Old 02-03-2014, 12:39 PM   #379
JordanWho
JordanWho's Avatar
Drives: Ford Focus RS & Toyota 86 GTS
Originally Posted by TylerLieberman View Post
Idk for sure. The diff risers do raise the diff up within the subframe, but in order to install it, you gotta pull the subframe anyways. I'd just do it all at once since the subframe is already off. $200 USD for both sets.
More than worth it. Now PBM just needs to release their knuckle kit and a rear drop spindle setup
I already replaced my subframe bushings with Whiteline bushings hence just wanting to do diff.
JordanWho is offline   Reply With Quote
Old 02-03-2014, 12:43 PM   #380
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
I'd like to say yes because the axles connect to the diff which are bolted to the subframe. If you raise the diff, that should eliminate some of the axle angle.
Idk about the individual gains though. Makes me curious if the diff raisers raise the diff by 20mm by themselves. If that's the case, then raising the subframe an additional 20mm after that would help eliminate a HUGE CHUNK of the axle angle.
That would be badass
TylerLieberman is offline   Reply With Quote
Old 02-03-2014, 01:00 PM   #381
JordanWho
JordanWho's Avatar
Well according to this link, that's actually seems to be the case...
They separate each product and claim that the diff riser gives you the 20mm for the axles and the subframe bushes seem to be targeted at handling and fixing roll center.
http://www.partsshopmax.com/e107_plu...opic.php?19215
That's how I read it anyway...
Old 02-03-2014, 01:10 PM   #382
TylerLieberman
Drives: '24 GR86
Seem to be right. So you raise the diff 20mm, then raise the whole subframe another 20mm.
So by doing both, you could effectively raise the diff by nearly 1.5" in the end.
Old 02-03-2014, 01:45 PM   #383
JordanWho
JordanWho's Avatar
The Drifting Thread
Mmmmm I don't think you get another 20mm from doing the subframe kit. If that was the case, surely they would of mentioned it in that post? Id say the subframe kit would be around 5-10mm.
The only thing that concerns me about the diff riser kit is having to weld in the subframe mounts.
We really need someone from PSM on here to clarify. I might compile all this and email them again.
Old 02-03-2014, 08:58 PM   #384
TylerLieberman
Drives: '24 GR86
I'd say 10mm at least. You're grinding down the top section where the subframe mounts meet the bottom of the chassis cause the bushings are recessed. Still over an 1" of correction.
As for the diff risers, so long as you have somebody who can weld well, I don't see it being an issue
Old 02-04-2014, 01:20 PM   #385
SubiePig
Drives: -'02 PSM WRX, '94 Miata, '13 BRZ
[ame="https://www.youtube.com/watch?v=93vgiIooXEw#t=130"]FRS DRIFT FAIL - YouTube[/ame]
Sponsered by:Chasebays/Corr Performance Tuning/KartBoy/Bad Panda Motorsports/Racer-X Fabrication
STX Build thread 14th/67 SCCA Nationals (2014)
SubiePig is offline   Reply With Quote
Old 02-04-2014, 04:34 PM   #386
Ryaquinn
Ryaquinn's Avatar
Drives: FRS
No bueno. Glad your okay. It seemed like you were inducing a lot of understeer with your throttle control throughout the video.
Ryaquinn is offline   Reply With Quote
Old 02-04-2014, 06:12 PM   #387
SubiePig
That was a video from a drift event a few months back here in Lousiana. Guy just tried to sell that car for $27k "never wrecked" cause thats what he owns on it with 26k miles. Sold me a set of Gram Lights a month before that that when I pulled the tire off there was a 3" weld bend at the spoke. He is thick headed.
"never wrecked"
\/ STX build thread, white car, don't drift.
Old 02-04-2014, 06:23 PM   #388
Chase Bays
Chase Bays's Avatar
Drives: FR-S | 335i | S13
but driftingisfun
Chase Bays is offline   Reply With Quote
Old 02-04-2014, 11:54 PM   #389
Verbal21
Verbal21's Avatar
Drives: 370Z
Between DSS axles, PBM diff risers AND subframe risers, I feel like I'll never have an axle issue again.
Once it gets on the car, I'll probably end up dropping the car down close to another inch.
How much does a setup like that run?
Verbal21 is offline   Reply With Quote
Old 02-05-2014, 12:09 AM   #390
TylerLieberman
Drives: '24 GR86
$200 for everything....provided you know how to do the work yourself.
Old 02-05-2014, 12:20 AM   #391
Verbal21
Verbal21's Avatar
Drives: 370Z
Oh, I must've been looking at something different then. I saw the 600hp axle going for $1K.
Old 02-05-2014, 10:45 AM   #392
nlamon33
nlamon33's Avatar
Drives: 2013 SWP BRZ Limited
Man I want to say I could tell he was about to lose it, but I don't think he ever really had it! I think those are the slowest moving hands I've ever seen.
nlamon33 is offline   Reply With Quote
Is there a thread for 'people doing stupid things in their brand new car' thread? Symbiont FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 36 02-18-2013 12:24 PM
BRZ Drifting. Hunter BRZ Photos, Videos, Wallpapers, Gallery Forum 7 09-20-2012 08:57 AM
So Cal drifting Thefear13 Scion FR-S / Toyota 86 GT86 General Forum 0 08-10-2012 04:53 PM
REAL drifting thread TylerLieberman Off-Topic Lounge [WARNING: NO POLITICS] 17 02-28-2012 04:20 PM
FT-86 II (RC) Drifting ft86cbx FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 8 11-11-2011 02:02 AM
