Old 08-21-2016, 03:02 PM   #29
kster1
kster1's Avatar
Originally Posted by MaximeT View Post
What's your position guys related to using a 6 point harness, no helmet and oem airbag on the road ?
I don't care at all about it being legal. Just the safety side.
It's pretty hard to find an answer so far.
I'm no expert in this area but keep in mind that OEM belts are designed to stretch during an impact to help absorb the energy. A 6 pt harness on the other hand will remain much more rigid. This comes into play during a collision; with a 6 pt harness, I'd be concerned about a neck injury without some type of HANS device (the torso will be stopped with the stiff belts but the head continues moving forward).
kster1 is offline   Reply With Quote
Old 08-21-2016, 03:08 PM   #30
MaximeT
MaximeT's Avatar
Drives: GT86-ACE-JRZ-RPF1-Essex
Yes that's my concern. On the other end, HANS are supposed to help with helmet weight and head weight. (Not head weight only).
But head weight must be the most part.
But drivers survived some amazing crashes before HANS device too. (It's even better with HANS)
JRZ 12-32 | ACE 350 | Delicious Tuning | RPF1 | Essex Sprint | SPL | Powerflex | My Car
MaximeT is offline   Reply With Quote
Old 08-21-2016, 03:33 PM   #31
MaximeT
MaximeT's Avatar
Ok, I just found my answer.
It's possible to use Schroth ASM 4 point harness (with 5 and 6th point added).
You can add HANS at the track.
You can drive with no helmet and a road legal and safe 6 points harness. (torso mouvement and road legal harness release included)
Old 08-23-2016, 08:57 AM   #32
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
Sorry I missed this conversation over the weekend, but it seems like you guys have it pretty well figured out. This roll bar is designed (and recommended) to work with 6-point harnesses and no air bags, however we're also keeping in mind the likely use case and are designing it to be as safe as possible in an otherwise stock car. That means keeping the roll hoop as far as possible from the driver's head, etc.
Here's a picture of the almost stock car we're using to design this roll bar. We're using what we learned putting the cage in ours, but this car has a full interior, and we'll be keeping as much of that as possible.
Thanks for all the interest, it's very encouraging.
GSpeed is offline   Reply With Quote
Old 09-01-2016, 09:00 AM   #33
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
Main hoop is bent and placed, now we're finalizing rear brace location. The goal is to maximize space and minimize modifications to the interior. Seems like the vast majority of you would rather have the rear seats in place, even if they're not still useful. I know I would, just for aesthetic purposes.
Jake
Old 09-02-2016, 05:39 PM   #34
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
Landing plates are done, framing up the rear support bars. The tape shows where the harness bar will run, placing it that far back keeps the harness in the 0°-20° below horizontal range harness manufacturers recommend. That angle is especially important when using a HANS device.
We'll add the diagonal bar next. Once it's framed up, we'll be adding some bolted joints (machined interlocking joints, not a sleeve or anything like that) so that it can pack flat for shipping. It's not necessary to get the assembly in or out of the car, but the additional manufacturing costs will be negated by the reduced shipping cost. Shipping these things everywhere on a pallet via freight will get real expensive compared to a large cardboard box UPS can deliver.
Jake
Old 09-02-2016, 11:20 PM   #35
Brzzee
Brzzee's Avatar
Drives: 2015 Subaru BRZ WRBP Limited 6MT.
Jake
Street touring class requires a full interior so the SCCA rules set drive the requirement for me. Guessing other racing venues dictate full interior too.
Since I use the car on the street and carry the ocasional oversized item, I will need to keep the rear seat folded since the harness bar's location looks to block folding the seat's back to the horizontal. Perhaps the rear support tubes block the seat's movement too. Can't tell from the images. If this is the case then one must specify seat back up or down before the roll bar is installed.
Alternatively, the harness bar might be designed to be removed (i.e. Bolted where it connects to the support tubes and the tubes themselves do not also block) when not needed. If the HB is welded in place then some disassembly and partial removal of the roll bar would be needed to change the position of the seat back.
Like how closely the loop fits the b pillar and roof line. Craftsmanship on display!
Brzzee is offline   Reply With Quote
Old 09-03-2016, 09:11 AM   #36
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
This customer needs a full interior for Autocross classing as well.
It actually looks possible to remove the seat back with the bar in place. We'll confirm once it's done, but it looks like you'll be able to take the seat bottoms out, unbolt the bottom hinge (two bolts), then release the top latch and the seat back will slide out the bottom.
Jake
Old 09-03-2016, 02:09 PM   #37
Brzzee
Brzzee's Avatar
Jake
Sorry for any confusion. I'm "this customer", Tom.
Thanks for the clarification on reconfiguring the seat back.
Happy, Safe and Fast Fun Labor Day weekend.
Old 09-06-2016, 08:23 AM   #38
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
Ha, of course! Sorry Tom, hard to keep screen names and real names straight sometimes! Glad you're happy with the progress, then, since it's your car.
Jake
Old 09-06-2016, 09:21 AM   #39
Brzzee
Brzzee's Avatar
Just confirming we're using DOM at 0.120 for the prototype roll bar.
- When men make plans the gods laugh.
Old 09-06-2016, 09:58 AM   #40
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
Tom,
I show in my notes we talked about using 1.5x0.120" or 1.75x0.095" DOM. Based off our tooling, we decided to go with the 1.75" x 0.095" DOM tubing on this prototype bar, and the production bars.
Jake
Old 09-06-2016, 03:46 PM   #41
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
Update- yes, the rear seats can come out without removing the rollbar. Unbolt the bottom mount, undo the top latch, and they'll squeeze out the bottom.
Old 09-06-2016, 03:50 PM   #42
MaximeT
MaximeT's Avatar
I like it.
Do you think packaging for international shipping will be an issue ?
GSpeed Roll Cage Kit Development GSpeed Tracking / Autocross / HPDE / Drifting 66 07-14-2016 12:59 PM
Finally looks like there is a proper bolt-in roll bar solution! OkieSnuffBox Tracking / Autocross / HPDE / Drifting 47 08-23-2015 07:13 PM
FS: Battle Version BOLT IN roll bar/cage Fortunate Few Brakes, Suspension, Chassis 22 07-22-2014 02:35 PM
Bolt in Roll cages. Ludacrits Cosmetic Modification (Interior/Exterior/Lighting) 8 01-26-2014 06:19 PM
86/BRZ/FR-S Bolt In Roll Bar by Alex Pfeiffer-Battleversion 03Z33 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 61 01-28-2013 04:57 PM
