Old 07-27-2016, 01:29 PM   #29
infinity21
infinity21's Avatar
Drives: 2014 BRZ Sport-tech
You might have issues maxing out camber through the strut slots/bolts with 245/40/17 tires depending on how wide they run. I would recommend you get adjustable top hats to avoid rubbing.
infinity21 is offline   Reply With Quote
Old 07-27-2016, 01:47 PM   #30
Cybmx
Drives: 2016 Hyperblue Brz
That's the issue I'm facing. I have the velox top hat but I can only gain a little camber as more camber will put my end link rubbing the frame.
http://imgur.com/Ifwap48
http://imgur.com/KT8g5Li
I have the koni shocks insert and lowered about 1".
Cybmx is offline   Reply With Quote
Old 07-27-2016, 02:00 PM   #31
infinity21
infinity21's Avatar
I suppose fixing one problem creates another. I'm not sure what else you can do other than get coilovers with smaller spring perches
Maybe try the ground control system so you can trim down the spring perch?
http://www.ground-control-store.com/...ion.php/II=923
Old 07-27-2016, 03:10 PM   #32
ChrisSC300
Drives: 2014 SWP BRZ
What kind of camber were you at when it started to rub?
ChrisSC300 is offline   Reply With Quote
Old 07-27-2016, 06:57 PM   #33
Cybmx
I'll take some photos later. Haven't have the alignment done yet as I just put on the shocks. But from what I can see visually, it's not enough. I will know for sure next week, what exact number I have now
Old 07-27-2016, 10:01 PM   #34
Cartman
Cartman's Avatar
Drives: 10 Series Scion FR-S
Install the bottom crash bolt that the camber bolt replaced on top and push the hub in, The camber bolt + smaller crash bolt should give you up to -2.4 of camber, then add as much camber as you can from the top hats before it starts rubbing.
Cartman is offline   Reply With Quote
The Following User Says Thank You to Cartman For This Useful Post:
Cybmx (07-28-2016)
Old 01-29-2018, 10:39 AM   #35
VerusEric
VerusEric's Avatar
Drives: BRZ, STI, GT350R, Supra, 987.2
We run our shop car (factory shocks, RCE yellows) at around -2.8 of negative camber and do not run into this issue. Are you doing something odd with camber bolts as well to cause the rubbing?
We've had other guys with our kit maxing them out to -3+ and have not let us know of any rubbing either.
Thanks,
Eric
VerusEric is offline   Reply With Quote
The Following User Says Thank You to VerusEric For This Useful Post:
tehShirt (01-29-2018)
Old 01-29-2018, 11:09 AM   #36
Cybmx
Thanks,
Eric
I only rubbed at full lock at maxed out setting on camber plates. I solved the issue by not maxing out on the camber plates and use camber bolts in addition for more camber. Running around 3.2 now and no issues anymore.
The Following User Says Thank You to Cybmx For This Useful Post:
VerusEric (01-29-2018)
Old 05-08-2021, 07:18 PM   #37
bucketfoot
bucketfoot's Avatar
Drives: 2020 Toyota GT86
I wasn't sure if it was better to start a new thread or add on to this old one. So I figured I'd try this first.
I am a new owner of a 2020 86 and I will be doing moderate tracking 2-3 times a year (HPDE and possibly 86Cup in the future). I will not be installing coilovers or lowering springs, as the car needs to remain something that my wife will be happy to ride in!
I am most definitely on the cheap side, but I also budget my expenditures and am someone who would rather spend more money once and do things right the first time.
So with all of that said, given my experience with tire wear tracking my previous car, I have camber plates on my short list of items for the car. As I am not someone who runs a dozen track events a year along with the fact that I have an automatic I will never be competitive with the top 86Cup drivers. So while the Raceseng CasCam looks like what would be the best setup for someone who focuses more heavily on being competitive, the question I keep asking myself is does the extra $300 make sense for me.
Any insight from you guys would be greatly appreciated!
This post sent using 100% recycled electrons.
bucketfoot is offline   Reply With Quote
Old 05-09-2021, 02:36 AM   #38
jflogerzi
jflogerzi's Avatar
You might loose bump travel with camber plates. What number are you shooting for?
2013 Series 10 FRS #553
Old 05-09-2021, 10:26 AM   #39
bucketfoot
bucketfoot's Avatar
Not sure I'll need all of it, but I'd like to have at least -3 degrees available.
Old 05-10-2021, 11:21 AM   #40
Racecomp Engineering
Both are pretty darn good with coilovers, but with stock shocks, get the Velox plates.
You lose bump travel when using the Raceseng plates and their upper spring perch on stock shocks (not coilovers though..they are fantastic with coilovers).
- Andrew
The Following 2 Users Say Thank You to Racecomp Engineering For This Useful Post:
Bonburner (10-14-2021), ZDan (05-11-2021)
Old 05-10-2021, 06:04 PM   #41
RotARy15
Drives: 1993 Mazda RX-7 R1, 2025 BRZ tS
- Andrew
How bad is the loss of bump stroke? I'm installing Raceseng plates on Sachs dampers and stock springs this week and I plan on staying with those components for at least the fall track day season.
I thought I saw that someone measured a 1mm rise in ride height with the Raceseng plates but there was no mention of whether the upper spring perch and upper damper rod mounting point were independently relocated.
RotARy15 is offline   Reply With Quote
Old 05-10-2021, 06:15 PM   #42
jflogerzi
jflogerzi's Avatar
At the track for they will be fine. For daily driving expect some harsh or crashing feeling
FS (NY): Bilstein B16 (PSS 10) + Raceseng camber plates + Raceseng B16 spring perch dp1 Brakes, Suspension, Chassis 7 05-01-2016 11:28 PM
FS: Raceseng Cascam Camber Plates bombardius Brakes, Suspension, Chassis 0 04-12-2016 07:55 PM
FS: Raceseng Camber Plates (for KW/Tarmac coilovers) Sportsguy83 Brakes, Suspension, Chassis 2 01-21-2015 05:24 PM
HVT vs Raceseng Caster Camber Plates? Phaedrus29 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 40 12-22-2014 06:34 PM
F/S: Raceseng Front Camber Plates ExxelDistributions Brakes, Suspension, Chassis 6 10-25-2014 04:02 PM
