Old 05-06-2025, 12:28 PM   #29
norcalpb
norcalpb's Avatar
Originally Posted by FrickingReallySlow View Post
Can pre-facelift FRS use a 2017-2020 HPFP? is it hard to replace to get rid of the chirp sounds
Yes the updated fuel pump can be used on the 2013-2020 cars.
Honestly, even though I was dreading the install, it wasn't that bad. Once you remove the intake manifold everything is right there in front of you.
I personally replaced the gasket(s) on the banjo bolt and the hard line itself going from the fuel pump to the direct injectors.
__________________________________________________ ________________________________
Part of my online order from "Devil Subaru Parts":
FUEL PUMP - 16625JB022 - $527.10 (The shop that diagnosed my car wanted $1,200 for the pre-revision pump, lmao)
INTAKE MANIFOLD GASKETS(S) - 14035AA610 - $15.33 x 2 = $30.66
THROTTLE BODY GASKET - 16175AA420 - $10.01 (You can leave the throttle body on the manifold if you drain your coolant)
FUEL PIPE GASKET - 17540AA340 - $3.91
HARDLINE - 17540AA340 - $37.56
Subaru fuel line disconnect tool for the quick disconnect line that connects to the intake manifold: $14
https://www.amazon.com/dp/B018SV6G5U...fed_asin_title
Lmk if you have any questions, very happy to help.
The Following User Says Thank You to norcalpb For This Useful Post:
FrickingReallySlow (07-24-2025)
Old 05-06-2025, 12:41 PM   #30
norcalpb
norcalpb's Avatar
Some helpful tips:
Pull the fuse for the fuel pump and try to start the car to get fuel out of the lines. As a second precaution let the car sit for a couple hours so the fuel can depressurize by going back into the gas tank. The high-pressure lines see thousands of PSI which can slice off a finger no problem so be careful. Put shop rags underneath the lines you are disconnecting to catch the fuel that drips out. Don't overtighten the 17mm lines. Prime the fuel pump before starting the car to check for leaks.
Solution Found: Rear Deck Rattle jdubz Issues | Warranty | Recalls / TSB 29 10-13-2019 03:48 PM
Solution Found: Rear Deck Rattle jdubz DIY (Do-It-Yourself) Guides 31 08-23-2015 06:08 PM
Has anyone found a solution to Kartboy shifter rattles and noises? oliverc Engine, Exhaust, Transmission 1 06-16-2015 07:25 PM
Randomly getting CEL w/ code P0193 YMAA Issues | Warranty | Recalls / TSB 18 07-31-2014 05:18 PM
