Old 10-07-2018, 02:21 PM   #29
jflogerzi
jflogerzi's Avatar
Would a super charger ever overboost like a turbo could...
2013 Series 10 FRS #553
Old 10-08-2018, 01:21 AM   #30
Akari
Drives: 2013 DGM BRZ
Not in the same way, but there are scenarios where actual boost could exceed target boost.
For the Edelbrock that would likely only happen if the bypass valve wasn't functioning correctly, and I'm actually not sure if it's used to bleed off excess pressure at high Rpm or purely used when the throttle is closed. On centrifugal kits it's pretty common to run a small pully for more boost at lower rpm and bleed off the excess at high Rpm with a recirc or blow off valve, in which case overboost could be more than the tune/engine is set up for.
Akari is offline   Reply With Quote
Old 04-11-2019, 11:06 PM   #31
casing
Drives: stock
Did anyone with the edelbrock OFT tune dyno their car?
casing is offline   Reply With Quote
Old 01-18-2021, 06:44 AM   #32
Wil
Wil's Avatar
Drives: Drives like a crab.
Don't want to necropost but..
Is there some sort of OTS tunes available?
Wil is offline   Reply With Quote
Old 01-19-2021, 05:57 PM   #33
steve99
There is no free off the shelf tunes for forced induction. Oft guys do those by custom tune for cost.
I could supply you a starter tune or full tune for your SC send me a message
Old 01-24-2021, 08:51 PM   #34
Teseo
Drives: frs
I thought shiv ditched this platform
Old 02-25-2021, 04:16 AM   #35
pro_turbo
Drives:
Originally Posted by Shiv@Openflash View Post
Hi guys,
Just wanted to let you know that we are currently tune a customer's Edelbrock SC. It's a nice kit and we will be able to support it as early as next week. Our custom E-tuning will still be required for optimizing the performance on each car but our starting baseline map will be safe and will make the car perfectly drivable right off the bat
Cheers
Shiv
will you share the map pls
pro_turbo is offline   Reply With Quote
Old 02-25-2021, 08:13 PM   #36
Decep
Drives: 2013 FR-S Series 10
lol.
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers
Corsa Catback
Edelbrock Supercharger installed @ 50k
Old 02-28-2021, 11:52 PM   #37
pro_turbo
Drives:
Originally Posted by Decep View Post
lol.
what are you using for tune ?
Old 03-01-2021, 09:30 PM   #38
Decep
Local tuner used ECUtek. People don't give their tunes away, there's $$$ at stake
RCE SS-1 Coilovers
Corsa Catback
Delicious Tuning: Edelbrock E-Force Supercharger with Flex Fuel – Official Dyno Data DeliciousTuning Software Tuning 53 10-19-2018 11:55 AM
**EDELBROCK E-FORCE SUPERCHARGERS Available now!!** 86SPEED Forced Induction 8 03-28-2017 03:01 AM
MXP SP Exhaust and Edelbrock? JGalp Engine, Exhaust, Transmission 2 05-18-2016 09:44 AM
Edelbrock's Custom BRZ with SC Lonewolf Southern California 9 08-02-2015 05:17 PM
