Old 05-04-2018, 06:52 PM   #379
MJones_RB
MJones_RB's Avatar
Me too. I'm nervous that I'm going to mess something up. I'm pretty comfortable with doing regular maintenance, but I've never messed with master cylinders or stuff like that.
Invest in a simple set of metric flare nut wrenches. It will take the worry out of loosening those banjo bolts.
MJones_RB is offline   Reply With Quote
Old 05-10-2018, 05:30 AM   #380
Whiskerz
Drives: 2014 86 GTS
Can anyone confirm whether THIS is the same part? I'm in Aus so I can't use your other links. Thanks for the writeup by the way.
EDIT: I don't know how I didn't realise that is clearly is the right part. Will probably be ordering this Thursday and giving this a go.
Whiskerz is offline   Reply With Quote
Old 06-20-2018, 04:07 AM   #381
Harey
Drives: 2013 Toyota 86
Just did this and wow I can drive a manual again!!! I dont know why it wasnt like this from the factory, its just how it should be. Nice predictable, precise engagement point each time.
I didnt have anyone to help with the bleeding so just used a block of wood pressed up against the drivers seat.
Thanks for the great writeup!!! It really is a pretty simple mod. If you dont do these things often just take your time.
Harey is offline   Reply With Quote
Old 06-20-2018, 12:39 PM   #382
Ultramaroon
not playing cards
Ultramaroon's Avatar
I think the level of detail may intimidate some people. The intent was to write it for adventurous beginners. Great to hear that it worked for you!
Apologies for missing your post. How did it go?
Old 07-29-2018, 08:07 AM   #383
reeves
Can anyone verify that the Autozone slave cylinder is shorter in length then the OEM one? Mines was.. and I'm having a hard time disengaging the clutch. Not saying it's due to the cylinder, but just wanted to rule it out & make sure I didn't get a wrong/faulty part. I bought the 900061 cylinder, but I've gotten faulty parts from them before. TIA!
reeves is offline   Reply With Quote
Old 07-29-2018, 01:33 PM   #384
N234
N234's Avatar
Drives:
What exactly do you mean by "hard time"?
Did you do the "Easy clutch Green adjustment" after installing?
Sent from my SM-G930W8 using Tapatalk
N234 is offline   Reply With Quote
Old 07-29-2018, 02:26 PM   #385
Ultramaroon
not playing cards
Except for branding, it should look identical to the stock cylinder. Can you share a photo?
Old 07-29-2018, 06:58 PM   #386
reeves
Ok never mind, I think they might be the same length after all. I popped off rubber to the broken OEM one to find the copper section completely blown out of the cylinder lol.
It definitely made it look longer than the Autozone one.
Still can't shift into gear though. Bled the clutch through a whole quart of fluid just to make sure.. And adjusted the pedal height thrice. It still doesn't mean the Autozone one isn't defective either (here's hoping). I'll buy another slave cylinder just to test it first before attempting to pull my tranny off (again).
Old 07-29-2018, 07:03 PM   #387
reeves
It's just plumbing. If you can fix a faucet, this'll be a cakewalk. Cleanliness is the key factor.
Yea it's a cakewalk like Ultramaroon said. I was hesitant at first too but was amazed at how simple it was to swap out. Just have a few extra 10mm crush washers handy in case you drop one.
Old 07-29-2018, 07:13 PM   #388
Ultramaroon
not playing cards
That's ok. I don't think there's anything wrong with that original slave cylinder. There's nothing keeping the piston from being ejected if the pedal is pumped while nothing pushes back. I'm guessing that was the case with your clutch failure. Let's troubleshoot your clutch in the other thread.
Old 07-29-2018, 10:01 PM   #389
ChRZ
ChRZ's Avatar
Drives: 2017 BRZ SP
Anyone happen to know if this is scca STX legal?
Sent from my Pixel using Tapatalk
ChRZ is offline   Reply With Quote
Old 07-31-2018, 06:12 PM   #390
reeves
I just bought another AutoZone one (900061) and also picked up an OEM one from the Subaru dealership. They are definitely not the same length. AutoZone one is slightly shorter.
Not saying this is the cause of my clutch problems.. just wanted to make a note.
OEM one is on the left, already with the pin assembled.
Old 07-31-2018, 07:55 PM   #391
Ultramaroon
not playing cards
They're identical except for the bore. You're fixating on the dust boot. Take them both apart and examine them. I have done just that with at least 10 people on my porch steps to help demystify the whole process. Once you see the guts, you'll understand that it's no more complicated than a syringe.
Keep them clean, though.
Old 07-31-2018, 08:13 PM   #392
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
He's not lying. He will take your nice clean new slave apart even if you're not mystified. Priceless.
clutch line, slave cylinder
Clutch Engagement Improved! enjoyminutemaid Engine, Exhaust, Transmission 53 11-07-2018 06:31 PM
Can steering feel, tactility, be improved? Without sacrificing adjustability? Trettiosjuan Suspension | Chassis | Brakes -- Sponsored by 949 Racing 101 08-16-2016 08:14 PM
Aftermarket Clutch Master and Slave? Yruyur Engine, Exhaust, Transmission 5 07-27-2013 10:22 AM
Hate the feel of the clutch FRSGeek Engine, Exhaust, Transmission 18 07-10-2013 01:24 PM
Clutch feel? Shit Luck Engine, Exhaust, Transmission 5 04-21-2013 05:32 PM
