Old 04-04-2016, 03:05 PM   #3809
D-VO
Drives: Whiteout FR-S, Evo 8 RS
Originally Posted by vgi View Post
can't spot it, would you pls highlight it
btw, did u get revised pulleys?
*Edited my OP* (#3821)
I have a feeling they don't want to give it to me. I spoke with CJ once about it and he seemed to know quite a bit. He wanted me to read off the code on the pulley for him but I couldn't see it at the time. It seems that I am still running the old set up with the 40T-100 crank pulley. I called back again and someone else picked up telling me that a rep. had to email me about it. Is that what you had to go through?
D-VO is offline   Reply With Quote
Old 04-04-2016, 05:00 PM   #3810
vgi
Drives: frs
ah, nope. CJ had told me that they had revised the pulleys and that I should not buy the belt as new pulleys would come with the new belt. The only thing he asked for is to provide the name and kit purchase confirmation. He is an absolutely amazing guy to deal with. They do have at least 1 knucklehead on their phone support who I bumped into when I ordered my c38 kit which was shipped with the c30 outlet rubber pipe - he tried to convince me that I'd need to come up with an adapter, so beware. Just email and/or pm to CJ or when you call try to get hold of him. They should keep the record themselves to whom they have shipped already the pulleys.
vgi is offline   Reply With Quote
Old 04-04-2016, 06:53 PM   #3811
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
Originally Posted by Sgtfluffy16 View Post
I bought My kit back in October 2015. I have not installed it yet. When was this updated pulley released? Wondering if I have the old setup or the new up-to-date setup
128mm crank pulley and 95mm SC pulley is the new setup.
Freeman is offline   Reply With Quote
Old 04-04-2016, 07:31 PM   #3812
D-VO
There's a code thats etched on the crank pulley. 40T-100 is the old one (Which I have) and 51T-128 is the new one.
51 teeth 128mm diameter
Old 04-04-2016, 07:52 PM   #3813
vgi
Drives: frs
it's been a while, at least a year. i think all 2015+ kits should have the new pulleys.
Old 04-04-2016, 08:08 PM   #3814
AZbrz89
Drives: 14 BRZ Crystal Black Silica Limited
I purchase mine Dec of 2014. Am I good?
Sent from my SM-G920V using Tapatalk
AZbrz89 is offline   Reply With Quote
Old 04-05-2016, 09:45 AM   #3815
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
Ok now it's my turn. My belt was losing teeth and getting really noisy and eventually broke. I have been very persistent with checking tension but the app is hard to use so I have defaulted to the twist method. Over the fall I believe the temp ranges may have made my belt too loose and it was slapping a lot when cold so I had it tightened a bit. I was only checking tension when fully warmed up and was able to twist to a little past 90 degrees. Thinking that slightly loose was better than too tight. I'm thinking now that the twist should be just hitting 90 degrees.
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
Old 04-06-2016, 12:45 AM   #3816
D-VO
How many miles did you put on the belt?
Old 04-06-2016, 12:57 AM   #3817
Apoc
Apoc's Avatar
About 10000 miles.
“The World is Flat”
[||•]=(86)=[•||]
Old 04-06-2016, 11:43 PM   #3818
D-VO
Hey man. CJ is sending me the new set up. I forgot to ask what all was involved. Did you have any difficulty changing out the pulley on the C38 unit?
About 10000 miles.
Sounds about right.
Old 04-07-2016, 02:07 PM   #3819
vgi
Drives: frs
nah, not really, just unbolted the plate and leaned it forward, didn't disconnect anything though.
since you're in touch with CJ, could you pls ask for the part# for the new belt? i don't think we have it here anywhere yet
Old 04-07-2016, 02:40 PM   #3820
Apoc
Apoc's Avatar
New belt for the 128/95 pulley set should be TP1280-8MGT-20
“The World is Flat”
[||•]=(86)=[•||]
The Following 3 Users Say Thank You to Apoc For This Useful Post:
D-VO (04-07-2016), Freeman (04-07-2016), vgi (04-07-2016)
Old 04-07-2016, 07:24 PM   #3821
D-VO
@digital_assassin
Could you attach this to the OP please?
Here's the link for the new belt through Gates:
http://www.biedlers-belts.com/gates-...t-20-belt.html
Old 04-10-2016, 05:32 PM   #3822
mscamp02
Drives: 2013 FRS
Pullet is toast to S/C is toast screws backed out. Actually was kinda lucky because I was doing a random check and noticed the pulley wobbling, well while I was watching it wobble trying to remember how I had to attach it or if it was a bearing or something going out it snapped the last bolt or two that was holding it causing it to jump and grind.
I got the pulley and belt off after pulling the main bracket off its mounts. Looks like I'll have to reflash back for a while until I can get a new pulley, no damage to s/c at least.
mscamp02 is offline   Reply With Quote
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 10:58 PM
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 12:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 12:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 05:27 PM
