 03-23-2017, 03:13 PM   #31
Yardjass
Yardjass's Avatar
Drives: '14 Monogram, '95 Miata, '90 300ZX
Too bad there isn't a whole lot of info out there on how rigid different lightweight wheels are relative to each other. I'd love to see if you lose anything when you for example, go RPF1 over one of the slightly heavier but still relatively lightweight options. Also, I'm sure the differences between Roturds, XXR's, and the real wheels they're copying would be entertaining to say the least.
Yardjass is offline   Reply With Quote
Old 03-23-2017, 05:43 PM   #32
cjny
Drives: 2016 BRZ
It makes sense that stiffness would be important, but stiffness and strength are not the same thing. Strength tells you how hard you can abuse your wheels before they break or permanently bend. Stiffness tells you how much the wheel flexes during cornering.
cjny is offline   Reply With Quote
Old 03-23-2017, 11:15 PM   #33
reeves
Originally Posted by Impureclient View Post
In 2000, there was a recall for SUV tires they made for Ford Explorers.
As far as those new Indy 500s, there isn't a negative review online and I've been reading through everything I could find online.
Either people like them or love them who have used them. Pretty sure that's what I'm trying next.
Recalled only after almost 50 deaths, resulting from tread separation from the tire. After several investigations & a Senate hearing, it was found that Firestone knew about the problem dating back to 1994, but tried to hide it. They even admitted to ramping up production to "dilute the failure rate".
Ford didn't help either with their initial recommended tire pressure of 26 psi, to give the Explorer a more 'comfortable' ride.. which resulted in more wear & flexing of the sidewalls, leading to overheated tires.
Sorry didn't mean to derail this thread.. I just knew someone who was almost hurt in an accident from those bad Firestone tires, so I still get worked up thinking about it.
The Firehawk does look promising, so I hope it works for you. I do hope Firestone has cleaned up their act, but I'll be waiting to spend my money on the new Michelin Pilot Sport 4S.
reeves is offline   Reply With Quote
The Following User Says Thank You to reeves For This Useful Post:
Tcoat (03-24-2017)
Old 03-24-2017, 09:40 AM   #34
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Yes, you are right. The stiffness of the rim is extremely important. Personally, I want to focus on cornering and I have a very stiff and high strength rim (Enkei RS05).
Regarding the question on the RPF1, you can find such information in Enkei's Japan site (http://www.enkei.co.jp/). Here are some comparisons between different rims:
RPF1
RS05
The Following 4 Users Say Thank You to nikitopo For This Useful Post:
FujiwaraTofu86 (03-24-2017), Tcoat (03-24-2017), TommyW (03-24-2017), Yardjass (03-24-2017)
Old 03-24-2017, 11:04 AM   #35
churchx
churchx's Avatar
Drives: 2014 GT86
Of course, ones with higher budget can get forged wheels that are both as strong/stiff as stiffer cast wheels, yet weight as much or less as lightest cast ones. Win-win everywhere but at wallet.
Old 03-24-2017, 12:58 PM   #36
cueball89
Drives: 15 Impreza
Enkei did some rigidity testing a few years ago with 2 sets of the same wheel. One set was lightened by approximately 4lbs.
http://www.m3post.com/forums/showthread.php?t=479110
cueball89 is offline   Reply With Quote
The Following User Says Thank You to cueball89 For This Useful Post:
TommyW (03-24-2017)
BUDDY CLUB Lightweight Racing Wheels - JDM, lightweight, low pricetag | 18x8.5" GuerillaRacing Wheels and Tires 116 01-20-2015 06:32 PM
TWS Forged Wheels T66-F - Ultra lightweight Race Wheels with Style // DSG Performance Jason@DSG Wheels and Tires 37 12-17-2014 02:50 PM
Can stickers make your 86 Faster? ntron1 BRZ First-Gen (2012+) — General Topics 21 04-14-2014 02:03 PM
Lightweight wheels or wide wheels Moetivegt86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 28 11-06-2013 10:57 PM
