Old 03-14-2016, 11:59 AM   #29
Dake
Dake's Avatar
It sounds like you have some track/AutoX experience already, so it may not be as big of a deal. But I'd recommend driving on the factory tires for a bit because they let you really learn the car; I think going straight to stickier tires means skipping over some of the finer points of handling (and they're perfectly capable tires for daily driving).
I drove the Michelins for almost two years. I found by the last few months I was very consistent on my times and got to the point where I was able to keep the car steady at the limits of traction. At that point I went up a wheel and width size (though still a high tread wear street tire), and was able to manage a good jump in times because it was a natural progression.
At any given AutoX, I am consistently Top-of-the-middle of the pack and I'm now ready to move to stickier, 200 TW tires. I'm confident I should be able to jump that regular two second gap into at least the bottom-of-the-top.
Most of the time doing a u turn on the the stock tires resulted in tire squeal which made it seem I was going faster than I really was.
That was my biggest complaint about the Michelins - a sure-fire way to get the cops to pull you over speeding or not is to let them hear a squeal, and those things made noise at the drop of a hat!
Dake is offline   Reply With Quote
Old 03-15-2016, 11:30 PM   #30
TheAsianRacer
TheAsianRacer's Avatar
Drives: Asphalt FRS
From stock tires to going to BFG rivals, I shaved off 7 seconds from going to the track once in one year. Tires is the best upgrade you can do as a first upgrade. I'll also add that the 2nd time at the track I had also added some racing pads on the front of the car. Those were my first upgrades but I've been to a few track hpde events over the past few years and am now in the intermediate/advanced run group in a relatively stock FRS if that helps anyone's opinion.
TheAsianRacer is offline   Reply With Quote
The Following User Says Thank You to TheAsianRacer For This Useful Post:
OUGrad05 (03-16-2016)
Old 03-16-2016, 07:43 PM   #31
D88
D88's Avatar
Drives: 2014 Scion FRS
I was almost going to say to drive your car through one winter in the snow and ice and you'll learn tons about how it handles in slick conditions but then I saw you live in Tulsa. That argument was opposing sticking with the stock summer tires to get a feel for the car's capabilities. So, in that case, I would agree with the general consensus that you should at least run the stock tires for a while before upgrading. You'll appreciate it more when you upgrade later.
D88 is offline   Reply With Quote
Old 03-17-2016, 12:28 PM   #32
Dake
Dake's Avatar
Tulsa gets snow and even more ice.
Old 03-17-2016, 01:56 PM   #33
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
I am a huge proponent of wearing out the primacy's and buying what you want next. Want a little more? S-04's or PSS. Want lots more? RS3, ZII, Rival, or RE71r.
I am really happy with 225/45 S-04's, and swift springs. It seems to be a well matched combo that stiffens just enough, gives just enough extra grip, but not so much I can't get some tail action on demand.
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
JazzleSAURUS is offline   Reply With Quote
Old 03-17-2016, 07:50 PM   #34
Keenercarguy
Mountain Runner
Keenercarguy's Avatar
Drives: 2013 Subaru BRZ Limited 6MT
Upgrading to a real dedicated performance street tire (like a pilot super sport) is the first thing I'd suggest doing after buying this car. I spent 5 months frowning on the stock primacy's, they're expensive and horrible. Get a better tire, any better tire, and you'll notice an obvious improvement. I didn't even really *notice* more body roll. I did, however, notice a much improved balance.
2013 BRZ 6MT Limited: "Quick as Hell, on a Budget" Build • Ceramic Coated Gruppe-S UEL/OP • Konig Hypergrams • RS4 200tw • Koni Yellows, Eibach Springs • Ferodo DS2500's
Keenercarguy is offline   Reply With Quote
bra difference from frs shift2launch BRZ First-Gen (2012+) — General Topics 5 01-22-2015 01:00 AM
Every difference between the MT and AT BlueDubbinTDI Engine, Exhaust, Transmission 38 09-04-2013 09:32 AM
Tires, PSS or S-04, is there a real difference? fip Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 07-24-2013 06:50 PM
Tires Make a Big Difference poudre Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 08-16-2012 10:58 PM
