#379 |
I Love custom Turbo kits
Drives: Limited BRZ
Thanks. I did do a full read before write and waited more than 15 secs everytime but definitely sounds like it might be the pins.
Great thread man.
| The Following User Says Thank You to Sportsguy83 For This Useful Post: | steve99 (06-04-2015) |
#380 |
Drives: 86
can any one help find J rom logcfg.txt
#381 |
the guy you need is @Td-d he should be able to give you a list of ecu ram addresses for your J series rom he will need to know which rom eg A02J then you can substitute thoe ram addresses into a G series logcfg.txt to make a J series logcfg.txt as scaling should be same.
best to emial him from www.romraider.com forum he is moderator their. |
#382 |
I love peanut butter
Drives: 2013 SWP BRZ Limited
Hey Steve, I went into romraider last night and was thinking of enabling FF shift option. When I use the RR def included with the roms, the option is not there. However, when I use the oft def, it appears. Is it not safe to edit rom when not using RR def? Using b01c 91 uel ROM.
#383 | |
Drives: UK GT86
.: Stealth 86 :.
#384 | |
lc ffs is a patch to rom code so only oft defs will have the tables to adjust parameters. make sure you only have one def linked in romraider as it might pick the wrong def if they are for same rom. make sure your using oft v2defs for v2 tunes and not the old v1.5 defs, v2 defs come in v2 tune zip flle |
#385 |
My car came with a A01C ROM and I was told (I think by Steve) that OFT A01C is a cal-id hacked B01C. It is safe to use B01C ROM and B01C defs, correct?
#386 | |
http://www.ft86club.com/forums/attac...1&d=1395947828 Roms later than B01C may not be compatable see first post in this thread for rom compatability Last edited by steve99; 06-13-2015 at 01:13 AM. |
| The Following User Says Thank You to steve99 For This Useful Post: | EAGLE5 (06-12-2015) |
#387 |
So right now we treat log records as snapshots in time, but in reality there's some serious skew going on -- if we poll 20 parameters, the last parameter polled is a lot closer in time to the next record than the current one.
It'd be interesting if we could measure the skew for each column. Maybe with the first row in a log being their offsets in time. Know if Tactrix has a way, or if we could calculate it based on the Tactrix config?
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
#388 | |
Drives: UK GT86
Playing devils advocate here, but to do that as accurately as you suggest you would need an individual row for each cell of data. Seeing as each row is given a time value, to separate each column's data poll (or skew) you would have to allocate that poll a time value and therefore you would have a row that shows the time value and then one cell of data. It's the logging resolution that really matters, if that's good enough then the data you collect will be more than adequate.
.: Stealth 86 :.
#389 | |
Assuming each record follows the same plan, I think having the start of the file look like this would be sufficient: Code:
Time,RPM,MAFv,FBKC,etc... +0ms,+0ms,+20ms,+10ms,etc...
#390 |
Road-hole
Drives: 2013 Whiteout FR-S
Logging OFT E85 using A01D...
So, it was my understanding that all the OFT's use a B01X that was changed for each bin and had a renamed calid, but when I use a B01D logcfg, I get zeroes for many params including engine speed/RPM...
This makes logging pretty much useless.. Any ideas what could be going on? Jaden ok so I re added the B01D logcfg and went out and did another log. It does show rpm but it doesn't seem right. I think it's off. Here is my log file. I know I redlined a couple of times and it idles at 700 so I don't understand why I'm getting these numbers...ok can't attach csv... oh well Last edited by Jaden; 06-28-2015 at 06:28 PM. |
#391 |
Drives: 86
Make sure that you useing correct logcfg file for your rom type
#392 |
Road-hole
yes but it's not that simple...
I've tried both A01D and B01D... Because it's an OFT rom type I'm not sure which is right because they use a different base rom.
The base file I'm using doesn't tell me either because it's a modded one to go with the OFT specific roms which are named based on the name of the rom file you use, which is A01D in my case but isn't necessarily that type. JAden |
| Tags |
| ecuflash, tactrix, taxtrix, tuning |
| ECUFlash - Getting close! | xjohnx | Software Tuning | 698 | 03-22-2015 12:10 PM |
| EcuTek Flash finished but now it shows only a Partial Flash... | Cross | Software Tuning | 32 | 02-12-2014 10:55 AM |
| Tactrix Openport | jamesm | Engine, Exhaust, Bolt-Ons | 1 | 01-28-2014 08:27 PM |
| Visconti Tuning - Latest BRZ Flash Info | Visconti | Software Tuning | 6530 | 12-24-2013 10:18 PM |
| Overboost Protection With OFT/EcuFlash? | FrX | Software Tuning | 9 | 10-23-2013 07:27 AM |
