Old 09-21-2015, 12:02 AM   #4033
ka-t_240
Originally Posted by Vic91 View Post
actually we're four i have a friend with red scion lol
I think he meant signed up for MNTA Finale on the 3 part! Unless you signed up as well. lol
ka-t_240 is offline   Reply With Quote
Old 09-21-2015, 08:57 AM   #4034
KevinK121
Miata traitor
KevinK121's Avatar
Drives: 2002 Miata SE
Yep. Still only 3 three signed up. I know Derek will be signing up too but I'm still surprised it's only 3. I'm sure the day before it'll be like 5 late sign ups.
KevinK121 is offline   Reply With Quote
Old 09-22-2015, 07:42 AM   #4035
jdnguyen
jdnguyen's Avatar
Drives: 2013 FR-S Series 10 and 2010 Camry
My co driver will be signed up too...
jdnguyen is offline   Reply With Quote
Old 09-22-2015, 09:26 AM   #4036
KevinK121
Miata traitor
KevinK121's Avatar
What are they driving?
Old 09-22-2015, 10:50 AM   #4037
TMF
TMF's Avatar
Drives: '14 FRS TT5
Originally Posted by redlined600 View Post
I'll take the DTC-60s if you don't want them. I really can't believe you guys aren't fading HP+ pads.
The HP+'s used to fade on my STI up at BIR and in my limited experience in the FRS, braking hard into turn 13 after the standing start lap, the HP+ felt like they were fading a bit.
For autox, DCTC and similar, I think the HP+ is good. For full track like BIR, other big road courses, I think a higher temp pad is needed. But if you go too aggressive, you'll overpower "street" tires.
Another thing to be mindful of when you go to a more aggressive pad (not saying you're having this problem, just general info), is that you have to learn to brake later and use more of the brake. A friend of mine said he was running DTC-something and was over heating them at BIR because he was braking too early and not aggressive enough - thus longer pad to rotor contact, more heat, more fade. Later, more aggressive braking = less friction time, less heat. There is of course a happy medium.
Follow my NASA TT5 build here: JHill Motorsports
TMF is offline   Reply With Quote
Old 09-22-2015, 10:53 AM   #4038
TMF
TMF's Avatar
Drives: '14 FRS TT5
I'm still trying to decide if I'll compete on the 10th...it's either compete, instruct/work the event, or go the Nordeast Big River Brew Festival. Too many options!
Old 09-22-2015, 12:13 PM   #4039
ka-t_240
Co-Driver = same car with a different driver
Old 09-22-2015, 02:39 PM   #4040
KevinK121
Miata traitor
KevinK121's Avatar
I was wondering if thats what he meant. I was going to make a 'ringer' crack.
Old 09-22-2015, 02:39 PM   #4041
KevinK121
Miata traitor
KevinK121's Avatar
Did you decide on Surly tonight?
Old 09-24-2015, 10:07 AM   #4042
fasteddy
Originally Posted by Gopherboy6956 View Post
I can't hold flat out in 2 on Z2SS. I reached about 120 at the turn in and started sliding the rear at 117 near the apex. I lifted just a little on that one going in. It was my best full road course lap at 1:50:01 though.
Typically I probably apex at 110-111 and hit 120 again before I brake at 4 or 3.5 marker into 3
Sent from my HTC6525LVW using Tapatalk
Was that in your BRZ? That is seriously quick! I have going to BIR a couple times a year for quite a while now. I don't often check my lap times but when I do I am happy to be under 2 minutes.
Hey, local guys. I have some brakes and wheels for sale here in MN in case anyone is interested.
http://www.ft86club.com/forums/showthread.php?t=95103
http://www.ft86club.com/forums/showthread.php?t=94696
I was only at BIR once with these brakes and never got there with the newer pads.
One other track trick I would like to pass on. I slotted my factory struts and used camber bolts to get -3 camber up front. This stopped the edge wear I was getting on the tires. I also could go for longer sessions. Before I did this I would get maybe 4-5 laps in before the tires felt greasy, after that I could go the full 25 minutes without an issue.
I sold my car last week so I am motivated to move these parts.
I also have a WRX spare wheel/tire for sale. This clears the brake kit.
Pat
fasteddy is offline   Reply With Quote
Old 09-24-2015, 10:09 AM   #4043
jdnguyen
jdnguyen's Avatar
I may be interested in the brakes. Need to look at my budget and I'll let you know.
Old 09-24-2015, 10:12 AM   #4044
fasteddy
OK sounds good. This is one of the only kits that works with stock wheels.
Pat
The Following User Says Thank You to fasteddy For This Useful Post:
jdnguyen (09-24-2015)
Old 09-24-2015, 11:52 AM   #4045
ka-t_240
Pat
Do those clear rpf1?
Old 09-24-2015, 12:40 PM   #4046
fasteddy
I would sure think so but I don't have any firsthand knowledge.
You can get the template to check here:http://www.essexparts.com/shop/compl...43mm-disc.html
Pat
Check in, eh? NorthFool CANADA 24 02-23-2012 07:32 AM
*NSFW* "Check Out My Subaru" on You Tube Axel Other Vehicles & General Automotive Discussions 4 01-17-2010 05:56 PM
how do you check a site 4agze Off-Topic Lounge [WARNING: NO POLITICS] 3 11-21-2009 09:27 PM
Video of FT-86 @ TMS from Edmunds. Check out how small the car is next to people. JDMinc FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 9 10-25-2009 08:53 PM
