Old 05-14-2015, 12:41 PM   #379
cjd
cjd's Avatar
Drives: 2017 BRZ
Originally Posted by renfield90 View Post
Try it and let us know!
Of course. May try to work out a swap with someone more seasoned to, well see.
I'm registered, just have to let the 24th roll around. this weekend is a road trip, and that'll be on PSS.
Old 05-14-2015, 01:44 PM   #380
autoXracer
Drives: 2013 WRB BRZ
Might just try the 255. STR s2000's run that size. Hope there won't be any rubbing issues with +45 wheels on the front inner fender wall and Strano sway bar.
autoXracer is offline   Reply With Quote
Old 05-14-2015, 07:06 PM   #381
48Spoons
Drives: Ultramarine FR-S
I've been running the the RE71 in 255 and so far they feel really good. I've had 3 events on them. I have the new TRMotorsport wheels with are +45 and I did have some trouble clearing the stock perches(I have the koni inserts) in the front. If you have full aftermarket coils it should be fine.
48Spoons is offline   Reply With Quote
Old 05-14-2015, 08:02 PM   #382
RedBRZ80
Drives: 2013 Red BRZ
Originally Posted by autoXracer View Post
Does the RE-71R in 255/40-17 benefit more than 245/40-17 for STX? Trying to decide between the 2.
The "fast" guys are running 245/40 in STX for the RE71Rs. Lighter tire and better turn in.
RedBRZ80 is offline   Reply With Quote
Old 05-14-2015, 11:28 PM   #383
autoXracer
Appreciate the input. Wasn't sure what everyone was running.
Old 05-19-2015, 08:16 PM   #384
RedBRZ80
70 runs into my first set of RE71rS. They might be about 90% of the grip when new. Still very solid.
Already have a second set waiting to go, if the Georgia Match Tour happens I'll probally go with the new ones.
Old 05-20-2015, 09:45 AM   #385
SeanRTR
C-Street AutoX
SeanRTR's Avatar
Test a new set against an old set for an actual delta on the watch, and I'll send you $6 via paypal.
-2013 Scion FR-S C-Street
Gearhead Homes - Homes geared towards car enthusiasts: https://www.facebook.com/GearheadHomes.RealEstate
SeanRTR is offline   Reply With Quote
Old 05-20-2015, 12:24 PM   #386
Locust
Custom User Title
Locust's Avatar
Drives: 2015 Scion FR-S, 2012 OB Evo X MR
Send a message via AIM to Locust
Sitting at Discount Tire waiting for my RE71Rs to get installed. For those of you running them what pressures are you starting with on pavement? And what about in the rain?
LOCUST
2015 FR-S (STX) and 2012 Evo X MR
Instagram:
LocustAutoX
Sponsors:
DSGPerformance Drift Office Evil Apex Racing
Locust is offline   Reply With Quote
Old 05-20-2015, 01:04 PM   #387
SeanRTR
C-Street AutoX
SeanRTR's Avatar
31 dry
25 wet
Old 05-20-2015, 01:14 PM   #388
Biggins
Drives: Yes
Originally Posted by SeanRTR View Post
31 dry
25 wet
What he said... I have my rears a little lower.
Biggins is offline   Reply With Quote
Old 05-20-2015, 01:53 PM   #389
Locust
Custom User Title
Locust's Avatar
31 dry
25 wet
Thanks guys
LOCUST
Instagram:
LocustAutoX
Sponsors:
Old 05-21-2015, 10:42 AM   #390
rx3
31 dry
25 wet
Granted that I don't know the RE71R. But the consensus here for any tire is that in wet conditions tires should be run at higher pressures.
For following reasons:
An overinflated tire has a reduced contact area and is therefore displacing water superiorly. But more importantly: This reduced contact area is apparently also getting more heat into the tire (and a warmer tire will be grippier). This sounds counter-intuitive but the reason could be that less contact area also reduces the heat transfer to the road (the cold road can't cool the tire as quickly). Some also say that a harder tire slides more initially and this generates more heat.
rx3 is offline   Reply With Quote
Old 05-21-2015, 10:57 AM   #391
SeanRTR
C-Street AutoX
SeanRTR's Avatar
I always hear this. Your thinking is correct if the autocross conditions look like this:
But when it's not a monsoon (most of the time), dropping the tire pressure to soften the sidewalls and make the tire more compliant is what you're looking for. If you're autocrossing in several inches of standing water, you probably should have stayed home....but if not, THAT is the situation where you would run more pressure.
Old 05-21-2015, 11:06 AM   #392
rx3
No, I'm not just speaking about hydroplaning.
As I said:
More importantly: This reduced contact area is apparently also getting more heat into the tire (and a warmer tire will be grippier). This sounds counter-intuitive but the reason could be that less contact area also reduces the heat transfer to the road (the cold road can't cool the tire as quickly). Some also say that a harder tire slides more initially and this generates more heat.
I also noticed that a narrower tire in damp cold conditions is faster than a wider tire.
Areddi's Autocross Video Thread Areddi Mid-Atlantic 130 05-17-2015 06:19 PM
Anyone DD 200 Treadwear Tires? CraftyObeseCrunchyKitty Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 01-09-2015 11:44 AM
Tire PSI for completely stock autocross? bladesamurai Tracking / Autocross / HPDE / Drifting 16 06-11-2013 10:07 AM
Autocross Tire Pressure on ZII's Areddi Tracking / Autocross / HPDE / Drifting 6 04-12-2013 08:37 PM
KW V3 autocross set-up thread -max- Tracking / Autocross / HPDE / Drifting 97 10-18-2012 08:02 PM
