Old 06-28-2015, 11:20 PM   #393
steve99
Originally Posted by Jaden View Post
I've tried both A01D and B01D... Because it's an OFT rom type I'm not sure which is right because they use a different base rom.
The base file I'm using doesn't tell me either because it's a modded one to go with the OFT specific roms which are named based on the name of the rom file you use, which is A01D in my case but isn't necessarily that type.
JAden
Your living dangereously. my friend
oft v2x tunes for D series roms are usually based on B01D except for D00D which is D00D
v1x tunes based on A01D from memory
you rearly need to confirm with hex editor so you use correct ecuflash definition
their are three instances of calid in rom all three should be same in unadjusted rom
in oft rom the first two arround 8000 and 10000 may be altered the third calid arround 13000i s the real calid
Old 06-29-2015, 01:15 AM   #394
Jaden
Road-hole
Drives: 2013 Whiteout FR-S
I'm not
I'm just talking about the logcfg...I was very careful in ensuring I had the right match for the bin before flashing it. In fact I had created a thread telling people what to look for when bringing up the bins to verify that it's accurate.
Jaden
Jaden is offline   Reply With Quote
Old 06-29-2015, 01:36 AM   #395
steve99
I'm just talking about the logcfg...I was very careful in ensuring I had the right match for the bin when flashed it. In fact I had created a thread telling people what to look for when bringing up the bins to verify that it's accurate.
Jaden
Ok thats great :-)
post your log up to datazap.me and post the link make sure you make it public.
you might have to check the logcfg.txt against the ram address lost for your rom type.
i cannot check the ram addresses as i am on G rom, if it looks like their no good then you will have to ask the romraider dissassembly guys eg td-d or maybe the tactrix guys to have a look.
Jaden (06-29-2015)
Old 06-29-2015, 11:32 AM   #396
Jaden
Road-hole
Here is my log...
Here is one of my logs and I'll attach the logcfg file I'm using.
Jaden
http://datazap.me/u/jaden/log-1435591610?log=0&data=9
I did verify the addresses based on what has been put out there for the B01D...
Old 06-29-2015, 04:23 PM   #397
steve99
Jaden
remove the trigger lines they never seem to work well, it will just log any time its plugged in then.
conditionrpn = RPM,0,>
action = start
conditionrpn = RPM,0,==
action = stop
Old 06-29-2015, 04:59 PM   #398
phrosty
action = start
action = stop
Indeed. Be careful of these. I left the car alone for a weekend and came back to a huge log of a car that was off, and a dead battery. I always unplug it when not in use now.
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
phrosty is offline   Reply With Quote
Old 06-29-2015, 06:05 PM   #399
Ultramaroon
not playing cards
Ultramaroon's Avatar
action = start
action = stop
The defrost button works for me. Yeah, yeah... timeout.
Old 07-13-2015, 12:52 AM   #400
steve99
@NotSoJDM
reply to your PM
see first post in this thread for compatability
most of the newer stock roms their
cars that came with A01C are compatable with B01C rom and your better off using that as its a later rom with some extra factory updates for idle stability ect
see below for older ones
NotSoJDM (07-13-2015)
Old 07-20-2015, 07:12 PM   #401
steve99
ZA1JE00I stock rom added to first post
2015 Auto trans for Australia/Europe/South Africa
Old 07-28-2015, 06:50 PM   #402
Kodename47
Kodename47's Avatar
Drives: UK GT86
ZA1JA01G/ZA1JA02G files.I've just been loojking into someone's tune and I've noticed something. I have the 3 MAP sensor scales in my definition:
Code:
<table name="Manifold Pressure Sensor Scaling A" storageaddress="1000CC" />
<table name="Manifold Pressure Sensor Scaling B" storageaddress="1000E4" />
<table name="Manifold Pressure Sensor Scaling C" storageaddress="11CC20" />
However upon comparing in ECUtek I have A correlating with the Atmospheric pressure sensor values. This may be worth confirming. It would also explain the extra values over the US ROMs as they don't have a atmospheric sensor.
@ztan @Td-d
.: Stealth 86 :.
Kodename 47 DJ:
Old 07-29-2015, 06:17 AM   #403
ztan
Drives: Toyota 86
Code:
@ztan @Td-d
When I put in my 3Bar sensor, I changed MAP scaling A,B, and C to all read the same and the altered scaling has not affected my ambient pressure readings at FFF8D290.
The value that 1000CC scales is stored in FFF87C80 - I have not logged this to see what it is yet.
ztan is offline   Reply With Quote
The Following 2 Users Say Thank You to ztan For This Useful Post:
aagun (07-29-2015), Kodename47 (07-29-2015)
Old 07-29-2015, 06:25 AM   #404
Kodename47
Kodename47's Avatar
Drives: UK GT86
I'm currently seeing what happens with just B and C changed. It's also a turbo setup. I had initially set all 3 the same which is how I noticed the above. ECUtek also only has 1 MAP scaling table which ties in with C.
.: Stealth 86 :.
Kodename 47 DJ:
Old 07-31-2015, 07:05 PM   #405
ztan
Drives: Toyota 86
Code:
Scaling C is definitely the MAP sensor.
I can't find where Scaling B is used yet, I can't find references in it to the ROM yet.
Scaling A is another sensor, I don't know which.
The 16 bit value is stored in FFF87CBC, after scaling sits in FFF87C80. I logged this just now engine off and got a steady 0V (=-20 kPa using stock pressure sensor scale and 3kPa if using 3Bar pressure sensor scale). I think it is unlikely this relates to ambient pressure - anyone want to log and see what this one is? These RAM addresses should be the same between A01G and A00C/A01C.
The Following User Says Thank You to ztan For This Useful Post:
Kodename47 (08-01-2015)
Old 09-16-2015, 04:22 PM   #406
Kodename47
Kodename47's Avatar
Drives: UK GT86
Here's a new ROM: ZA1JF10G - EUDM 2015
.: Stealth 86 :.
Kodename 47 DJ:
ecuflash, tactrix, taxtrix, tuning
ECUFlash - Getting close! xjohnx Software Tuning 698 03-22-2015 12:10 PM
EcuTek Flash finished but now it shows only a Partial Flash... Cross Software Tuning 32 02-12-2014 10:55 AM
Tactrix Openport jamesm Engine, Exhaust, Bolt-Ons 1 01-28-2014 08:27 PM
Visconti Tuning - Latest BRZ Flash Info Visconti Software Tuning 6530 12-24-2013 10:18 PM
Overboost Protection With OFT/EcuFlash? FrX Software Tuning 9 10-23-2013 07:27 AM
