Old 02-07-2015, 01:25 PM   #379
ap5512
ap5512's Avatar
Drives: 2013 SWP BRZ
The sound is like a fluttering kind like leaves rustling. I haven't logged any data yet but after I re-tighten the bolts today I'll log it. Any word on the torque specs?
"Don't be a don'ter, do be a doer" - Johnny Wu
ap5512 is offline   Reply With Quote
Old 02-07-2015, 03:28 PM   #380
ap5512
ap5512's Avatar
Just got done re-tightening the bolts....they were extremely loose. One was literally just hanging off the thread stud waiting to fall off.
I torqued the header bolts to 22 ft./lbs and did about 34 ft./lb for the header to overpipe connection.
The sound is gone and the smell is too...
My only concern is that is the bolts on the header ( the 3 on each side) come loose too easily with the given torque specs. I'll have to keep and eye and ear out to see if the sound changes again and also keep track of my logs.
Old 02-07-2015, 05:35 PM   #381
2much
I wanna go fast
Drives: 2013 FR-S 6MT
damn I just got mine installed about two weeks ago. Now i'm worried and I've got to get the bolts checked.
2much is offline   Reply With Quote
Old 02-07-2015, 05:51 PM   #382
ap5512
ap5512's Avatar
^^ I don't think you should worry if you had yours installed by a pro. This was my first time installing a header. It wasn't difficult but I could tell right away something was wrong. The sound and smell was very apparent.
I installed the header last week and noticed the sound getting obvious on cold starts and every time i was on the gas pedal. I'm just really glad I took the time out today to inspect them. I think had I waited a few more days, the very loose bolt would have flown away.
Once I re-tightned to torque spec the sound was instantaneously changed and it sounded the way I expected. The way I see you shouldn't be hearing any type of strange fluttering sound on starts/accelerating from the front of the car.
Old 02-07-2015, 05:52 PM   #383
ap5512
ap5512's Avatar
On a positive note..the OFT+OFH has made the car seem much smoother. The power feels more linear and shifting through gears seems smoother too.
Old 02-09-2015, 02:42 PM   #384
tomaszjanczak
Drives: Silver Subaru BRZ
@Shiv@Openflash Hey sorry to bother you again but I emailed you my log last week and you haven't replied. I'm the one with the P2097 code.
http://datazap.me/u/tomaszjanczak/lo...5?log=0&data=1
Thanks for your time.
tomaszjanczak is offline   Reply With Quote
Old 02-09-2015, 02:56 PM   #385
steve99
- Exhaust leak near O2 sensor
- Faulty O2 sensor
did this occurr after fitting ofh ?
did you use new gaskets
did 02 sensors screw in by hand ? then torque to correct level. if you forced them then it can strip threads or damage sensor
Tips for changing header
1. Always use new gaskets, if you re-use the old ones it will leak causing 02 sensors to read incorrectly
2. Run a thread tap or chaser (M18 x 1.5) through you new header 02 bungs to clean them up , 02 sensors should screw in by hand. If you force them they are easily damaged and the threads on 02 sensor easily stripped.
3. Put high temp anti-seize on header bolts and 02 sensor bung threads, DO NOT get any grease or anti-seize on sensor tips, once contaminated they are stuffed.
4. Leave the 02 sensors in the stock header until you remove it from car then remove sensors. Just disconnect the plugs an tethers on wires as per picture below.
5. Black plug to black socket, grey plug to grey socket. and remember to plug both back in.
6. Use correct torque for bolts and o2 sensors, re-torque after a heat cycle.
Old 02-09-2015, 03:16 PM   #386
tomaszjanczak
- Faulty O2 sensor
Hey thanks very much for your help but you already helped me a few months ago when I posted about this issue on the forums!
I have no leaks, because I had it smoke tested multiple times. Both O2 sensors already replaced, brand new gaskets replaced twice already (second time with thick Grimmspeed gaskets). I ran thread tap through O2 sensor holes, used anti-seize on O2 sensors, everything is perfectly installed, torqued perfectly, yet I still get the code (it goes on and off totally randomly but it's on more than off).
And yes, this happened after the install of the OFH. I never got it on stock tune or stage 1, everything was good. I already emailed the whole story to Shiv, he just hasn't replied back yet after I sent him the data log.
There was an issue in the beginning with the OFH's flange not being flat at the overpipe connection and that showed an obvious leak when smoke tested, but that's been fixed and I still have the code.
Old 02-09-2015, 03:23 PM   #387
DarkSunrise
DarkSunrise's Avatar
Out of curiosity, how did you fix the flange issue? I've been trying to fix an exhaust leak at the OP/header connection as well (JDL header/overpipe). Thanks!
2022 BRZ Build
2013 FR-S Build
Old 02-09-2015, 03:29 PM   #388
tomaszjanczak
I took it to a shop, don't know exactly how they did it. Sorry I didn't help
Old 02-09-2015, 03:43 PM   #389
DarkSunrise
Haha no problem. I'm guessing they probably lapped it using a belt sander or something like that.
2022 BRZ Build
2013 FR-S Build
Old 02-09-2015, 08:39 PM   #390
steve99
ring the openflash guys on the phone.
Old 02-09-2015, 09:48 PM   #391
tracerit
Drives: '13 SSM BRZ Limited 6MT
This is more of a general header question, but since I have the OFT already, I figured maybe complement it with the OFH. So with the OFT, I notice a raspy metallic noise at 4k which I've read has something to do with the timing to get rid of the torque dip. Someone mentioned that getting a header can address this metallic noise. So for users who have both the OFT + OFH, does it get rid of it entirely or is it just minimized?
tracerit is offline   Reply With Quote
Old 02-09-2015, 09:57 PM   #392
2much
I wanna go fast
I am not sure I know exactly which noise you are talking about. But I can say with both oft/ofh all I can hear is bassy rumble and air induction on the inside.
Open Flash Header - Sound and Performance Comparison nlowell Engine, Exhaust, Transmission 41 05-19-2014 06:29 PM
FS: Open Flash Header - SoCal Pickup nlowell Engine, Exhaust, Bolt-Ons 9 05-12-2014 06:29 PM
Open Flash Tablet Andrew025 Engine, Exhaust, Bolt-Ons 3 04-26-2014 05:03 PM
Open Flash Header Catless Clip Vmax911 Engine, Exhaust, Transmission 25 03-08-2014 06:51 AM
Open flash tablet. cooldandani Scion FR-S / Toyota 86 GT86 General Forum 1 02-22-2014 07:14 PM
