Old 01-29-2016, 02:51 PM   #29
tskaohu
tskaohu's Avatar
Drives: 2015 Subaru BRZ Series.Blue CWS
Originally Posted by buruguduy View Post
I had the Flex Z for a few months now (thanks to CSG) and I am really happy I went with it. Even my wife is comfortable driving the car with it. Also with your budget, you will have enough to get some rear lca as well and still have some change.
And what would getting rear lca's benefit? I'm new to suspension sorry for the noob question.
1320 Performance Headers & Overpipe | HKS Hi-Power Spec-L Catback Exhaust | Delicious Tuning Flex Fuel Kit | Delicious Tuning Stage 2 Tune | Tein Flex A Coilovers | 20 & 25 MM Spacers
tskaohu is offline   Reply With Quote
Old 01-29-2016, 02:55 PM   #30
Ashikabi
Ashikabi's Avatar
Adjust rear camber
Old 01-29-2016, 02:58 PM   #31
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
Adjust rear camber
What @Ashikabi said. Rear struts are non camber adjustable for our cars. We need adjustable lower control arms if you want to adjust the rear camber.
Instagram: trevor.parque
Old 01-29-2016, 03:02 PM   #32
buruguduy
Drives: 2013 Scion FRS
you can get a rear adjustable lca so you can adjust your rear camber. My car is also a DD and is setup with Flex Z and SPC lca, just around $1k for both. Easy enough to install too, just get an alignment after.
EDIT: sorry for the late reply. But it is what @Ashikabi and @MisterSheep said.
buruguduy is offline   Reply With Quote
Old 01-29-2016, 03:14 PM   #33
Ashikabi
Ashikabi's Avatar
A tip: when buying suspension parts, always get adjustable even if you think you don't need it, cuz if you change your mind it's gonna be expensive
Old 01-29-2016, 03:35 PM   #34
tskaohu
tskaohu's Avatar
So would i be correct in assuming if you had lca's for the front then you would be able to add more camber than the camber plates on the coilovers provide?
Old 01-29-2016, 03:37 PM   #35
MisterSheep
Killed Scion
Camber bolts are a much more efficient way of getting that little extra bit of camber that you need. I wouldnt recomend lower control arms for the front as they aren't really needed.
Unless you trying to look like this...
Old 01-29-2016, 03:37 PM   #36
tskaohu
tskaohu's Avatar
naaa fam not that stance
Old 01-29-2016, 03:40 PM   #37
MisterSheep
Killed Scion
Then you'll be good.
Old 01-29-2016, 03:41 PM   #38
strat61caster
strat61caster's Avatar
Hypothetically yes, but to my knowledge nobody makes one and it would be more expensive than the other options (camber bolts and plates).
Edmunds had the car on a lift and made good pictures pointing out the components about 3.5 years ago, should help explain a lot when people start talking about changing suspension bits.
http://www.edmunds.com/car-reviews/t...alkaround.html
ineedyourdiddly
Old 01-29-2016, 03:53 PM   #39
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
Unless you want to go super low, I'd recommend against getting coilovers for daily driving. If I had to do it over again, I'd just get springs and Bilstein HD's. Every time you make height adjustment, you pretty much have to get an alignment done. Plus you have to worry about the threads getting messed up and possible corrosion issues. Not to mention the suspension geometry issues that come with lowering the front end too much. Just my two cents on the topic.
smg1138 is offline   Reply With Quote
Old 01-29-2016, 05:10 PM   #40
Mim
Mim's Avatar
Drives: MY11 Maxima 350st, MY15 BRZ
I've been researching a lot of suspension threads and have pretty much settled on Tein Flex Z's myself. I'll need to do a little extra research on this, but from my understanding you can go for a really minimal drop ie 20mm or so and also have a really nice ride for the street that's even more comfortable than the revised dampers used in the MY15+ cars.
Here is some propaganda on the product http://www.tein.com/products/flex_z.html
MY15 CWP A/T BRZ | Leather heated seats | STI CAI filter, A/T leather shifter, strut brace, V-brace, draw stiffener, battery tie down, Radiator cap, Oil cap, push start button | TRD door stabilizer | YoSpeed STI console garnish | Pioneer AVIC-F70DAB + Rev-camera, TS-WX710A sub | JL speakers, Amp | TOMS' Clear Brake Lights | Cusco 4.556 FD | Driveshaft Shop aluminum shaft | Tein FlexZ, EDFC AP+GPS | Crawford BPB
Mim is offline   Reply With Quote
Old 02-01-2016, 12:05 PM   #41
kch
Senior Misanthrope
kch's Avatar
It looks good nonetheless, and if i might ask are you running PSS 225's on the stock sti rims?
Sorry for delay. Yeah, I have PSS in 225 on the stock wheels.
Old 02-01-2016, 10:07 PM   #42
tskaohu
tskaohu's Avatar
225's make any noticeable difference over 215's? definetly want to go that route eventually
Recommended Car Ramps for the BRZ/FRS? mechaghost Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 49 09-01-2017 12:41 AM
Coilovers Coilovers, Coilovers: Tein, KW, BC, D2, Cusco, Eibach + more FREE SHIPPING! No Limit Motorsport Brakes, Suspension, Chassis 204 05-26-2017 12:09 PM
Recommended CAI and CBE ricanrolla Engine, Exhaust, Transmission 7 12-08-2014 06:51 PM
Any recommended detailers? Seabrz Northwest 5 10-25-2013 04:28 AM
E-85 NOT Recommended White64Goat Engine, Exhaust, Transmission 36 09-05-2012 01:53 PM
