#29 |
Drives: 86
#31 | |
If you connect via serial knterface and use the renasis or tactrix ecuflash software tool to talk to ecu they send the software commands to ecu to go into sh boot mode as soon as this happens the ecu wiĺl delete both the user and boot areas To reflash ecu you then need both the boot and user rom areas unfortunatly no one has boot area code |
#32 |
Drives: 2014 GT86
I wonder cannot stock boot area code somehow be read to some image?
| The Following User Says Thank You to churchx For This Useful Post: | aagun (01-21-2017) |
#33 | |
Drives: 86
what about this in evo http://www.evolutionm.net/forums/evo...-pictures.html |
#34 | |
the tactrix guys wre working on trying to read the boot area. Once someone works out how to read the boot area then you will be able to use the SH boot mode and serial interface to recover ECU. The Lancer ecu is different, it was simialr to older wrx ecu based on earlier processor 7058 7059 and these processors only had one memory area and you could read entire area and recover using sh boot mode. The BRZ ecu is different unfortunatly and has the two memory areas |
#36 | |
Drives: frs
This below just really doesn't smell right:
If I were you, rather than asking on this forum I would contact Tactrix guys directly to get 100% correct answer to this question - if it's possible bench BRZ ECU ala EVO and use EcuFlash flash recovery mode. |
#37 |
Drives: 86
ecu changed . and the car work now after registration the ECM to key id
| The Following User Says Thank You to aagun For This Useful Post: | steve99 (01-24-2017) |
#38 |
Drives: Full race 4cyl boxer
Has anyone looked to see if the ECU brings out the JTAG pins (TCK, TMS, TDI, TDO & TRST)?
If there is a 5-8 pin header all by itself (or even bare pads), they might have provided a connection for a JTAG pod to connect. If that is the case, it should be possible to get control through that port on a bricked ECU.
Arguing with an engineer is like wrestling with a Pig in the mud. You are never going to win and after a couple of hours you realize that he likes it.
#39 |
Drives: 86
@steve99
thx for helping i am not give up form old ecu . i know alot of ppl wanna unbrick sh72531 ecm and there are many rom devrs can't hijack anything coz of bricks . thx alot |
#40 | |
Drives: 86
#41 | |
when you use sh boot mode you need the actual data from 0000-7ffff which no one has, the tactrix guys were working on reading the boot area. |
#42 | |
If the user rom is completly corrupt non existant and checksum is wrong you can usually recover with a power off on reset and reflash. If the rom flashed correctly and checksum is correct but code is bad and send processor into loop or some strange state then you dont appear to be able to recover with power off on and for some reason the watchdog does not seem to recover the processor. Or maybe it does and its resetting the thing so often you dont get a chance to talk to it via obd port. Untill somone bench tests one and looks at all the signals its all speculation |
| Bricked ECU? | FirestormFlex | Software Tuning | 8 | 03-14-2016 10:20 AM |
| My OFT is basically bricked | austin_ellas | Software Tuning | 19 | 03-08-2016 07:59 PM |
| Who has Bricked an ECU | Toyota John | Software Tuning | 5 | 03-02-2015 11:10 PM |
| Need Bricked BRZ 86 ECU | steve99 | Software Tuning | 0 | 10-25-2014 07:09 PM |
| I think I bricked my ECU with EcuTek help | iketiak | Engine, Exhaust, Transmission | 4 | 07-04-2013 12:19 AM |
