Old 11-10-2016, 06:39 PM   #29
jvincent
jvincent's Avatar
Nope.
I may not have to drive so much when it is time for my next car and then it is hello Porsche or Jag. I will then just appear here every once in a while to see how the peasants are doing!
A man of your stature should be rocking this.
Old 11-10-2016, 07:57 PM   #30
I still have something of a budget to live within!
Old 11-10-2016, 08:41 PM   #31
jvincent
jvincent's Avatar
If you are talking Porsche or Jaguar this isn't that far out of reach. Just eat ramen until you retire.
Old 11-11-2016, 12:00 AM   #32
allowe
allowe's Avatar
I can see you driving S-FR lol
Is this actually going to make it to the markets?! What's the point... don't get me wrong we need more rwd jdm cars but the frs is better in every aspect other than weight and size which the frs isn't far off. Maybe someone has a different opinion on it. Let me know what you guys think of it.
allowe is offline   Reply With Quote
Old 11-11-2016, 09:42 AM   #33
allowe
allowe's Avatar
Originally Posted by Shark_Bait88 View Post
Pick up a used set of bugeye WRX wheels. They'll cost you about the same as steelies, but will look better and be hubcentric. (This is coming from someone who actually likes the look of steelies, btw)
You are a genius! I didn't know they would fit. I found a super cheap pair and they look amazing! I'm guna plasti dip them white to go with my white frs thanks!
Old 11-11-2016, 09:45 AM   #34
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
Originally Posted by allowe View Post
You are a genius!
Finally! The recognition I deserve.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
Old 11-11-2016, 10:29 AM   #35
There is a whole thread dedicated to this someplace. It is still just a concept with no real news since the spring. There is still no confirmation that it will be made at all much less come over here. The odds of them importing them even if it gets made are remote anyway.
Old 11-11-2016, 10:51 AM   #36
PeterFRS
PeterFRS's Avatar
Drives: FRS
17 inch steelies ftw..hubcentric too
'14 Scion FRS
Tein Flex
TE37
PeterFRS is offline   Reply With Quote
Old 11-12-2016, 11:26 AM   #37
cjny
Drives: 2016 BRZ
Down-sizing for winter has never made sense to me. Maybe I'm just thick. Maybe it's just the things I value are different from the way others see it.
Each year I DREAD the day when I have to switch to winter tires. I put it off as long as possible, not wanting to take the performance hit until absolutely necessary. Picking a taller sidewall and narrower tread would make the decrease in performance even worse. Even where I live (more snow than most people, for sure) I drive on clear roads way more often than not. MAYBE I give up a small amount of traction on a few real snow days, but my driving in those conditions is more limited by the others on the road than it is by the conditions themselves. So, no, down-sizing just doesn't appeal.
I use a studless snow tire (not one of the "performance" snow tires, which seem to be only slightly better than all-seasons) in stock size. Dry and wet grip is less than with the summer tire, of course, but not as noticeable as a narrower tire would be.
cjny is offline   Reply With Quote
Old 12-03-2016, 09:38 PM   #38
WWFT86
Drives: 2017 BRZ Limited
From tire rack:
Why is Narrower Better in Winter Conditions?
Thursday, January 12, 2012 by Hunter Leffel
Winter Driving"Why does Tire Rack recommend narrower tires for winter use?"
It's all about physics. Wider tire sizes have to plow through the snow which causes more resistance and a tendency to float. A narrower option, with a smaller contact patch, has more weight per square inch that helps the tire cut through the ice and snow.
In addition to the increased winter capability, there are other advantages to a minus size winter / snow tire. In most cases, narrower tires have a lower price tag. The advantage will apply in cases where you're purchasing a Winter / Snow Tire & Wheel Package with smaller diameter wheels. By decreasing the wheel diameter there's an increase to the tire's sidewall that keeps the overall diameter very similar between the two size options. As an additional benefit, the extra sidewall provides more wheel protection from damages that can occur from a pothole.
- See more at: http://blog.tirerack.com/blog/hunter....aBczH6HK.dpuf
WWFT86 is offline   Reply With Quote
Old 12-04-2016, 02:21 AM   #39
geezerbrzeezer
Geezer
Drives: 2016 Subaru BRZ Sport Tech
Blizzak WS80 205/50 on stock wheels - would have gone even narrower but n/a for this tire on that wheel.
In the dry it feels . . . soft, gummy almost - new respect for the mediocre and much maligned Prius rubber.
But I gotta feeling it's gonna kick ass when it snows.
Speaking of snow, my snow button doesn't work - I've pushed it a bunch of times and it never snows.
geezerbrzeezer is offline   Reply With Quote
Old 12-04-2016, 05:35 PM   #40
KnightRyderx2
Drives: 2014 FR-S
I did 205/50 Hankook iCept Evo 2 on the stockers, put them on last week. This is first time I have used winter tires on any car, it doesn't feel right. I hate the hit to the performance and to the MPGs.
KnightRyderx2 is offline   Reply With Quote
Old 12-05-2016, 05:02 AM   #41
davmandave
Drives: 2016 Scion FRS, Pearl White, M/T
Well there's your problem! You have to push and hold for 10 seconds to make it snow.
davmandave is offline   Reply With Quote
Old 12-05-2016, 05:47 PM   #42
geezerbrzeezer
Geezer
I will try this, thanks - couldn't find that info in the manual.
FS: Goodyear UltraGrip Ice WRT 215/45/17 winter tires (tires only) Clawz Wheels and Tires 0 11-04-2016 08:46 PM
My first winter approaching, need some winter tires. Jfheisenberg Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 31 01-05-2016 08:56 PM
Winter Tires worth it in Jersey for the remaining of this winter? Jfheisenberg Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 01-22-2015 10:58 AM
Downsizing Wheels and Tires -- I Want Less Grip and More Sidewall! Rosso_Corsa Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 35 02-10-2014 09:17 AM
Report: Toyota bucks engine downsizing trend, may stay turbo-free DAEMANO Scion FR-S / Toyota 86 GT86 General Forum 9 10-15-2013 04:25 PM
