Old 10-20-2013, 07:05 PM   #379
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Originally Posted by no chrome View Post
Successfully read ecu and uploaded corresponding 1.2 map.
Checksum YES written success YES
When I connect to car, whether key is on or off (not running)
Select tuning, tablet shows: reading tune file, then:
open flash type: professional
Vin number
Ecu file BLANK
hw 100
Fw 116
Also strangely it wants to calibrate its screen every time I connect to anything
@shiv is there a way I can start over?
If the OFT is stuck in a endless calibration request loop, it's because you are probably using your fingers which, if they are like mine, are too dull for calibration purposes. To sort things out, just plug the OFT into your car (unplug from laptop first) and use a stylus to calibrate. That should sort it out. If you don't have a stylus, you can use a ballpoint pen but press very gently to avoid scratching the screen.
Old 10-20-2013, 07:14 PM   #380
no chrome
She said member
Drives: fr-s firestorm
Does not seem to be stuck endlessly
I will try it with my note2 stylus.
Does the rest of that sound right?
EDIT:apparently it was stuck on calibration screen
Now it wants me to update openflash, I can't do that here.
Will have to try from work tomorrow morning, Thanks for getting me one step closer though
no chrome is offline   Reply With Quote
Old 10-20-2013, 07:46 PM   #381
vrtrasura
Drives: 2013 DGM Subaru BRZ
Is this an appropriate place to ask for support?
I got my OFT last week. It successfully did the read from my car. Then I tried to use the SW on win8 and got a bunch of checksum errors (I had installed the patch). The SW worked much better on a win7 machine but now any time I plug it in and press tune it says "Tuning file mismatching. ECU write denied." I'd like to start over and just use Win7. Any advice?
vrtrasura is offline   Reply With Quote
Old 10-20-2013, 07:47 PM   #382
Shiv@Openflash
Drives: 2013 FRS
No problem
let me know if you still need help after the update.
Shiv
Old 10-20-2013, 07:53 PM   #383
Shiv@Openflash
Drives: 2013 FRS
Sounds like you loaded an incompatible file on to your OFT. The good news is that the OFT pre-qualifies the file before writing it to your ECU. If it's incompatible, it won't allow the write. To make things easy, I would suggest starting over again on you win7 laptop since you say the software works better. Just delete the tune file you loaded on to the laptop and reload them. Make sure you see the window saying that "checksum has been corrected" after selecting the file to load. After that, you should be good to go. If you still have any questions, feel free to call us up tomorrow during work hours and the guys can walk you through the process step by step over the phone.
Cheers,
Shiv
Old 10-20-2013, 08:27 PM   #384
vrtrasura
Even when I have no files on the OFT it still shows that message "Tuning file mismatching. ECU write denied.". I think maybe my original file is corrupt? Is there a way to delete that and start totally fresh? I can't seem to remove it from the OFT.
Thanks!
Old 10-20-2013, 08:31 PM   #385
Shiv@Openflash
Drives: 2013 FRS
Thanks!
Yes, you can erase the entire OFT an start over from scratch. Just to confirm, you haven't flashed the ECU yet? You just did the read, correct?
Old 10-20-2013, 08:44 PM   #386
vrtrasura
Yes, I'd only done a read. I tried an erase (seemed to do something). Tried in the car to do a read again but when I click the tuning tab I get the same message. Now in the SW when I go to download or upload it says IDS_PRESENT under original file as if it was not erased. The erase button is grayed out so I cannot erase again. When I go to the backup screen is says the device has never been used.
I very much appreciate your time, my work hours coincide with the shops so calling for support during the week is hard for me.
Old 10-20-2013, 08:56 PM   #387
Shiv@Openflash
Drives: 2013 FRS
PM'd you
Old 10-21-2013, 12:38 PM   #388
overlookedx
overlookedx's Avatar
Drives: 2015 WRB Limited
I tried everything but I can't edit the launch control tables without TunerPro crashing.
I open the stock intake file, go to the "Launch Control RPM Delta" table, change its value, commit the changes, then save the .bin file as a new file. I can open that new file just fine, but if I try to edit the "Launch Control RPM Delta" table again, the program crashes.
I've tried it multiple times, reinstalled the program, ran the patch, but it still crashes every time. Any help?
Superfast Jellyfish
overlookedx is offline   Reply With Quote
Old 10-21-2013, 01:04 PM   #389
Shiv@Openflash
Drives: 2013 FRS
Make sure you are running the newest version (v5.00.8200) of Tuner Pro. It can be downloaded HERE.
Earlier versions had a bug causing software crashing when editing 32 bit data. The newest update fixes that
Old 10-21-2013, 01:05 PM   #390
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Drives: Lexus IS-F Series 2
@shiv@vishnu Please check your email regarding recent order
Thanks!
2URGSE
JPxM0Dz is offline   Reply With Quote
Old 10-21-2013, 01:18 PM   #391
CamryDS
Drives: 2003 Camry Blue | 2013 FR-S White
Could this be an I/O problem on the disk maybe or even the file that was downloaded was written to disk with errors? Not sure, if you're on windows 8 it could be the new kernel it's using that's causing this problem. Just throwing possibilities out there.
CamryDS is offline   Reply With Quote
Old 10-21-2013, 01:29 PM   #392
Shiv@Openflash
Drives: 2013 FRS
Thanks!
If you sent an email to sales@vishnutuning.com, you should get a response today.
cat overtemp
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
OpenFlash Tablet Stg 2 Tune (Dyno Progress) Rombinhood@OpenFlash Software Tuning 26 10-24-2013 01:19 PM
FBM Tuning fixed my issue, FA20 and Visconti didn't work as well whitefrs Forced Induction 253 08-19-2013 12:39 PM
