Old 03-06-2016, 06:08 PM   #4061
Locust
Custom User Title
Locust's Avatar
Drives: 2015 Scion FR-S, 2012 OB Evo X MR
Send a message via AIM to Locust
Originally Posted by edj View Post
1) 2 ft SCION decal on the front of the car ( on the hood)
2) Scion Racing decals, 1 on each side of the car
3) TRD decals, 1 on each side of the car
Thank you. That makes a lot more sense than two Scion Racing decals on each side.
LOCUST
2015 FR-S (STX) and 2012 Evo X MR
Instagram:
LocustAutoX
Sponsors:
DSGPerformance Drift Office Evil Apex Racing
Locust is offline   Reply With Quote
Old 03-07-2016, 02:53 AM   #4062
ButteR
Originally Posted by Gen3MR2 View Post
February 2016 Fastrack
Page 2
#18376 Koni struts for twins
http://cdn.growassets.net/user_files...pdf?1453302259
I contacted Koni and they said they are sending out the spacer washers and instructions to get it to the correct spec.
Just got back into autocrossing after recovering from an injury for the past 7 months, felt great to get back into it.
Seems like a lot of good stuff has happened in c street since ive bden gone. The new Mx-5, the Koni camber mystery solved (bye bye to my -2 camber hehe). Have they allowed brzs to run with TRD sway bars and springs yet?
Anything else that's happened over the lat 7 months?
ButteR is offline   Reply With Quote
Old 03-08-2016, 12:48 AM   #4063
markw
Drives: 2014 FR-S
Just call Koni and order your washers, they're no cost to you. The ND is beatable, I've done it twice now, both times in the rain. I'll be bringing a water truck to the events from now on. BRZ with TRD parts will always be an STX car. You need to show up to events so we can have a decent sized class. Only 9 cars in class yesterday because of the rain. Which is fine with me as points are points, and the only way to win the season is to be consistent. There's only 1 ND in the region to worry about, Jeff C is going STR with his.
markw is offline   Reply With Quote
Old 03-08-2016, 10:00 AM   #4064
ryan t
Drives: frs
is there a different effect on the car between the offsets of the kosei and rpf1 42 and 50? i was wondering if the 8mm made a change in scrub radius or leverage on the suspension. or is the rpf1 wider track width is better the rule? i am about to order wheels and cant decide which to get.
ryan t is offline   Reply With Quote
Old 03-08-2016, 10:24 AM   #4065
YawMomentRacing
YawMomentRacing's Avatar
Drives: 2013 Red 6MT Scion FR-S
I use the Kosei K4Rs b/c of the +50 offset. A wheel spacer effecitively reduces wheel offset so the Kosei gives you the ability to tune track (balance) width with wheel spacers. The Enkei is close to the "max width" which is legal for C-street based on the +/- stock offset rule.
Dave Ogburn | Yaw Moment Racing
2013 Scion FR-S - C-Street
http://yawmomentracing.blogspot.com/
YouTube Channel
YawMomentRacing is offline   Reply With Quote
Old 03-08-2016, 10:33 AM   #4066
chucky12012
Drives: 2013 Asphalt Scion FR-S
I have the Kosei's too, and with long studs you can play with spacers on them. Plus, they are cheaper than the Enkei's and a tiny bit lighter. If you don't have longer studs, I'm not sure you would want to run the 8mm spacers though.
chucky12012 is offline   Reply With Quote
Old 03-08-2016, 10:54 AM   #4067
ryan t
Drives: frs
this is exactly what i was thinking of doing. i used to race on dirt and we used different offsets the change balance. i just dont know if dirt changes equates to asphalt, example...on dirt a wider front track made the car understeer. is this the same for our car in autox?
Old 03-08-2016, 11:01 AM   #4068
YawMomentRacing
I found that adding a front spacer while keeping the rear narrow made the car looser and more responsive on turn in.
Sent from my XT1254 using Tapatalk
YouTube Channel
Old 03-08-2016, 11:27 AM   #4069
ryan t
Drives: frs
I was thinking dirt and pavement are completely opposite to each other in car setups. At least thats what ive been finding so far. Thanks
Old 03-08-2016, 08:32 PM   #4070
RMP
Drives: 1992 Isuzu PuP, 2014 FR-S
I'm also running the Kosei's and have a set of 3mm and 5mm spacers since I could not find one off the shelf at 8mm.
Do you stack spacers to fine tune widths? I'm wondering if there are any safety and reliability issues for competition use only.
RMP is offline   Reply With Quote
Old 03-08-2016, 08:35 PM   #4071
AlanLGuy
Drives: Raven 6 speed Manual FRS
Originally Posted by RMP View Post
Do you stack spacers to fine tune widths? I'm wondering if there are any drawbacks to this for competition use.
I had the same thought today. Realized I ordered 12mm spacers which is way too much to be legal with my +50 wheels, so I looked today and closest I could find that was still legal was 5mm spacers. Found some 3mm as well but was hesitant on stacking them to get to 8mm....
2013 6-Speed Raven Black Scion FRS - Unmolested, for now
2000 Celica GT-S - "Frankenstein" CAI, Boosted2.0 Ported Header, TRD Exhaust, ES Motor Mount Inserts, ES Suspension Bushings, Southbend TZ clutch, Fidanza Flywheel.
AlanLGuy is offline   Reply With Quote
Old 03-08-2016, 09:08 PM   #4072
bslate3
Drives: 2015 CWP BRZ
I got some custom made 9mm hub centric spacers, I have the Kosei wheels. My BRZ needs all the extra oversteer/rotation it can get. I'm going to try them out this weekend to see if it will add enough rotation to justify running a larger front sway bar.
bslate3 is offline   Reply With Quote
Old 03-09-2016, 09:20 AM   #4073
DylanFRS
Lost in Kansas
DylanFRS's Avatar
Drives: 2013 Scion FRS (Raven)
Are you running stock studs?
Where did you order them from?
DylanFRS is offline   Reply With Quote
Old 03-09-2016, 09:21 AM   #4074
chucky12012
I had found some 8mm spacers from Evasive. They are more generic for multiple bolt patterns, but do the job.
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 05:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 12:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 01:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
