#29 |
Drives: 2013 frs
What aboutthis step. I dont get it.
Level with what!?! Sent from my iPhone using Tapatalk
2013 silver frs, injen intake, agency power header, hks exhaust, no kitties, ecutek tune
#30 |
Drives: 2013 frs
Is that essentially. Leaving the bolts loose and putting tires on. Putting car on ground and then fonishing torquing bolts. I assum thats what leveling the arm is mimicing
#31 |
Drives: 2017 BRZ
Level means level... Not sure what you don't understand. Perpendicular to gravitational pull. Its an absolute measurement. The car should be raised so its level as well, as best you can.
| The Following User Says Thank You to cjd For This Useful Post: | wparsons (11-07-2016) |
#32 |
Drives: 2017 BRZ
Not necessarily. A level driveshaft (not arm!) may not be the same as static rest position, and with tires on you need to roll the car or it won't settle right/evenly.
#33 |
Panda Trueno
Drives: No twin now.
I googled your location. Looks like there are several speed shops around that could help.
| The Following User Says Thank You to Summerwolf For This Useful Post: | wparsons (11-06-2016) |
#34 | |
Drives: 2013 frs
Yah i noticed it was friveshaft and not arm. Re did rears today. With proper spring placement. Seems to be a little better Sent from my iPhone using Tapatalk
#35 | |
Drives: 2013 frs
Not really? There are two tuner style shops. One claims u dont need to tune an frs after installing headers exhiast and intake. Even if youre throwing cel and idling weird. The other doesnt do chassis. Theres one good alignment shop in the whole province. Ill be going there this week Sent from my iPhone using Tapatalk
#36 |
Panda Trueno
Idk, but you probably need some eyes on help at this point and just get someone to fix it. Good luck.
#37 |
I highly doubt there's only one good alignment shop in all of BC... I'd suggest talking to some local racers to see where they go.
#38 | |
Drives: 2013 frs
Only one i know of. I phoned best tuner shop in bc yesterday and he said same thing Sent from my iPhone using Tapatalk
#39 |
Drives: 2013 frs
Pretty much i guess to be straighforqard i seek the cheapest way to 1 degree of variance in rear and 1.5 degree upfromt. Whitelines for front, put bottom bolt up top? Im only 3.6mm closer to suspension than stock setup with my tire and rim now. Will i need something to not hit suspension?
And spc lrcs is cheapest route for atleast 1 defgree in the rear? Sent from my iPhone using Tapatalk
#40 | |
Drives: 2005 Toyota Camry
If you want cheap, the options are listed here. -alex |
#41 |
Drives: 2013 frs
All is good! Camber is at -1.7 and -2.0. Always get a second alignment if things arent making sense i guess!!
| FS: New H&R TC112 Rear Camber Bolts, PAC 2.5" Helper Springs | customfab87 | Brakes, Suspension, Chassis | 0 | 02-08-2016 11:41 PM |
| Fitment with -2 Camber and 1" Drop 18x9.5? | ajcarson11 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 10-26-2015 02:29 PM |
| *FREE alignment* with Purchase and install of Front Camber / SPL Rear Camber Arms! | Corner3garage | Southern California | 188 | 04-24-2015 02:10 PM |
| *FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! | Corner3garage | Mechanical Maintenance and Tools | 6 | 10-31-2013 04:40 PM |
