Old 04-29-2016, 06:19 PM   #29
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Generally speaking, you go with whoever is going to give you the best support locally.
I can't emphasize this enough.
Old 04-29-2016, 06:34 PM   #30
strat61caster
strat61caster's Avatar
Why is this the case? Are you referring to to the mass of the driver? I drive a rhd car.
Ooops, well yours would probably be heavy right side, I forget about other countries and my background is circle track (cars are built to be left heavy).
Hypothetically every car would be different, where the gas tank is located, steering rack, ecu, battery, air conditioning, they're all placed in order to package everything well with enough space and to balance the car. Generally as it's a road going vehicle, designers assume 2x, 4x, 6x passengers, but when you're setting up for racecar, unless you've got a navigator in the passenger seat, you'll be designing for driver only (and designing around no driver is foolish unless you've got an autopilot), an extra 100-250 lbs on the left (or right) is inevitable in production cars.
Most world cars are built the same though, your car probably comes out pretty close to the Vorshlag corner balance on page 1, steering wheel, rack, pedal box, brake booster, (battery on this car), a few things flip over, but all the major stuff remains the same, it's rarely a perfect mirror image.
I put foot in mouth in this thread.
ineedyourdiddly
Captain Snooze (04-29-2016)
Old 04-29-2016, 07:21 PM   #31
Traktor
Drives: Subaru BRZ Limited
When it comes down to the nitty gritty, I'm 100% certain Cootes knows far more than I do. Ultimately, I'm a driver, and while I can describe what I like and dislike about the behavior, and how I'd like for that to change, or even how I want a curve to look, I don't actually know how to change the shim stack to achieve that specific behavior.
However, most high end dampers all behave similarly, and that is, they keep the car planted. Lets see if I can convince CSG to pony up for a set of MCA dampers...
Haha, I meant to see if you could come to some sort of trial business arrangement!
Traktor is offline   Reply With Quote
Old 04-29-2016, 07:46 PM   #32
cjd
cjd's Avatar
Drives: 2017 BRZ
I'm going to guess it's just as important to have ongoing support; just getting product here to sell is a tiny part of the issue if it's not a "dispose when done" product.
Old 04-29-2016, 10:15 PM   #33
Ultramaroon
not playing cards
Ultramaroon's Avatar
I have not had my car corner weighted before. The dampers that are on my car now are off the shelf items.That is, all the coil overs of that model are the same. Received them, had them fitted, off I go. Awesome value for money.
The dampers I am thinking of are made to measure. I could, if I the experience, know how and money specify the damping curve I wanted.Their through shaft dampers start at $12k AUD a set. And no, through shaft dampers are not on the shopping list. As it is my proposed budget only allows for low speed compression damping adjustment which is why the more information I can supply the more accurately the dampers can be tailored for me/my car. I would be relying their expertise to fill in the blanks.
What dimensions/properties are customized?
Old 04-29-2016, 10:44 PM   #34
Captain Snooze
Drives: Red Herring
You tell them as much (or as little) as you can. Each damper set is made to order. So spring rates and damper curves are customised to the customer's requirements. For a person such as myself I would be relying on their expertise to give me a damper. I will discuss regressive damper curves with them just for a better understanding of damper design. I am in no position to request a particular curve.
What I thought was a little controversial was being told they do not offer 4-way dampers. Even their dampers for the V8 Supercar series are only 2-way adjustable. (There are only 3 sanctioned damper manufactures for the series: Sachs, Ohlins And Supashock.) They also don't use remote canisters.
Old 04-29-2016, 11:00 PM   #35
OkieSnuffBox
Drives: '23 BRZ Limited
If you aren't sure what to ask for, how is this crazy custom setup going to help vs one of the proven OTS options?
Old 04-29-2016, 11:11 PM   #36
Ultramaroon
not playing cards
I guess I'm still unclear as to exactly how they would use your corner weights.
Old 04-29-2016, 11:14 PM   #37
Ultramaroon
not playing cards
I think the value here is in learning what to consider given the options.
I'm curious.
Old 04-29-2016, 11:42 PM   #38
Captain Snooze
Drives: Red Herring
When I ordered the AST 5200 all I specified was spring rates and double digressive valving. The rest was left up to AST.
Just because I can't tune BRZEdit doesn't mean I don't appreciate the small increase in power.
I don't have to understand the workings to see a benefit. Having said that there is no guarantee at my level I would see a benefit. That remains to be seen.
Old 04-30-2016, 12:32 AM   #39
OkieSnuffBox
My point was more, if you don't know how to communicate what you're looking for, or know what you're looking for, I don't see the benefit.
This isn't meant as an attack, but if you can't figure out to put on the stock suspension or access other data to find stock Weight Distribution, can you really talk about hysteresis, where the "knee" is in the valving, etc.
In reality, amateurs like us that may be quicker than most guys at a track day, typically still don't have the skills/feel, testing, etc, to spec dampers. It becomes kind of a "street cred" thing on what you spent.
Old 04-30-2016, 01:07 AM   #40
They can make regressive dampers ala penskes?!???!???!?!?!?!?
Old 04-30-2016, 01:36 AM   #41
Captain Snooze
Drives: Red Herring
This was only mentioned in passing but they said yes, they can do that. I intend to quiz them some more about that when I chat to them next.
Old 04-30-2016, 01:40 AM   #42
You have my attention
Question About Negative Camber: More Negative Camber == More Grip at Corner? Figo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 38 03-10-2019 03:08 PM
Question - Black OEM Shift Knob Weight h8meh8ers Scion FR-S / Toyota 86 GT86 General Forum 3 06-22-2015 01:41 PM
Turn Signal / Corner Light DRL Question J_McElwee Scion FR-S / Toyota 86 GT86 General Forum 1 06-18-2015 12:25 PM
Weight Reduction vs. Weight Distribution (for track use not for drag..etc) glamcem Tracking / Autocross / HPDE / Drifting 21 07-01-2014 12:38 PM
A serious wheel question that goes beyond weight and appearance... boredom.is.me Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 29 06-28-2012 11:41 AM
