#29 |
not playing cards
Loose tolerances make for a cheaper build. So the TL70 is a cheap transmission. Meh. Works just fine.
#30 | |
A.K.A. Starlord
Drives: 2015 Series.Blue
#31 | |
not playing cards
Answer this trick/leading question. How can the engine have any affect on the input shaft of the transmission if the clutch is disengaged?
#32 | |
A.K.A. Starlord
Point 1: Double clutching is meant to bring the transmission input shaft up to speed. When you double clutch, you release the clutch in neutral, which reconnects the engine to the transmission input shaft, and spins it up so that you can more easily go into the gear you are trying to go into. Point 2 (entirely unrelated to Point 1): If you blip the throttle so that the engine has the proper RPM, you can shift into 1st at any speed. |
#33 | ||||
not playing cards
Your points are related in the sense that they are contradictory. Quote:
The first gear limit depends on the input side spinning close enough to the output side before it allows the two (three, actually) parts of the synchro to come into contact. No amount of revving the engine will do anything in this case. Your friend is wrong and you've been experiencing a placebo effect. Many many years ago before I really thought it through, I used to do the same thing.
#34 | |
A.K.A. Starlord
I would love for someone to explain why this is the case, because everything you said is true, and so it seems contradictory to my actual experience. I'm not disagreeing with you. I'm simply telling you how my car is actually functioning. How else do you explain the video above? It isn't "faked." All I did was blip the throttle and it went right into gear at 20 MPH. If I hadn't blipped the throttle, it would not have gone into gear. My impression is that there is a mechanical system in the vehicle that prevents you from putting the shifter into 1st gear unless your engine speed is closely matched. That's what it seems like, anyway. Last edited by Stang70Fastback; 09-01-2016 at 12:03 AM. |
| The Following User Says Thank You to Stang70Fastback For This Useful Post: | Ultramaroon (09-01-2016) |
#35 |
Drives: 2017 BRZ
Given that you don't need the clutch if you rematch properly, I'm guessing the clutch engages a tiny bit before the shift happens.
#36 | |
not playing cards
If there is any difference, doesn't work quite as well or not at all, then I'll say there is just enough drag from the air gap or some light contact between the disc and flywheel/pressure plate to do the job. And I didn't get the impression you were being argumentative. I just wanted to assure you I had no intention of being "that guy."
#37 | |
not playing cards
Definitely not my experience.
#38 |
Well, this will give me something to do in the morning ...... see if/how I can get my FR-S into first gear when it is moving.
If I remember to try it ....... then remember how I did it ....... ![]() humfrz |
| The Following 3 Users Say Thank You to humfrz For This Useful Post: |
#39 | |
not playing cards
I didn't try it stone cold because I didn't think of it early enough this morning.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | Stang70Fastback (09-01-2016) |
#40 | |
A.K.A. Starlord
#41 | |
not playing cards
I'll try it as well.
| Help! Oil filter isn't coming off smoothly | ShoGun | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 40 | 11-26-2015 09:58 AM |
| How to Smoothly and Quickly Up-shift from 1st to 2nd Gear? | DemonRawr | BRZ First-Gen (2012+) — General Topics | 20 | 10-20-2014 05:51 PM |
| brake pedal doesn't return smoothly | chenshuo | Issues | Warranty | Recalls / TSB | 6 | 08-14-2013 07:06 PM |
| (6MT) Getting into 2nd smoothly | l0aded | Scion FR-S / Toyota 86 GT86 General Forum | 16 | 04-19-2013 06:10 PM |
| shifting and down shifting feel | Lowellrenzo | Scion FR-S / Toyota 86 GT86 General Forum | 23 | 07-08-2012 06:09 PM |
