Old 07-01-2012, 01:23 AM   #379
kanundrum
Drives: 2013 Whiteout FR-S
Awesome Had NO idea
Old 07-01-2012, 01:30 AM   #380
kanundrum
Wonder what track times were Ok i should sleep now
Old 07-01-2012, 03:23 AM   #381
LSV8
Drives: Very fast
Are the KW shocks mono tube..? Inverted design..?
lmk, thx!
LSV8 is offline   Reply With Quote
Old 07-01-2012, 09:30 AM   #382
ubersoph
Looking forward to seeing results at CenDiv! Wish I could be there to see it.
ubersoph is offline   Reply With Quote
Old 07-01-2012, 09:35 AM   #383
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
lmk, thx!
http://www.kw-suspension.com/us/index.php
direct from KW's website. they have a variety of designs... their Clubsport models are INVERTED.. but I think the Var3's are monotube...
This is for the Var 3's
State-of-the-art technology from motor sports for more performance on the road. The separate and independently adjustable rebound- and compression damping allows for an individual suspension setup for different uses and preferences. The unique patented system with its two-stage valves allows a rebound damping adjustment (comfort) and a compression adjustment (driving dynamics) in the low-speed range while the high-speed range which controls the driving safety, is fixed.
  • Damping technology with individually adjustable rebound- and compression technology
  • inox-line* stainless steel technology
  • Individually height adjustable
  • Adjustment parameters approved by the German Technical Control Board (TÜV)
  • High-quality components for long durability
  • Infinitely variable rebound damping adjustment
  • 14-way adjustable compression damping
  • Unique, individually working damping force adjustment
  • Comprehensive documentation for easy use
Scooby South is offline   Reply With Quote
Old 07-01-2012, 10:57 AM   #384
track_warrior
Track Junkie
track_warrior's Avatar
Drives: Faster than the Stig!
Originally Posted by Scooby South View Post
ok....KW's are ON...OMG...it is a sexy beast and man is it 'PLANTED'..... There is at least an inch of clearance between the tire and the Strut... sooo Camber isn't going to be an issue...AT ALL.. will easily fit 265's..if needed... So...STX...STR.....BRING IT...Its amazing how much Decent suspension does to a car...Installation...I give a 6...the front was no problem..however the ABS and Brake line is routed kinda funky..but I adapted and overcame the Rear.. was a bit more stubborn...but I got it...finally.. Stock 14mm rear sway is on now..with Kartboy links..running Recommended settings for now.. went on a short 'test' drive... I can't wait to get this thing on the course now......I LOVE the KW's...easy to tune... and pretty easy to adjust....I was going to have an event tomorrow but I didn't get to the alignment ...so Monday after work...then I also need to corner weight it.....so far...I am absolutely Beyond pleased with the KW's...They Got it right....On to the pics..
Stock Front Strut assembly....12.6 lbs...
KW Front Strut assembly... 12.9 lbs...
Fronts.... adjusting the ride height..
Front ...After adjustment...about a 1 inch gap between the top of the tire and fender... Coool thing of note...All 4 fenders are Factory Rolled..so nooo issue whatsoever with fitment...
Obligatory Side shot..
and...the Side Profile shot...soooo Sexy..
Can't wait for Cent Divs Next week in Milwaukee.... running up our good buddy Neal Tovsen...and his wife in STX...should be interesting.. ...we'll see how it does against a well prepped Bimmer..
More later
Bill
Congrats man!! It looks amazing!! Made me hate vivid racing for keeping me waiting on my set .
How low did you set it? It looks great at that height!! Looks like we will be running the same setup
Compensating a heavy car with horsepower is like giving an alcoholic cocaine to sober him up...
track_warrior is offline   Reply With Quote
Old 07-01-2012, 11:00 AM   #385
Scooby South
Conedancer
I am basically an inch off the tire all the way around... it could go lower..but not functional...Control arms are pretty much Parallel like they are supposed to be..
Bill
The Following User Says Thank You to Scooby South For This Useful Post:
track_warrior (07-01-2012)
Old 07-01-2012, 11:03 AM   #386
track_warrior
Track Junkie
Bill
I agree looks perfect the way it is!! Bet you are liking your RS3's as well!! I love how in control they make the car feel not too much grip or too little just right.
Old 07-01-2012, 11:49 AM   #387
Scooby South
Conedancer
well...I kinda glad I waited to get my alignment... after driving around for about 30 miles..and letting it sit overnight...it seems that the suspension settled a bit... nothing huge...but maybe a 1/4 in or so... I have to remeasure to see for sure....
Bill
Old 07-01-2012, 01:26 PM   #388
track_warrior
Track Junkie
Bill
Pic please!! and thanks for the tip on breaking them in.
Old 07-01-2012, 06:17 PM   #389
Scooby South
Conedancer
Spaceywilly (07-02-2012)
Old 07-01-2012, 06:39 PM   #390
track_warrior
Track Junkie
Looks perfect!! Hopefully you have no rubbing issues when autoxing so you can leave it at that height since it looks perfect!!
Cheers man
Old 07-02-2012, 10:11 PM   #391
*KID*
86-er
*KID*'s Avatar
Drives: BRZ tS
DAM that looks beautiful. Perfect Stance, and perfect meat on them wheels.
2018 Subaru BRZ ts 020/500 - My Daily, work car, and track car
*KID* is offline   Reply With Quote
Old 07-02-2012, 10:28 PM   #392
jamal
jamal's Avatar
Drives: Legacy GT
V1,2,3 and clubsports are twin-tube, not inverted.
Some of the KW Race stuff is mono-tube but I'm not sure they make many inverted shocks. Some have a big sleeve with a linear bearing for reinforcement, which looks like an inverted shock but is not (wrx and evo group n 3-ways for example).
edit- this fancy thing for example is not actually an inverted shock:
jamal is offline   Reply With Quote
The Following User Says Thank You to jamal For This Useful Post:
Scooby South (07-02-2012)
Subaru/Scion warranty and autocross Ribface Tracking / Autocross / HPDE / Drifting 55 06-17-2015 08:30 PM
Will you Autocross your 86? Ribface Tracking / Autocross / HPDE / Drifting 131 06-22-2012 05:48 PM
Which autocross class? jpdarty7 Tracking / Autocross / HPDE / Drifting 66 06-21-2012 05:53 PM
FR-S at a CA Autocross oneday Scion FR-S / Toyota 86 GT86 General Forum 57 03-26-2012 03:38 PM
