Old 04-02-2014, 05:25 PM   #4103
raven1231
Hey Shiv has there been any update on the dual dump pack testing???
Old 04-02-2014, 08:55 PM   #4104
WRB5titch
Drives: WRBrz
Mine just hit customs!! Cannot Wait.
Go w0t or go home!!!!
Sent from my Nexus 7 using Tapatalk
EBSC - dt.FF - MXP CompRS
WRB5titch is offline   Reply With Quote
Old 04-02-2014, 10:20 PM   #4105
fenton
I have seen results but I won't post them without @shiv@vishnu s permission. I think everyone will be pleasantly surprised
Sent from my HTC One using Tapatalk
fenton is offline   Reply With Quote
Old 04-03-2014, 09:34 PM   #4106
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
In case any interested party hasn't seen the update on the power blocks + Phantom:
"Shiv:
Anyway, tested the BPB yesterday with both the Phantom and NA (full bolt on- OFH + Custom bat-back) set ups. With a tank full of 93oct. With the Phantom, it doesn't look like a good match. Lost power just about everywhere. It didn't look promising so I didn't bother with custom tuning with the BPBs. I will probably give it a try when more time permits though. But these results make sense as more airflow would suggest shortening the runners are the way to go."
Old 04-04-2014, 12:14 AM   #4107
nlowell
nlowell's Avatar
Drives: 2013 Scion FRS
"Shiv:
I was bummed but my wallet cheered for a moment....until I gave Vishnu money anyways for an eTune =)
nlowell is offline   Reply With Quote
Old 04-05-2014, 09:23 AM   #4108
WNDSRFR
Drives: FR-S,GTI
I have a couple questions.
I checked my manifold pressure today and sure enough I get 4 PSI max boost.
First question is: Are you guys saying that by adding the dual dump pack to a "stock" phantom setup, I can gain another PSI of boost? Or is that only with the larger compressor? 5 PSI would definitely be worth the price of a couple more batteries.
Second question is a bit more involved.
When I checked my manifold pressure 4 PSI was the max but 0 was the minimum. Is that possible? My VW varies between +15 PSI max to -20 PSI at idle. I thought that maybe the gauge wasn't working for vacuum but if you suck on the hose it does go negative. Am I doing something wrong here?
Old 04-05-2014, 11:37 AM   #4109
jpit
Drives: Subaru BRZ
I have the dual battery pack and I get about 1/2 psi more with it. Have seen 4.5 psi but never 5.
jpit is offline   Reply With Quote
Old 04-05-2014, 12:37 PM   #4110
nlowell
nlowell's Avatar
Full throttle Electric Supercharger Build Thread
The dual setup requires some new hardware from Rob (I believe) that he is still finalizing testing on. Otherwise I'd be dual right now
Old 04-05-2014, 12:59 PM   #4111
jpit
Drives: Subaru BRZ
You need a new harness but the controller is fine. Relocating the starter battery is the only real problem.
Old 04-05-2014, 01:33 PM   #4112
nlowell
nlowell's Avatar
I just finished my first hpde session with the phantom. I pointed my gopro at the gauge so I can review how It held up later. One question - after coming back in from the session I noticed it's sitting at 26.6 and doesn't seem to be charging back to 28s. Bad battery?
Old 04-05-2014, 01:34 PM   #4113
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Originally Posted by nlowell View Post
I just finished my first hpde session with the phantom. I pointed my gopro at the gauge so I review how It held up later. One question - after coming back in from the session I noticed it's sitting at 26.6 and doesn't seem to be charging back to 28s. Bad battery?
When I had a bad battery the voltage went higher not lower. Give it a bit and see if it recharges.
Installed Mods:
Old 04-05-2014, 01:47 PM   #4114
WRB5titch
Drives: WRBrz
INSTALLL TIMEEE
@shiv@vishnu I sent you my original rom. So please get back to me when you find some free time, albeit it is Saturday and I understand it's your day off
Old 04-05-2014, 03:27 PM   #4115
Thatruth2001
Drives: Raven FR-S
No the battery is not bad you hit the heat limit of the controller and it is in partial boost mode. Hence back up off the boost. Also remove the rubber lining that is connected to the hood to allow better airflow to keep the control unit cooler.
Thatruth2001 is offline   Reply With Quote
Old 04-05-2014, 03:45 PM   #4116
WRB5titch
Drives: WRBrz
Hey guys so I'm trying to install the fuse for the auto on off and this is as far as the fuse will go into the box.... Am I just not pushing it in hard enough lol
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
