Old 04-13-2014, 01:04 AM   #379
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Hello
Sent from my IBrick
Old 05-07-2014, 02:14 AM   #380
mattbenich
mattbenich's Avatar
Drives: 2014 FRS Monogram
Wheel Directory: Enkei RPF1 17x9.0 +35
Got a question for this thread...
How can you run a 17x9 +35 or +45 if they don't offer it in a 5x100 bolt pattern?
I was looking at the spec sheet and I don't see that 5x100 offered...is it a custom order?
http://enkei.com/size_chart/RPF1.pdf
mattbenich is offline   Reply With Quote
Old 05-07-2014, 02:30 AM   #381
CladMonitor
CladMonitor's Avatar
Drives: 2013 FR-S Asphalt
Enkei no longer sells many color size combinations to the public. They have licensed companies like oakos.com to have sole access to them.
CladMonitor is offline   Reply With Quote
Old 05-07-2014, 02:31 AM   #382
CladMonitor
Originally Posted by fooddude View Post
@CladMonitor: Nice! ...btw, did you paint your own tails? Looks really good, oem(not dark red) and shiny. Which red paint and clear coat did you use? Enamel mixed clearcoat?
Sorry didn't see your question, I painted the tails and the headlights myself. I used VHT Nightshades and perfect match clear. This combined with a lot of hand wet sanding and buffing/polishing got it to that look.
Old 05-07-2014, 02:37 AM   #383
mattbenich
mattbenich's Avatar
I didn't mean specific colors I just meant just the bolt pattern? I just assume that people are special ordering them and not swapping there hubs to 114.3's....
Old 05-07-2014, 02:39 AM   #384
CladMonitor
Matt I'm saying they are not special order but the size color (inc bolt patterns) are licensed away from Enkei so they do exist. For example:
http://www.oakos.com/Merchant2/merch...ode=Subaru-BRZ
The Following User Says Thank You to CladMonitor For This Useful Post:
mattbenich (05-07-2014)
Old 05-07-2014, 02:40 AM   #385
mattbenich
mattbenich's Avatar
Ah I figured it was something like that, thanks for the info, I am going to look into the other companies.
Old 05-07-2014, 02:42 AM   #386
CladMonitor
No problem. If you find what you want on oakos you can use the manufacture part number to search the net using google.
Oakos is pretty cheep btw, no one could get them to my door cheaper. There was no tax and no shipping.
Old 05-09-2014, 02:55 AM   #387
wrussi
wrussi's Avatar
Drives: 2013 frs
17x9 35 on 255/40/17 RE-11A
wrussi is offline   Reply With Quote
The Following 3 Users Say Thank You to wrussi For This Useful Post:
akahenry (06-14-2014), Goya (05-09-2014), mit_peid (05-12-2014)
Old 05-09-2014, 02:55 AM   #388
SmsAlSuwaidi
Boosted
Camber specs + lowering choice ?
Sent from my IBrick
Old 05-09-2014, 08:12 AM   #389
wrussi
wrussi's Avatar
Drives: 2013 frs
Sent from my IBrick
-2.8 on the front and natural -2.5 on the rear lowered on BC coils
Old 05-09-2014, 01:52 PM   #390
Silver Ignition
APEXHNTR
Silver Ignition's Avatar
Drives: 10 Series FR-S #1867
any rubbing issues?
2013 Sc10n FR-S 10 Series
#1867 of 2500
in the garage...2001 Toyota 4Runner [Solid Axle Rock Toy], 1987 Pontiac Fiero GT [Shitwagon], 2004 Honda Interceptor VFR800 [daily rider], 1978 Suzuki GS750 [Café Racer]
Silver Ignition is offline   Reply With Quote
Old 05-12-2014, 12:27 PM   #391
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
Anybody else running 17x9 +35 and 245/40/17 with Eibach Pro-Kit (1" drop) and only camber bolts. Any rubbing? How much poke do you have if you maximize the negative camber in front? Any fender work needed?
mit_peid is offline   Reply With Quote
Old 05-12-2014, 07:54 PM   #392
Silver Ignition
APEXHNTR
I plan on doing it, only with Tein S-Techs.
#1867 of 2500
Wheel Directory: Enkei RPF1 17x9.0 +45 LevinPhan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 265 06-04-2024 11:13 AM
Group Buy: Enkei RPF1 17x9 +35, 17x9.5 +38, 18x9.5 +38 ***In Stock*** LSD Motorsports Groupbuys 246 08-29-2013 01:35 PM
WHITE Enkei NT03+M 18x9.5 / Enkei RPF1 17x9 Touge Factory Wheels and Tires 2 02-05-2013 04:53 PM
