Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
03-09-2017, 10:21 AM | #29 | |
Drives: 2015 Raven FRS
03-09-2017, 10:37 AM | #30 |
Drives: toyota86 full opt aero auto
03-09-2017, 11:39 PM | #31 | |
Drives: Toyota 86
And at 400hp it is just quite absurd to be quite honest! anything above half throttle in auto mode to get on it a bit from a roll and your spinning wheels. In manual mode getting on it decently it just spins 1/2/3 if your really into it. Fun but a bit scary!. Driving in auto mode is actually realllllly sketchy if you are rolling along and decide do lay into it. You will just go sideways. SC might be a bit diff to turbo in that respect though as its not a rush of boost all at one time.
2013 Toyota 86 (IQOf86) - Coyoda Turbo Kit, Perrin 3" Exhaust, 18" CE28SL's, Custom Oil Cooler/Transmission Cooler, Tuned by Coyote Tuning, Built FA20, E85 Fuel, Turbo Kit and Oil Coolers installed by Turbo Yoda
03-10-2017, 12:15 AM | #32 |
How much torque are you putting down?
03-10-2017, 01:13 AM | #33 |
The Following User Says Thank You to Lunatic For This Useful Post: | tyler_win_photo (03-10-2017) |
03-10-2017, 05:01 AM | #34 | |
Sent from my HUAWEI NXT-L29 using Tapatalk |
03-10-2017, 06:04 AM | #35 | |
Drives: Toyota 86
Will try and go 265+ on rear next time I think.
03-10-2017, 07:08 AM | #36 |
03-10-2017, 08:04 AM | #37 |
Drives: Toyota 86
No rubbing yet. Have a few ppl over here running 265+ in the rear depends on offset I guess and how low you actually are?
03-10-2017, 09:50 AM | #38 | |
03-10-2017, 10:31 AM | #39 |
Fast enough
Drives: 2013 Subaru BRZ AT
How are you guys all handling the rev limiter with the increased power?
I'm asking because at least on my JRSC + HBP+ E85 car, I will hit the limiter before the trans is able to shift from 1st to 2nd in automatic mode. Normally I'm in manual mode when I want to have fun and I shift it when needed to account for that. Just wondering. I also notice that there is a slight delay in the shift from 1st to 2nd and 2nd to 3rd when I'm full out. As in I click the paddle but I stay in gear still accelerating for a split second longer. The shift itself seems pretty quick once it starts. |
03-10-2017, 10:47 AM | #40 | |
-Phil's BIGGEST FAN BOI
Drives: 2014 Greddy Turbo BRZ
I have the same hanging issue.
When I'm shifting above 4k and on the throttle, the RPM dips like it's suppose to, but you're able to see a little waver at exactly 4k before it starts climbing in the RPMs again. Quote:
2014 Subaru BRZ
Don't follow your dreams, follow my instagram www.instagram.com/soloside |
03-10-2017, 12:45 PM | #41 |
Drives: AVO Turbo Subaru BRZ / Subaru WRX
For me with 255lb of torque and it's slipping like crazy. Wheels no spinning but revs would climb and sometimes my fourth gear would disappear totally in manual mode. The revs would drop to idle and I would have to shift down to 3rd gear instead.
AVO Turbo|Essex AP Sprint Kit|AVO Overpipe|HKS Hi-Power Spec L Catback|Cusco Engine Mounts|Whiteline Bushings|KW Clubsport|Defi Advance ZD|AEM Wideband Failsafe Gauge|Greddy ProFec Boost Controller|Tomei 2Way LSD|AEM Water/Meth Kit|PBM Angle Kit + Kunckles|Flatwell LCA|HKS Oil Cooler|Greddy High Cap. Diff Cooler|Sard ATF Oil Cooler|CSF Radiator|
03-10-2017, 01:24 PM | #42 |
Has anyone here experienced the P2757 CEL?
The light ONLY happens when I'm in 4th gear at more than half throttle.
2014 Subaru BRZ
Similar Threads | ||||
Boosted owners in NY - how are you passing state inspections? | Foobar | NY / NJ / CT / PA | 12 | 10-15-2015 02:02 PM |
Auto Trans issue | Triumphrider | Issues | Warranty | Recalls / TSB | 9 | 11-04-2014 07:34 PM |
Is there an Auto Trans only dyno thread? | Pure Automotive | Engine, Exhaust, Transmission | 17 | 07-17-2014 12:35 AM |
Auto Trans Feels like it is slipping... | Fett4Real | Issues | Warranty | Recalls / TSB | 19 | 01-16-2014 10:02 PM |
What is the best way to Launch the Auto Trans | DeOppressorLiber | Tracking / Autocross / HPDE / Drifting | 27 | 10-22-2013 11:24 PM |
