Old 08-08-2015, 11:44 AM   #3865
jdnguyen
jdnguyen's Avatar
Drives: 2013 FR-S Series 10 and 2010 Camry
Originally Posted by jdv14476 View Post
What are you putting on in it's place?
FT86 velox rear diffuser
jdnguyen is offline   Reply With Quote
The Following User Says Thank You to jdnguyen For This Useful Post:
Blu-by-U (08-11-2015)
Old 08-10-2015, 12:38 AM   #3866
ka-t_240
Originally Posted by KevinK121 View Post
The other negative thing is that no tuner around here tunes with the oft compatible software. FBM uses ecutek, I forget what shane uses, Jordan uses BRZedit. Jordan said he'd try it if I bring the software and whatnot.
OFT uses RomRaider... Anyone who tunes subarus should be able to tune with an OFT. Call and talk to Ron at RS. I have no complaints with my OFT tunes, I am on E85 tho... The stage 2 EL tune was a big plus over the stock map.
ka-t_240 is offline   Reply With Quote
Old 08-11-2015, 10:57 AM   #3867
KevinK121
Miata traitor
KevinK121's Avatar
Drives: 2002 Miata SE
Hows your throttle response? Mine is absolutely terrible. I think thats the source of my dissatisfaction.
KevinK121 is offline   Reply With Quote
Old 08-11-2015, 11:11 AM   #3868
stokeless
stokeless's Avatar
Drives: 2020 BRZ PP Silver
did you follow the appropriate steps? my throttle is fine. How long has it been since you uploaded the tune? if you touch the throttle before the ecu calibrates the new tune, you can have some dead spots when you hit the gas pedal. it should eventually self-adjust though.
stokeless is offline   Reply With Quote
Old 08-11-2015, 11:16 AM   #3869
KevinK121
Miata traitor
KevinK121's Avatar
I saw that bit. Maybe Ill try reloading it.
From what I remember it just said to let it idle for 45 seconds before driving it. Other than that I dont remeber it having any other tips for letting it learn.
On the e85 tune I know its dont drive it hard until the ecu learns the blend.
I uploaded it a few weeks ago.
I just remember the throttle response was the first thing I noticed on the test drive. DBW sucks. Looks like you can tune it out though. I really need to get into RomRaider and start playing with settings.
Old 08-11-2015, 11:22 AM   #3870
TMF
TMF's Avatar
Drives: '14 FRS TT5
I think my throttle is plenty responsive on my car...it is still stock though
Who in Minnesota even does custom tunes for the twins? RS?
TMF is offline   Reply With Quote
Old 08-11-2015, 11:25 AM   #3871
KevinK121
Miata traitor
KevinK121's Avatar
SM Speed (Jordan previously of MAP) uses BRZ Edit but said he'll try OFT if I bring in all the required hardware/software. LJ at Full blown uses ECUTek. Shane at DB uses.... I dont remember what he uses but it's probably ECUTek if he's even done any 86's. I've never dealt with Ron/RS.
Forgot about NF but Im sure theyd be willing to tackle it. Also probably on ECUTek.
Old 08-11-2015, 11:29 AM   #3872
TMF
TMF's Avatar
Drives: '14 FRS TT5
I see, thanks for the info! I plan on keeping it stock engine-wise for the foreseeable future, but that is good info to have.
The Following User Says Thank You to TMF For This Useful Post:
KevinK121 (08-11-2015)
Old 08-11-2015, 11:52 AM   #3873
stokeless
stokeless's Avatar
I followed these steps when loading my tune, I didn't have an issue with the dead spots.
http://www.ft86club.com/forums/showthread.php?t=71157
My Throttle Pedal has dead spot - car sluggish after Flashing Tune
To minimize any issues and speed up learning after a Flash or Reset
  • Turn ignition fully off after a flash or reset
  • Turn ignition fully ON, do not start car, do not touch throttle, leave for 20 sec this will allow ECU to perform its diagnostics and calibrations on cam position and throttle position sensors
  • Turn off ignition
  • Turn on ignition leave for 20 sec then start car do not touch throttle
  • Let car idle for at least a minute and wait till it settles at the normal idle of about 750 RPM, again do not touch throttle.
  • After normal idle is achieved then drive car.
The Following User Says Thank You to stokeless For This Useful Post:
Old 08-11-2015, 12:00 PM   #3874
KevinK121
Miata traitor
KevinK121's Avatar
Ill give it a shot, tyvm
Old 08-11-2015, 12:01 PM   #3875
stokeless
stokeless's Avatar
give it a shot
Old 08-11-2015, 01:13 PM   #3876
KevinK121
Miata traitor
KevinK121's Avatar
Anyone planning on going to DCTC this Thursday for test and tune? Or the 21st for MNTA event #3?
Well I know ka-t is probably going on the 21st.
Old 08-11-2015, 02:56 PM   #3877
TMF
TMF's Avatar
Drives: '14 FRS TT5
Yep, I'll be at the test n tune this Thursday, but I'll be helping out/instructing. I'll probably take my car out for a few laps too, but I'll be on the prius tires (I need to save my RE71's for autox nats). I unfortunately won't be able to make the event on the 21st due to a wedding
Old 08-11-2015, 03:27 PM   #3878
KevinK121
Miata traitor
KevinK121's Avatar
I was going to try and make it. I should be getting tires and wheels mounted tonight but the suspension won't be done until Thursday at the earliest. I might skip the suspension and just come by to watch my friend in his SI.
Check in, eh? NorthFool CANADA 24 02-23-2012 07:32 AM
*NSFW* "Check Out My Subaru" on You Tube Axel Other Vehicles & General Automotive Discussions 4 01-17-2010 05:56 PM
how do you check a site 4agze Off-Topic Lounge [WARNING: NO POLITICS] 3 11-21-2009 09:27 PM
Video of FT-86 @ TMS from Edmunds. Check out how small the car is next to people. JDMinc FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 9 10-25-2009 08:53 PM
