Old 08-20-2015, 04:13 AM   #393
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
Originally Posted by jiaim View Post
APR has a tvs 1740 now vs the 1320.
Hmm, didn't know they changed it, either way they did us the 1320 for years in that application.
Decay107 is offline   Reply With Quote
The Following User Says Thank You to Decay107 For This Useful Post:
CSG Mike (08-20-2015)
Old 08-20-2015, 11:07 AM   #394
funwheeldrive
I know it varies from shop to shop, but is there a ballpark number on how much it would cost to install this kit?
Old 08-20-2015, 11:16 AM   #395
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Hard to tell, specially since the install instructions have not been published yet, but based on the parts shown on their pics, I would guesstimate about a 6-8 hr job with a competent shop. Factor in your shop's rates, and you got you price
The Following User Says Thank You to BigFatFlip For This Useful Post:
funwheeldrive (08-20-2015)
Old 08-20-2015, 11:53 AM   #396
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Originally Posted by CounterSpace Garage View Post
Based on our past discussions/meetings with Edelbrock, the Tuner 1556 is the CARB exempt kit. The website is a little fuzzy on that information, but the setup is exactly like the Jackson Racing kit setup (FTS vs. TIY).
So the 1556 doesn't come with any Ecutek license, cable or tune correct?
JoeBoxer is offline   Reply With Quote
Old 08-20-2015, 12:29 PM   #397
350matt
Drives: toyota mr2/ Toyota GT86
So $4550 for the kit + $1000 for a tune inc license?
does this kit need any other addenda ?
For example with the sprintex you need to really purchase the intercooler kit + better MAP sensor + the IAT sensor mod / relocation kit
350matt is offline   Reply With Quote
The Following User Says Thank You to 350matt For This Useful Post:
Freeman (08-20-2015)
Old 08-20-2015, 12:39 PM   #398
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
Is there a way to properly monitor post intercooler temps on this kit?
Freeman is offline   Reply With Quote
Old 08-20-2015, 12:48 PM   #399
Jaden
Road-hole
Drives: 2013 Whiteout FR-S
no it comes with all of the above is my understanding...
The 1556 should come with everything you need.
the 15560 is the tuner kit that wouldn't have the ecutek or tune, although from what I understand the CARB tune will still be downloadable from their website.
Jaden
Jaden is offline   Reply With Quote
Old 08-20-2015, 01:34 PM   #400
j123ic
Drives: Evo 9
1556 comes with everything needed to get the vehicle running. The kit includes a 2 bar Bosch TMAP sensor. Same sensor used on the current C7 z06 Corvette. This sensor is used to monitor both boost and post charge temps. So you do not need 2 separate sensors like other kits.
There is an included plug and play harness that relocates the IAT signal from the MAF to the the TMAP sensor. Not cutting, splicing, or soldering needed.
Note: the harness and sensor are also included in the 15560
j123ic is offline   Reply With Quote
The Following 9 Users Say Thank You to j123ic For This Useful Post:
Bach415 (08-21-2015), BigFatFlip (08-20-2015), civicdrivr (08-20-2015), CSG Mike (08-20-2015), Freeman (08-20-2015), itsibarra (08-20-2015), JS + BRZ (08-20-2015), LucidMomentum (08-20-2015), sato (08-20-2015)
Old 08-20-2015, 01:46 PM   #401
Freeman
Freeman's Avatar
Note: this harness is also included in the 15560
Awesome, thank you
Old 08-20-2015, 02:13 PM   #402
DelayedBRZ
Drives: GBS BRZ, Auto Limited
Ordered!
Been waiting to pull the trigger on a supercharger for the last 6 Months. Almost pulled the trigger on the Cossie, but hesitated due to CARB. At one time I wouldn't have cared, but I guess I am getting more responsible as I age. The output is more than my needs, the CARB cert, and the amazing price for performance. Definitely hitting on all cyclinders. I finally get to join the long list of Counter Space Garage customers. Thanks Mike!
DelayedBRZ is offline   Reply With Quote
The Following User Says Thank You to DelayedBRZ For This Useful Post:
Old 08-20-2015, 02:24 PM   #403
1556 is with the tuner; 15560 is without.
MSRPs are $5399.87 for 1556, and $4649.87 for 15560.
DelayedBRZ (08-20-2015), JoeBoxer (08-20-2015)
Old 08-20-2015, 02:53 PM   #404
sato
sato's Avatar
Drives: Dodge Patitas
Mike, plan you next vacation to head to the Caribbean. I'm offering my services as a tour guide for free. Bring on of those kits with you :p
Sent from my A1P using Tapatalk
The Following 2 Users Say Thank You to sato For This Useful Post:
CSG Mike (08-20-2015), LucidMomentum (08-21-2015)
Old 08-20-2015, 08:39 PM   #405
djdnz
1337
Drives: 2013 BRZ WRB S/C
Hey Mike, do we know if any oil coolers are compatible with the Edelbrock heat exchanger setup in the front bumper?
djdnz is offline   Reply With Quote
The Following User Says Thank You to djdnz For This Useful Post:
sato (08-20-2015)
Old 08-20-2015, 08:50 PM   #406
BigFatFlip
BigFatFlip's Avatar
There's been mention that their test car had a Perrin oil cooler, which makes sense since it mounts up on the lower plastic piece and most likely clears the heat exchanger. I'd be interested to hear if other top mounted oil coolers would work. Edelbrock also has a sister company Russell performance that specializes on lines, AN fittings, etc. so I wouldn't be surprised if they came up with their own oil cooler kit.
boost, byebye jackson racing, e-force, edelbrock, forced induction, supercharger
Trunk needs a bit of force to close..... Hachiroku14 Issues | Warranty | Recalls / TSB 30 06-19-2018 06:09 PM
X-Force 3" Exhaust mwjcyber Engine, Exhaust, Transmission 19 03-13-2017 02:55 PM
The force is strong with this one (2015 STi) blackhawkdown FR-S / BRZ vs.... 39 08-01-2014 01:26 AM
X force or Invidia N1 JakeG AUSTRALIA 8 01-18-2014 05:16 AM
G-force meter mikepaul21 Cosmetic Modification (Interior/Exterior/Lighting) 2 03-17-2013 02:24 PM
