Old 03-28-2014, 01:15 PM   #4047
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
Originally Posted by FrsDuke View Post
It's definitely not the deep base most people love, but I wouldn't call it tinny with the track pipe like it was with the stock axle back. I dunno how the catted nameless combo pipe would affect it, but I love it right now. I work out at COTA on Sunday and I'll get a little tunnel vid.
edit: driveway video
https://www.facebook.com/photo.php?v=10203610419689099&l=126049337237410730 7
This actually sounds pretty damn good! I might have to swap back to the stock op/fp, as I've been fighting a horrible tinny resonance for the past week anytime I push up past about 4200 rpm.
Decay107 is offline   Reply With Quote
Old 03-28-2014, 01:25 PM   #4048
FrsDuke
Fanboy
FrsDuke's Avatar
Drives: 2013 ultramarine frs
I definitely dig it. To me it has an almost Italian pitch to the sound rather than a typical Japanese 4banger sound. I am a bit biased, however. I have to say that I'm surprised how the video sounds like the car actually sounds. At least when I listen to it on my home theater setup. Best part is my exhaust setup was under $1250 including grimmspeed gasket set, header, trackpipe, shipping and my free labor.
I'm done helping those who won't help themselves.
TL;DR:
-Duke
FrsDuke is offline   Reply With Quote
Old 03-28-2014, 10:11 PM   #4049
toeout
Installed mine today. I was checking for exhaust leaks under the car with my girlfriend revving it. I noticed condensation water shooting out from between the header and the overpipe. It stopped in less than a minute as the header heated up.
Would that indicate an exhaust leak? I couldn't really hear any additional noise while being directly under it.
toeout is offline   Reply With Quote
Old 03-28-2014, 10:48 PM   #4050
FrsDuke
Fanboy
FrsDuke's Avatar
That is absolutely, without any doubt, no question, an exhaust leak. I resolved the same leak by using their gasket plus a grimmspeed gasket. Could reuse the old one to try to do the same. I put the nameless gasket on the header side and the gs gasket on the op side.
TL;DR:
-Duke
Old 03-28-2014, 10:56 PM   #4051
toeout
I'll try the factory gasket + the NP gasket tomorrow. Thanks!
Old 03-29-2014, 01:07 AM   #4052
dradernh
Drives: Used to Drive:Grand-Am GS #54 E36M3
Ceramic Coating
Long thread, so I don't know if it's been mentioned already, but I've used Swaintech's White Lightning for underhood heat reduction on NA, FI, street, and race cars. Best product I've found; massive drop in underhood temps. Details here, definitely low-bling factor although you can always paint it, no affiliation: http://swaintech.com/race-coatings/r...aust-coatings/
Some discussion of it here: http://www.ft86club.com/forums/showthread.php?t=45776
dradernh is offline   Reply With Quote
Old 03-29-2014, 09:09 AM   #4053
Captain Insano
I've used that stuff before. I agree, it's the best heat coat I've encountered.
Old 03-29-2014, 11:36 AM   #4054
RiskyTrousers
RiskyTrousers's Avatar
Drives: '87 Corolla GTS, '13 FR-S 6MT
Any drawbacks to double stacking the gaskets like that?
RiskyTrousers is offline   Reply With Quote
Old 03-29-2014, 03:28 PM   #4055
Decay107
Decay107's Avatar
Nope, I ran double oem gaskets on my nameless front pipe for about a year (including a few track days) because I had an exhaust leak on initial install.
Old 03-29-2014, 05:27 PM   #4056
Calum
That Guy
Drives: 2013 asphalt FRS MT
Yes, there's a much better chance of a leak. That said, the chance is probably still remote.
Old 03-29-2014, 05:36 PM   #4057
toeout
Well I tried the OE + NP gasket with no luck. Grimmspeeds are next.
Old 03-29-2014, 07:06 PM   #4058
Decay107
Decay107's Avatar
You might want to try loosening everything up (all exhaust connections) then re-tighten them starting from the header and moving back. That has worked for me on a few occasions where I had leaks.
Old 03-29-2014, 07:29 PM   #4059
toeout
I had the front pipe loose from the transmission and the up pipe mated the header very easily. It seems that when I tighten them together, the middle of the up pipe bows out. The condensation was also shooting out from the middle.
Old 03-29-2014, 08:43 PM   #4060
Carlitoz3
Carlitoz3's Avatar
Drives: 2013 MT Asphalt FRS
How are you guys taking off the 02 sensor plugs?
Carlitoz3 is offline   Reply With Quote
21 months no dyno, 22 months no vendor dyno, 22months4rattles&leakssmh, amazing warped qualiy, y u no tag
Nameless Performance BRZ Axleback Exhaust ESBjiujitsu Engine, Exhaust, Transmission 1377 04-21-2020 02:23 AM
Nameless Performance Axleback is available for pre-order. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 114 07-23-2012 10:38 PM
Nameless Performance Downpipe is available for pre-order. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 4 07-12-2012 04:57 PM
We are Nameless Performance. John@Nameless Announcements, Contests, Giveaways 22 06-18-2012 11:32 PM
Nameless Performance is here. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 16 06-06-2012 04:32 AM
