Old 03-09-2017, 11:21 AM   #29
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
Originally Posted by krr150 View Post
Good to hear it's holding up, I'm really leaning towards the edelbrock s/c. eventually id probably chase 400whp & I know that the boost would be too high for a stock box and tranny
Could you tell me what is the boost psi on the base tune and torque & HP numbers? I don't want a rebuild right away I like to take it step by step for the experience and financial reasons too
Sent from my HUAWEI NXT-L29 using Tapatalk
9 psi boost
Lunatic is offline   Reply With Quote
Old 03-09-2017, 11:37 AM   #30
krr150
Drives: toyota86 full opt aero auto
Originally Posted by Lunatic View Post
9 psi boost
Oh that sounds to be very safe. Thanks for the quick response bro😉
krr150 is offline   Reply With Quote
Old 03-10-2017, 12:39 AM   #31
Stimmed
Stimmed's Avatar
Drives: Toyota 86
Im sitting at 400hp on quite a low reading dyno. And its having no issues.
And at 400hp it is just quite absurd to be quite honest! anything above half throttle in auto mode to get on it a bit from a roll and your spinning wheels.
In manual mode getting on it decently it just spins 1/2/3 if your really into it. Fun but a bit scary!.
Driving in auto mode is actually realllllly sketchy if you are rolling along and decide do lay into it. You will just go sideways. SC might be a bit diff to turbo in that respect though as its not a rush of boost all at one time.
2013 Toyota 86 (IQOf86) - Coyoda Turbo Kit, Perrin 3" Exhaust, 18" CE28SL's, Custom Oil Cooler/Transmission Cooler, Tuned by Coyote Tuning, Built FA20, E85 Fuel, Turbo Kit and Oil Coolers installed by Turbo Yoda
Stimmed is offline   Reply With Quote
Old 03-10-2017, 01:15 AM   #32
tyler_win_photo
tyler_win_photo's Avatar
Drives: 2014 Scion FRS (Asphalt)
I am at 323 with edelbrock and e-85. Automatic tranny, lots of track days, and no problems at all. I always heard the automatic was actually stronger then the manual. I also run a tranny cooler and normally see 230 to 240 tranny temp on track.
How much torque are you putting down?
tyler_win_photo is offline   Reply With Quote
Old 03-10-2017, 02:13 AM   #33
Lunatic
Lunatic's Avatar
250 @ 5800 rpm.
The Following User Says Thank You to Lunatic For This Useful Post:
tyler_win_photo (03-10-2017)
Old 03-10-2017, 06:01 AM   #34
krr150
Wow😂 what tyres are you running
Old 03-10-2017, 07:04 AM   #35
Stimmed
Stimmed's Avatar
Drives: Toyota 86
255/35/18 on 9.5.
Will try and go 265+ on rear next time I think.
Old 03-10-2017, 08:08 AM   #36
tyler_win_photo
255/35/18 on 9.5.
I was thinking of that tire size next time around. Do you currently rub? I heard 265s will rub a little in the rear unless you shave back the tab on the bumper.
Old 03-10-2017, 09:04 AM   #37
Stimmed
Stimmed's Avatar
Drives: Toyota 86
No rubbing yet. Have a few ppl over here running 265+ in the rear depends on offset I guess and how low you actually are?
Old 03-10-2017, 10:50 AM   #38
Lunatic
Lunatic's Avatar
I'm close to you, at 323 and 255/40/17's 1st and 2nd are worthless. But boy is it fun once you hook up. I can't imagian what 400 would be like.
Old 03-10-2017, 11:31 AM   #39
xsnapshot
Fast enough
Drives: 2013 Subaru BRZ AT
How are you guys all handling the rev limiter with the increased power?
I'm asking because at least on my JRSC + HBP+ E85 car, I will hit the limiter before the trans is able to shift from 1st to 2nd in automatic mode.
Normally I'm in manual mode when I want to have fun and I shift it when needed to account for that.
Just wondering.
I also notice that there is a slight delay in the shift from 1st to 2nd and 2nd to 3rd when I'm full out. As in I click the paddle but I stay in gear still accelerating for a split second longer. The shift itself seems pretty quick once it starts.
xsnapshot is offline   Reply With Quote
Old 03-10-2017, 11:47 AM   #40
Soloside
-Phil's BIGGEST FAN BOI
Drives: 2014 Greddy Turbo BRZ
I have the same hanging issue.
When I'm shifting above 4k and on the throttle, the RPM dips like it's suppose to, but you're able to see a little waver at exactly 4k before it starts climbing in the RPMs again.
Just wondering.
2014 Subaru BRZ
Don't follow your dreams, follow my instagram www.instagram.com/soloside
Soloside is offline   Reply With Quote
Old 03-10-2017, 01:45 PM   #41
liquidsky44
liquidsky44's Avatar
Drives: AVO Turbo Subaru BRZ / Subaru WRX
For me with 255lb of torque and it's slipping like crazy. Wheels no spinning but revs would climb and sometimes my fourth gear would disappear totally in manual mode. The revs would drop to idle and I would have to shift down to 3rd gear instead.
AVO Turbo|Essex AP Sprint Kit|AVO Overpipe|HKS Hi-Power Spec L Catback|Cusco Engine Mounts|Whiteline Bushings|KW Clubsport|Defi Advance ZD|AEM Wideband Failsafe Gauge|Greddy ProFec Boost Controller|Tomei 2Way LSD|AEM Water/Meth Kit|PBM Angle Kit + Kunckles|Flatwell LCA|HKS Oil Cooler|Greddy High Cap. Diff Cooler|Sard ATF Oil Cooler|CSF Radiator|
liquidsky44 is offline   Reply With Quote
Old 03-10-2017, 02:24 PM   #42
Soloside
Has anyone here experienced the P2757 CEL?
The light ONLY happens when I'm in 4th gear at more than half throttle.
2014 Subaru BRZ
Boosted owners in NY - how are you passing state inspections? Foobar NY / NJ / CT / PA 12 10-15-2015 03:02 PM
Auto Trans issue Triumphrider Issues | Warranty | Recalls / TSB 9 11-04-2014 08:34 PM
Is there an Auto Trans only dyno thread? Pure Automotive Engine, Exhaust, Transmission 17 07-17-2014 01:35 AM
Auto Trans Feels like it is slipping... Fett4Real Issues | Warranty | Recalls / TSB 19 01-16-2014 11:02 PM
What is the best way to Launch the Auto Trans DeOppressorLiber Tracking / Autocross / HPDE / Drifting 27 10-23-2013 12:24 AM
