#4173 | |
Drives: 2014 BRZ Limited (DGM)
I’ve looked everywhere that I can see without taking the bumper off... I haven’t found any evidence of a leak. No oil, residue, or areas where dust or dirt stuck. I’ll be getting under the car again next week to do an oil change and I’m going to closely inspect everything again, but every time I look everything is clean (except for normal road dirt) and dry. I know this is a weird oil and it will evaporate but I would imagine if I had I leak I would see some kind of evidence like residue or caked on dirt or something. It may evaporate but I doubt it’s magical stuff that turns completely invisible. Who knows, I’ve been wrong before. |
#4175 | |
Is there any possibility for an internal leak in the rotrex? Can you think of any place else I should be looking specifically? |
#4176 | |
The fluid does dry rather quickly. |
#4177 |
Famous Potatoes
Drives: '15 ultramarine
#4178 |
Drives: 2017 BRZ
Is anyone using the C38-71 instead of the C38-81? I've spent a good deal of time on the Rotrex compressor maps and am convinced the 71 would be the best for my goals (93 oct, hbp, ace 400, 7k rpm redline).
#4179 | |
pessimistic skeptic
Edit: I tested the stiffest yellow spring. There is less but still noticeable power gain at lower rpm over the blue spring. And, when I release the throttle suddenly during acceleration, I hear less amount of re-circulation sound. I will keep the yellow spring although it was marked for highest boost applications. Please let me know if you see any harm for engine doing so. Last edited by mrg666; 10-07-2017 at 07:01 PM. |
#4180 | |
| The Following User Says Thank You to CSG Mike For This Useful Post: | mrg666 (10-07-2017) |
#4181 | |
pessimistic skeptic
I think this is what you are pointing out. I am quoting from the Rotrex manual: "If you choose to position the throttle body downstream, a re-circulation valve is recommended. If the valve is omitted the supercharger will create noise under deceleration caused by surge. Surge occurs when the supercharger keeps making pressure at low airflow forcing the compressor to work outside the intended operation area. This will be most noticeable on high boost applications under high engine rpm with the throttle closed (deceleration). The re-circulation valve will prevent surge by allowing air to circulate from the pressure side of the supercharger to the inlet side of the supercharger under manifold vacuum conditions." The supercharger was making more noise under sudden deceleration with the stock valve. Last edited by mrg666; 10-07-2017 at 10:21 PM. |
#4182 |
Hmmm interesting.
Can you PM me links to everything you're using? I'm curious to try. |
#4183 |
pessimistic skeptic
#4184 |
Drives: 2013 Subaru BRZ Premium
Finally decided I'm going to pick this up with my year-end bonus and am starting to plan the build.
I'm massively OCD and completionist when it comes to buttoning things up whenever I do a mod so what have people been doing for supporting items (and brands for those items) with these? I'm planning on putting in a Cosworth long tube header when I put the kit in and expect there are going to be a lot of the usual culprits; stage 2 clutch, injectors, fuel pump, oil cooler, etc. Any particular Injectors/Pumps/Oil Coolers I should be looking at? |
#4185 | |
Not recommended unless you like regularly replacing melted fans. |
#4186 |
That bad even with the ceramic coating?
| Jackson Racing Rotrex Supercharger System Info and Discussion | Jackson Racing | Forced Induction | 827 | 04-06-2020 05:56 PM |
| Jackson Racing Supercharger Press Release and Info | CounterSpace Garage | Forced Induction | 110 | 01-03-2017 10:04 PM |
| jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! | CSG Mike | Forced Induction | 24 | 04-27-2016 01:59 PM |
| Jackson Racing supercharger | NoppyNop | Forced Induction | 241 | 06-26-2014 04:05 PM |
| Jackson Racing Supercharger Pre-Order Sale, $200 off! | Xero-Limit | Forced Induction | 2 | 03-05-2014 05:14 PM |
