Old 01-12-2022, 03:08 PM   #29
Pat
Pat's Avatar
Drives: 2023 BRZ
While that might explain some of the discrepancies, it doesn't explain all of them. I've still seen meaningful differences between sensors on the same vehicle at a fixed altitude.
Also, explaining the difference is altitude doesn't really fix the problem. It's still a problem many people have to account for if they want accurate readings. I don't understand why people are so reluctant to check tire pressures manually. It takes almost no time or effort.
Old 01-12-2022, 03:16 PM   #30
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I do check them manually. The problem is I would like to have an idea of what my tire pressures are peaking at as what I am reading in the pits isn't 100% accurate either because of a long cooldown lap at the track I frequent the most. I am interested more for the data and to have a live reference while driving.
Old 01-13-2022, 01:04 AM   #31
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Originally Posted by geraldjust View Post
i actually got TPMS out of the can data from these cars. But its not as simple as sending some bytes and getting the return back. I can give ya a hint. its basically how Multi-Frame Message. If you google that you will get a semi aquatineace on how it works.
BTW responses should be in 0x758
This is a great pointer!
We would all really appreciate it if you could just share the exact request / response protocol.
I'm going to add it to my GitHub anyways, but you can just save everyone some time
I promise to read more into the details of how Multi-Frame Messages work!
I find "learn by studying an example" to be more effective than
"learn by first solving a puzzle that requires you to already know what you want to learn to solve it".
Also curious if you've confirmed if the same message format is working on the 2022 cars.
Have you guys ever compared TPMS readings with readings from a high-quality traditional gauge? [...] But I think it's important to recognize there can be significant inaccuracies in them.
Totally. I definitely wouldn't rely solely on them, but they should give you a ballpark trend how much your tires gained in PSI since the start of the session.
Keep in mind that the sensors are Absolute pressure
Interesting data!
yeah i was worried about that too. but the sensors have a .5psi resolution
I have seen two different sensors at the exact same ambient conditions reading 2–3 psi off each other,
even though the same pressure gauge measured the same pressure from both tires.
So "0.5 psi resolution" doesn't necessarily mean "0.5 psi precision".
But again, as long as you can see the general trend...
So i made mine also check temp too.
This is perhaps even more interesting to log!
timurrrr is offline   Reply With Quote
Old 01-13-2022, 01:05 AM   #32
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
I think doing both is better than doing either of them individually.
If only doing one, using a high quality pressure gauge is probably more precise,
as long as you fly into the pits at full speed, and your assistant quickly checks all four tires while they're hot.
Old 01-13-2022, 02:49 AM   #33
geraldjust
Drives: MR2, Sliver BRZ
Interesting data!
Interesting thing to find about two tires being at different temps / pressures but same ambient temp. it was a conundrum that only happen at daytime but not at night. i ended up finding out with this that a parked car whos tires face the sun warm up so much it can use a super noticeable difference in PSI. by resolution i mean yes by .5. but so far ive tested with a backup manual check of my in the valve stem and for me they been all accurate with 1psi. But i do have the oem sensors. im not 100% sure if the accuracy is maintained if using aftermarket sensor though as its just a added variable in accuracy.
also for what use is for simplicity. not saying you should rely on the sensors. but knowing the temp and psi help out a ton. i even did some measurements when heating the front tires when braking repeatedly with heavy breaking. Looking at the sensors and sure enough you can see the difference.
let me dig up the code and and il ask my business partner if i can release the info!
Always looking to tinker with something..
geraldjust is offline   Reply With Quote
Old 01-30-2022, 03:31 AM   #34
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
I FIGURED IT OUT!
To read tire pressures
Request 1:
Data: 2A 02 21 30 55 55 55 55
Provides a response:
Data: 2A 10 07 61 30 XX YY ZZ
The highlighted "1" means that this is the first frame of a multi-frame response.
To get the second frame, we need to send a "Continue to send request":
Data: 2A 30 00 05 55 55 55 55
Which provides the second frame of the response:
Data: 2A 21 WW 00 00 00 00 00
The XX, YY, ZZ and WW bytes in the response will contain the tire pressures for sensors #1, 2, 3 and 4.
I believe the encoding is:
pressure_in_kPa(x) = (2 * x) - 100
pressure_in_psi(x) = (0.29 * x) - 14.5
where "x" is the value of XX, YY, ZZ or WW.
However it's worth noting that ScanGauge seems to use a different formula:
pressure_in_psi(x) = (0.2977 * x) - 14.7
Given that the car is Japanese (metric), the "(2 * x) - 100" seems like a simpler / more plausible encoding than what ScanGauge uses.
To read tire temperatures
Similar thing, just slightly different bytes:
0x750 | 2A 02 21 16 55 55 55 55
0x758 | 2A 10 07 61 16 XX YY ZZ
0x750 | 2A 30 00 05 55 55 55 55
0x758 | 2A 21 WW 00 00 00 00 00
and formulas:
temperature_in_C(x) = x - 40
temperature_in_F(x) = (x * 1.8) - 40
Enjoy!
Thanks so much @BRZyJ for letting me play with his ScanGauge!
Old 01-30-2022, 03:53 AM   #35
geraldjust
I FIGURED IT OUT!
Request 1:
and formulas:
Enjoy!
hey you gut it! congrats! for PSI its: (X+32)/4
And to get relative pressure then X+32)/4 - 14.5
so you understand how extended frames work!
Old 01-30-2022, 04:36 PM   #36
22R
22R
22R's Avatar
Drives: 2012 Camry SE 2017 Toyota 86
I really do not need this but Dayum that it too neat. I have a Scangauge II but this is the shizzle. Ima put it on my wishlist.
Nice Website and equipment.
22R
22R is offline   Reply With Quote
Old 06-04-2022, 09:11 PM   #37
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
And to get relative pressure then: (X+32)/4 - 14.5
Looks like Autel is using ((X * 0.25) - 7.5) for psi,
which maps to ((X * 1.724) - 51.7) for kPa.
Follow the build thread for my GR86!
Old 06-01-2024, 07:49 PM   #38
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
2024 update:
  1. Note that XX / YY / ZZ / WW values in the examples above are ordered by sensor index.
    That means that as you rotate tires the corners will unfortunately get reshuffled in data.
  2. gen2 cars support the exact same 0x750/0x758 protocol as the one I documented for gen1 cars.
  3. Additionally, you can passively observe tire pressure data from gen2 cars via 0x6E2:
    https://github.com/timurrrr/ft86/blo...-id-0x6e2-1762
    Good news: the data seems to be ordered by tire position, so the channels shouldn't get reshuffled if you rotate tires.
    As 0x6E2 is broadcast on the CAN bus, you can listen to that data passively, which is important when data logging using the popular RaceChrono / OBDLink MX+ combo.
    Meh news: the data uses only psi precision, unlike 0x758 which uses 0.25 psi precision.
    Thanks to @geraldjust for pointers on 0x6E2!
Old 01-26-2026, 05:32 PM   #39
Luns
Drives: 2017 GT86
I poked around a little with TPMS in Techstream. The gauge pressure values I saw would always end in 0.15, 0.4, 0.65 or 0.9.
Totally a moot point, but I think changing the 14.5 to 14.6 would align things with Techstream. It puzzles me though that it's not 14.7 instead.
This was on my gen1, over a range of pressures from 28 to 36PSI, and temperatures from 58-64F. I don't know if the fractional parts may vary outside this window. Pressures didn't exactly match my pressure gauge, but I have more faith in the TPMS sensors than my gauge.
Luns is offline   Reply With Quote
New TPMS Sensors - Car Not Reading Them Bluesman62 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 11-27-2016 01:41 AM
SOLD - Set of 315MHz TPMS - $125 OBO - Tire Pressure Sensors badamowski Wheels and Tires 0 07-16-2014 10:07 PM
Tire Pressures mike the snake Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 04-21-2014 04:03 PM
Tire Rack tpms sensors TimR Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 10-27-2013 12:12 PM
WTB: Tire Pressure Monitoring Sensors (TPMS) RYU Wheels and Tires 6 09-18-2012 12:52 PM
