Old 10-20-2013, 07:29 PM   #393
brad fischer
Drives: 2013 BRZ Premium Blue Manual
This thread is almost identical to a thread on the Genesis Coupe forums regarding bad syncros and poor cold shifting. Similar Aisin tranny similar issues, similar remedies, Pentosin, Redline MTL , Redline D4ATF. Pentosin was chosen as the factory fix for the tranny problems, but some dealers installed other oils noted above and even their own brand ATF. Also a lot of trannys swapped out by dealers.
I just read the whole thread here and wonder why you guys don't get the dealers or factory to come up with a fix even if it is as simple as having a dealer flush and fill the tranny with a better oil? My 2010 Genesis Coupe acts similar to my wife's BRZ. Difficult cold shifts, mainly second gear. My Gen has improved a bit as its had more miles on it in the last 4 years. I kept the factory fill as I have not driven it in the winter. I expect the same from our BRZ, but my wife is going to drive the BRZ all year so I am wondering what to do about the bad 1-2 shift when cold.
I mentioned the problem to my service department a week ago, car is 3 weeks old with 1500 km on it now. I think I will go back and start a paper trail on this issue just to be safe. Have not had any driving below 40f so not sure how bad it will be at 0f - 20f (common Toronto winter temps)
brad fischer is offline   Reply With Quote
Old 10-28-2013, 09:41 PM   #394
Ozzman
Drives: old
Is there any downside to running a slightly thinner GL4 vs the factory fill 75w90? I have access to BG products at work and the BG syncroshift 2 is 75w80. And does anyone have experience running BG syncroshift in the toyobaru?
Just found this tech doc on the Synchroshift 2.
http://kansasbg.com/Complete_Set_of_...h/792_SPEC.pdf
Ozzman is offline   Reply With Quote
Old 10-28-2013, 10:11 PM   #395
White64Goat
I just shift 1-3 when it's cold and that solves the problem for me.
Old 11-03-2013, 10:37 PM   #396
frslee
Just drive it
Drives: 13' FR-S
Redline MTL works great in cold shifting
frslee is offline   Reply With Quote
Old 01-24-2014, 02:25 AM   #397
FLYFISHR
FLYFISHR's Avatar
Drives: 2014 BR"ZED" Sport-tech DGM MT
Originally Posted by OICU812 View Post
Ok I think I found someone up here that has the oil.
To clarify for tranny and diff oil
Transmission: Redline MTL GL4 70W80
Rear Differential:
Motul Gear 300 GL4/GL5 75W90
These are the exact lubricants being discussed correct? No other additives or such for the motul for rear diff required?
who did you find north of the 49th to buy from?
thanks
Old enough to know better but young enough to do it again
FLYFISHR is offline   Reply With Quote
Old 01-24-2014, 03:21 AM   #398
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
thanks
Guy out of Toronto actually, I'll look back see if can find it again for you, if you don't hear from me in a few days PM me to remind me and see where its at.
Old 03-15-2014, 06:49 PM   #399
SpeedyJay
SpeedyJay's Avatar
Drives: '13 WRB BRZ
I just finished changing out my Trans fluid to MTF2, initial impressions are very good. Definitely smoother shifting in all gears and my second gear 'notch' is gone. Very pleased with this. I'll do an up date later after a I try a cold down shift into second gear.
side note I've tried Redline in my other cars and wasn't really impressed
In God We Trust - Hold No Faith That Violates Reason
SpeedyJay is offline   Reply With Quote
Old 03-15-2014, 08:03 PM   #400
roddy
roddy's Avatar
Drives: '13 Ultramarine
It will continue to get better over the next few hundred KMs or so. I have enough MTF2 here for another fluid change and plan to do it soon. I'm just waiting on some back ordered 75W85 gear oil for the rear end so I can do them both at the same time. I'm looking forward to getting some Pentosin back in the trans. The Redline I've been using is better than stock, but not as good as the MTF2.
Old 05-06-2014, 08:08 PM   #401
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
I haven't been on this subforum much but is this still a well regarded fluid for trans?
I have it in my car now, just wanted to know if anyone found out anything negative before I buy 5 liters of it.
Join the Galaxy Blue Silica BRZ registry below:
https://docs.google.com/spreadsheet/...2c&usp=sharing
Laika is offline   Reply With Quote
Old 05-12-2014, 03:31 PM   #402
SpeedyJay
SpeedyJay's Avatar
Drives: '13 WRB BRZ
Why are you buying 5 liters of it? I thought the transmission only takes 3L.
Old 05-18-2014, 05:15 AM   #403
nyfries
Drives: 14 FRS Whiteout
Sold on the mtf2. Gonna change it out after I pick up a low profile jack.
The question is who has the best price for the mtf2 + motul300 for the diff?
nyfries is offline   Reply With Quote
Old 05-18-2014, 05:25 AM   #404
OICU812
Just a dude
OICU812's Avatar
Pentosin = Autohauz in Arizona. The Motul well you can get that locally in Van somewhere I'm sure. Google foo may find you both in your own city.
Old 05-18-2014, 05:55 AM   #405
nyfries
I live very close to the border I don't mind making a trip their, where would be the best store to pick up both in the states?
Old 05-18-2014, 06:04 AM   #406
OICU812
Just a dude
OICU812's Avatar
I dunno man would need to google it. Both are not that uncommon. I bought Motul near local in Edmonton. The MTF2 I bought online from Autohauz and had mailed.
Official Australian Toyota 86/Subaru BRZ Owners Thread Maj3sty AUSTRALIA 148 09-02-2017 06:55 AM
Five Axis Edition FR-S Owners Thread digital_assassin FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 563 07-08-2015 09:22 PM
Must-read for Top Gear fans Sport-Tech Other Vehicles & General Automotive Discussions 16 03-28-2012 09:38 AM
Supra Owners Build Thread BoostJunkie Other Vehicles & General Automotive Discussions 164 03-12-2012 09:37 AM
Will FT-86 have Synchro Rev Match? Dark Scion FR-S / Toyota 86 GT86 General Forum 56 05-27-2010 11:05 AM
