Old 02-12-2017, 10:32 PM   #3907
SPCorBUST
SPCorBUST's Avatar
Originally Posted by eherschend View Post
15k? Really? That number seems inflated.
If you choose skimp on some things, I think you could do 13k. Again, this is for everything new. If you had a motor that was fine and just wanted to replace some stuff in it, I'm not sure what that would be.
Sent from my SM-G925T using Tapatalk
Setup 1: KW C38, Grams 550, Grams 265, 4bar, FlexFuel, Delicious
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East
Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church
Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor
Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor
SPCorBUST is offline   Reply With Quote
Old 02-12-2017, 10:39 PM   #3908
twag4
Drives: frs
12k for motor, 5k for supporting mods
twag4 is offline   Reply With Quote
Old 02-13-2017, 01:02 AM   #3909
SoCalArgento
Drives: 2014 Argento FRS
Curious what supporting mods would be needed for adequate motor strengthening/improvement? Rods, pistons, bearings, valves/springs etc?
SoCalArgento is offline   Reply With Quote
Old 02-13-2017, 02:38 AM   #3910
kevin.nguyen
Drives: Ultramarine FRS
What modifications do you have?
kevin.nguyen is offline   Reply With Quote
Old 02-13-2017, 02:57 AM   #3911
SoCalArgento
C38 with DD flex fuel supporting mods.
What about you?
Old 02-13-2017, 07:13 AM   #3912
BR-ZED
BR-ZED's Avatar
Drives: 2014 WRB BRZ Limited
Originally Posted by SPCorBUST View Post
Around 15k all in with new everything is fair.
Are you saying $15k for just the motor?? Or everything in your build (sc, fuel pump, injectors, oil coolers, etcetc)
Element tuning has race motors in the $5k to $7.5k range
http://elementtuning.com/competition...r-wrx-fa20dit/
BR-ZED is offline   Reply With Quote
Old 02-13-2017, 07:25 AM   #3913
Yoda
Drives: Crystal Black BRZ(Sophia)
Prob not 15k for just the motor. I assume it includes labor and tuning and everything thing else so it runs right. Not too bad really. It cost money to build.
Yoda is offline   Reply With Quote
Old 02-13-2017, 12:22 PM   #3914
SPCorBUST
SPCorBUST's Avatar
That cost assumes you sent them a fully serviceable long block. Shipping, a new long block, installation, a new tune, taxes, etc. and you're going to be where we're saying.
Old 02-13-2017, 04:10 PM   #3915
twag4
Drives: frs
Yes, rods, pistons, bearings, valve springs, valve guides, valves, machine work, chamfer oil passages etc. these aren't supporting mods though. This is the engine build. My oil cooler is likely full of metal, since it is full of antifreeze, it'll have to be replaced. My upgraded clutch isn't going to be upgraded enough. I'll need axles. I'm buying the c38 upgrade. I need motor mounts. And, I need an improvement or replacement to transmission. I will be over that 5k mark if I replace/upgrade the transmission- which I will. But, that I didn't consider a supporting mod to the engine. It's a transmission thing. I could baby the stock transmission to get by, plus I have a spare. The engine could go more than 12k too, depending on what else is damaged. The coolant fitting that runs under the intake manifold but on top of the engine is blown apart. Timing cover might be a loss. Heads might be unsalvageable. It could go 15k just for the engine.
The Following User Says Thank You to twag4 For This Useful Post:
SoCalArgento (02-15-2017)
Old 02-13-2017, 04:13 PM   #3916
twag4
Drives: frs
They can source a used serviceable engine in the $2500 range. That puts their long block, super stout, big valve, 9000 rpm monster in the $10000 range. Plus any labor and tuning plus supporting mods.
Old 02-13-2017, 04:41 PM   #3917
SPCorBUST
SPCorBUST's Avatar
Shipping, taxes, installation, supporting mods etc. put you at 13 to 15k. In Cali taxes alone are about 1k and labor is like 1-2k, so that's 12-13k assuming no tune or supporting mods... But who does that? You'll want those mounts, oil pump, fuel pump, tune, etc. That's like another 1.5k already, not including is you want to upgrade your clutch, add oil cooler, and other jazz.
Old 02-13-2017, 04:46 PM   #3918
twag4
Drives: frs
I am already in the middle of my engine build. My prices are from my experience. As I mentioned before, 12k for engine, plus around 5k for supporting mods. With a chance of fair to partly "gotta buy more stuff" for the engine itself. No shipping or tax where I live and with my builder. My engine will be a high rpm engine as well.
Old 02-13-2017, 05:37 PM   #3919
SPCorBUST
SPCorBUST's Avatar
Ah, in my reply I transposed you with the other fellow thinking the cost was a bit high. My build experience is similar to yours.
The Following User Says Thank You to SPCorBUST For This Useful Post:
twag4 (02-13-2017)
Old 02-13-2017, 07:53 PM   #3920
BR-ZED
BR-ZED's Avatar
Thanks. All of this is making me think that maybe I should just trade in for used stingray..... :-(
Though at least for me, Element is local. They quoted me around $9k for the installed built motor.
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
