Old 07-13-2016, 08:56 PM   #29
mpross
mpross's Avatar
Drives: 2015 Scion FRS
Originally Posted by MeisterR View Post
That is what we have done with the ZetaCRD within reason.
Springs rate isn't out of this world.
Softer damper setting will have low cracking pressure as well as reasonable damping force leading to a compliant ride especially over uneven road surfaces
Stiffer damper setting will have increase cracking pressure as well as higher damping force leading to better steering and damping response.
Jerrick
I can confirm that this is the case with the ZetaCRDs. I've had them on my car for several months now, and on the road, with softer settings, the car feels almost like stock, just a bit sharper. At stiffer settings the car feels flat, responsive, and really sure footed. There's a little bit of body roll in the stiffer settings when cornering hard (autocrossing or track), but no more than what is needed to get aggressive street tires to work properly when driven hard, so to me that seems by design. With the damping set somewhere in the middle, it's noticeably firmer than stock, but still very suitable for daily driving and a fairly dramatic difference in steering response and control.
mpross is offline   Reply With Quote
FS: ST Suspension Coilovers stevohl Brakes, Suspension, Chassis 11 04-07-2015 04:37 PM
ST Suspension Coilovers for BRZ/FRS/86 Muller Performance Brakes, Suspension, Chassis 5 12-05-2013 04:19 PM
Air suspension or Coilovers? gdrider77 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 10-22-2013 09:13 PM
