#29 |
Drives: 2005 Toyota Camry
If only CT200h center bore is larger than 54mm... the Lexus CT200h uses the exact same tire as the FRS/BRZ and the wheel specs are identical, except the center bore are 54.1mm to match 54mm hub diameter on the Lexus.
Ours is 56mm. -alex |
| Incoming Vehicles available at Scion of Kirkland | RogerCarr_TOK | Northwest | 14 | 08-04-2012 02:38 PM |
| bolt pattern is 5x100? | derka-derka | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 06-30-2012 03:58 AM |
| Natural Gas Vehicles and Sportscars | KaliKev | Other Vehicles & General Automotive Discussions | 11 | 04-28-2012 07:16 PM |
| Bolt Pattern, Wheel Hubs and Studs | Jeff Lange | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 29 | 03-08-2012 03:49 AM |
| The wheel bolt pattern is... | quik1987 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 193 | 02-29-2012 07:04 PM |
