Old 01-17-2017, 12:05 AM   #29
tCsonfrs
Drives: 10 Series FR-S #207
Originally Posted by Stang70Fastback View Post
I'm doing 10,000 mile intervals, soooooooo... #grandexperiment.
Why??
Also bump for resolution for the OP
tCsonfrs is offline   Reply With Quote
Old 01-17-2017, 12:52 AM   #30
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
Originally Posted by tCsonfrs View Post
Why??
I'll let my blog post do the talking:
More Fluid Changes and Blackstone Labs Oil Analysis
I racked up just shy of 10,000 miles since my last oil change over 6 months ago, which meant it was time to do it all over again. The timing worked out perfectly to allow me to change all of my fluids before the weather got cold enough to make it an annoying task. For those who haven’t been following along with my previous oil change posts, I use AMSOIL fluids in the engine, transmission, and differential. I also follow a modified service interval. For the transmission and differential, Subaru suggests a 30,000 mile oil change interval, but I dropped that to 20,000 because of my severe use, and because I think AMSOIL fluids are a bit thinner than the OEM fluid. The transmission and differential fluids looked fine when I changed them (though I assume the transmission fluid was changed when I had the throwout bearing replaced recently). Also, there were no more metal shavings on the magnetic drain plug for the differential than one might expect after 20,000 miles. So no issues there.
Subaru dictates a 6,000 mile oil change interval for the engine, but AMSOIL claims 25,000 miles, or 15,000 under “severe use.” Since I fall well within the severe use category, and didn’t want to push my luck, I’m doing 10,000 mile intervals, which is still significantly higher than what Subaru suggests. I’m also sending samples at each oil change to Blackstone Labs for analysis. Before we get to those results, though, let’s consider the past 10,000 miles:
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
Old 01-17-2017, 12:55 AM   #31
Calvin27
Drives: GTS
A few aussies (mostly boosted but some na) are running into the spun bearing now and some of these cars are out of warranty. I hope you get it fixed through warranty, but if not let us know what the quoted cost to fix is. I suspect it can't be too far from a HKS 2.1L stroker kit - which would make it a little more bearable.
Calvin27 is offline   Reply With Quote
Old 01-17-2017, 04:52 PM   #32
demasrv
demasrv's Avatar
Drives: 2013 Rally Blue BRZ
Will do--apparently they sent the info over to Subaru Friday afternoon. I'm not sure what the expected wait period is, but my hope is they'll at least give approval to tear into it to see what the issue is soon. I'm pretty certain it's the spun rod bearing issue since there are example of that happening on the forums and I was getting the same sound that I heard in other youtube videos.
In the end my only maintenance proof I have is:
1. FB picture dated with car on ramps and the oil draining on 9/2015
2. Receipt from O'Reily showing purchase of mobil1 0w-20 oil in 3/2016
3. Receipt on Amazon showing royal purple 0w-20 and OEM filter in 10/2016
demasrv is offline   Reply With Quote
Old 01-17-2017, 05:01 PM   #33
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
So to them, you changed your oil once in 2015 and twice in 2016 lol.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 01-17-2017, 05:09 PM   #34
Oh Dude you screwed yourself if you sent them this! They don't care what the AMSOIL claims are they say 6000 miles or six months.
"I racked up just shy of 10,000 miles since my last oil change over 6 months ago"
"Subaru dictates a 6,000 mile oil change interval for the engine, but AMSOIL claims 25,000 miles, or 15,000 under “severe use.” Since I fall well within the severe use category, and didn’t want to push my luck, I’m doing 10,000 mile intervals, which is still significantly higher than what Subaru suggests. I’m also sending samples at each oil change to Blackstone Labs for analysis. Before we get to those results, though, let’s consider the past 10,000 miles"
tCsonfrs (01-19-2017)
Old 01-17-2017, 05:12 PM   #35
demasrv
demasrv's Avatar
Well not entirely--I bought the car used in September 2015. The dealership pulled a carfax and records from the other Subaru dealership in town.
Currently right at 53k miles. The more I'm reading the more I regret buying a 2013.
Old 01-17-2017, 08:57 PM   #36
stevesnj
stevesnj's Avatar
I used the Scion customer portal and had all my maintenance history there. Now it's all gone. Wish they would've told me it's being deleted.
My 2016 Build thread
The Following User Says Thank You to stevesnj For This Useful Post:
Tcoat (01-17-2017)
Old 01-17-2017, 09:35 PM   #37
Stang70Fastback
A.K.A. Starlord
Yeah, at that point the theory is that if I ever have an issue, and Subaru claims it was an oil-related failure, AMSOIL is supposed to pay the repair. That's what AMSOIL says, anyway. That's why I said it's a grand experiment. It's really AMSOIL's "warranty" that I'd be testing.
The Following User Says Thank You to Stang70Fastback For This Useful Post:
Tcoat (01-17-2017)
Old 01-19-2017, 12:11 AM   #38
tCsonfrs
Its on Toyota's website now
The Following User Says Thank You to tCsonfrs For This Useful Post:
stevesnj (01-19-2017)
Old 01-19-2017, 02:42 PM   #39
stevesnj
stevesnj's Avatar
That's what I thought, even with my vin I can't find my car.
Old 01-19-2017, 03:02 PM   #40
Didn't even know this was a thing. How do you get to it? I am lazy and don't want to wander the labyrinth that is Toyota's website.
Old 01-20-2017, 12:19 AM   #41
tCsonfrs
No idea honestly, in the early days I used to go to the Scion website and track my maint with them bu then I stopped. They sent me a few emails telling me that the info would be transferring to Toyota's website and that I should register my car on there but I never did
The Following 2 Users Say Thank You to tCsonfrs For This Useful Post:
stevesnj (01-20-2017), Tcoat (01-20-2017)
Old 01-20-2017, 11:57 AM   #42
stevesnj
stevesnj's Avatar
Scion had a maintenance graph you manually can put in your maintenance and whatever the dealer did they enter their service record. It was pretty good actually.
Toyota finally updated my account service history, it's crappy compared to the Scion, oh well. It just doesn't have all my self maintenance and mods. I have to re-enter them
The Following 2 Users Say Thank You to stevesnj For This Useful Post:
Tcoat (01-20-2017), tCsonfrs (01-21-2017)
engine, oil change engine damage, rod knock, warranty
What do you use your car for and how important is suspension to you? Racecomp Engineering Suspension | Chassis | Brakes -- Sponsored by 949 Racing 58 04-17-2015 08:46 AM
Is this cap important Frs32907 Engine, Exhaust, Transmission 5 03-29-2014 08:08 PM
IMPORTANT QUESTION AZOOZ_95 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 27 08-21-2013 03:44 AM
Color, how important is it to you? Iixii BRZ First-Gen (2012+) — General Topics 63 11-09-2012 11:25 AM
How important is an LSD on this car? colHolm Scion FR-S / Toyota 86 GT86 General Forum 92 05-13-2011 06:53 PM
