Old 02-11-2017, 02:10 PM   #3893
Jmonty
Realtor/ Principal Broker
Drives: JRSC BRZ GBS LTD 2010 LTD Outback
How many miles on that set up, and what fuel were you running?
Originally Posted by twag4 View Post
I think these cars have oil pressure issues inherently, which I believe probably caused a bearing to spin, resulting in a broken rod. Or, the rod simply broke. I offer the second possibility, as my engine never made any strange noises, or gave me any indication of an impending failure whatsoever. I was driving in the rain, got up to 40mph rather conservatively, and once my speed was stabilized at 40, I went maybe 200 feet and the engine quit. It was a strange mix of noise, literally every light on my dashboard came on ( including both turn signal indicators on steady), and a huge cloud of white smoke that literally caused everything behind me to vanish. I also had little bits of metal bouncing down the road beside me. I now have a window under my intake manifold that is about 10 inches long by one inch wide. Carnage, pure carnage. I am about to walk into the garage, repair my broken garage door spring, and pull the engine. I will take it to the engine builder who can hopefully salvage the heads and timing cover. Getting more power and rpm, and I am getting an improved drivetrain (think stronger transmission). I will reveal more on that when the option I am going with is officially released. I believe a lot of people are going to want to know about this. I was a little north of 350 whp when my engine blew btw. This is not a cheap engine to build. I mean really not cheap! But, I don't want to destroy the character of the car by doing an LS swap or something like that. Just what I want...! I don't mind others doing it, it just isn't for me.
Jmonty is offline   Reply With Quote
Old 02-11-2017, 11:18 PM   #3894
86joe
Drives: 2013 Scion FRS
How much boost did the testing with the RS show to make at redline? Is the lowered redline necessary because the blower is exceeding 90k rpms? Reason Im asking is because I have a built motor in process and am looking at squeezing more out of my C38. I originally was going to have a machine shop make me a custom pulley that will make about 14-15psi at redline and then use a wastegate placed right before the intercooler and set it to open at 12psi (and also lower the redline a little bit) that way id have the boost level of the High Boost Pulley but that 250ft lbs or whatever torque it makes would come on sooner in the rpm band. Setti g the wastegate to open before hitting max boost at redline should allow it to hit that 12psi sooner and hold it till redline if Im not mistaken?
Anyways all that aside, if the RS pulley can make just north of 12-13psi without overworking the rotrex Ill be satisfied lol.
I dont mind a slightly lowered redline if i can hit boost sooner.
86joe is offline   Reply With Quote
Old 02-11-2017, 11:27 PM   #3895
86joe
Originally Posted by DaiTT500 View Post
Your tuner could probably be able to do flex fuel map and another map to 110 octane fuel. I don't think you can use a flex fuel map to run 110 octane. as the tune uses an ethanol content sensor to tell the computer how much timing to advance or pull based upon ethanol content. Another map can be setup for race gas 110 octane with different timing and fuel strategies to maximize the fuel. Most tuners use the cruise control stalk to change maps.
Old 02-11-2017, 11:51 PM   #3896
twag4
Drives: frs
Originally Posted by GsxrMe View Post
@twag4
Tuner? Or OTF tune?
Oil used? Oil cooler used?
ECUtek, yes oil cooler, Mobil 1 5w30. Yes oil cooler. It was tuned like I requested, not a tuner mistake. My mistake.
twag4 is offline   Reply With Quote
Old 02-11-2017, 11:58 PM   #3897
twag4
Drives: frs
I was on a 93 octane tune for about one year. C30, standard pulley, oil cooler, ace 350a header and full exhaust. Switched to e85 catless in July. Engine blew the Tuesday after Thanksgiving. I'm a pilot and was in training for a new aircraft. I finally just now have time to deal with it. Just want to be clear it wasn't a tuner mistake. My request was met.
The Following 2 Users Say Thank You to twag4 For This Useful Post:
Barefootdan (02-12-2017), Jmonty (02-12-2017)
Old 02-12-2017, 10:28 AM   #3898
Jmonty
Never suspected the Turner, we were/ are running a similar setup but I now have the C38 blower
The Following User Says Thank You to Jmonty For This Useful Post:
twag4 (02-12-2017)
Old 02-12-2017, 10:59 AM   #3899
twag4
Drives: frs
Just wanted to make sure that was out there for everyone's sake!
The Following User Says Thank You to twag4 For This Useful Post:
Jmonty (02-12-2017)
Old 02-12-2017, 02:23 PM   #3900
cgjeff
Drives: 2015 Scion FRS
We can catch up and you can experience this setup yourself. Sometime after all this snow/ice stuff
Definitely need to get together this Summer! I ordered the Rad/Cooler combo, just have to wait until work slows down to install it.
cgjeff is offline   Reply With Quote
The Following User Says Thank You to cgjeff For This Useful Post:
Jmonty (02-12-2017)
Old 02-12-2017, 08:28 PM   #3901
twag4
Drives: frs
About 11000 miles before e85, about 4500 after.
Old 02-12-2017, 09:28 PM   #3902
twag4
Drives: frs
some photos of the carnage under my intake manifold. You can see the broken rod end in some of the photos. Enjoy!
eherschend (02-12-2017), Psilox (02-27-2017)
Old 02-12-2017, 09:36 PM   #3903
Barefootdan
Barefootdan's Avatar
Drives: 2017 BRZ
as someones who's never built an FA motor, how much are you estimating your costs?
Barefootdan is offline   Reply With Quote
The Following User Says Thank You to Barefootdan For This Useful Post:
Old 02-12-2017, 09:43 PM   #3904
SPCorBUST
SPCorBUST's Avatar
Mine appeared similarly.
Sent from my SM-G925T using Tapatalk
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East
Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church
Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor
Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor
SPCorBUST is offline   Reply With Quote
The Following User Says Thank You to SPCorBUST For This Useful Post:
twag4 (02-12-2017)
Old 02-12-2017, 09:46 PM   #3905
SPCorBUST
SPCorBUST's Avatar
Around 15k all in with new everything is fair.
Old 02-12-2017, 09:48 PM   #3906
eherschend
15k? Really? That number seems inflated.
eherschend is offline   Reply With Quote
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
