#3809 |
Drives: i have not any car,
To get the best type of knowledge, this website will help in many matters. So, must visit it and get benefit from the data.
#3810 | |
Drives: 2018 Subaru BRZ
I have not any car. I fckn love these bots.
#3811 |
LMGTFY
Drives: 13 FRS, 91 Miata
#3812 | |
Hey what operating temps are you seeing? I got 85C while a doing a quick match. Should I have the GPU at balanced settings and not Quiet? Sent from my iPhone using Tapatalk
#3813 |
ProCrastinationConsultant
at least remove the hyperlink, otherwise, you're spam!
#3814 | |
friendly
Drives: 17' 86
85c is perfectly fine I wouldn't worry unless you go over 90c core and over 100c junction. I'm on water so I'm usually ~40-45c core and 55c junction.
Seek comfort in discomfort.
#3815 | |
I wonder if the temperature reported by Warzone is core or junction. I'll have to enable the AMD performance monitor to look at temps. Right now I have it on balanced and temps were in the high 70s and low 80s. It is an absolute monster though, I might need to set a limit on the FPS to prevent screen tearing, I was in the upwards of 240 FPS at 1440 on normal, around the same at 1080 on Ultra settings.
| The Following User Says Thank You to spcmafia For This Useful Post: | p1l0t (04-22-2022) |
#3816 | |
TRACKBREAD
Put down the diagnostics and play the game! If nothing’s throttling, it’s fine. The temps in the factory fan curves and boost clock tables are conservative enough. Unless your fans are maxed out and you have throttling/crashing issues don’t worry about temps. |
| The Following 5 Users Say Thank You to Yoshoobaroo For This Useful Post: | alphasaur (04-21-2022), p1l0t (04-22-2022), spcmafia (04-20-2022), weederr33 (04-20-2022), x808drifter (04-20-2022) |
#3817 | |
That's the thing, even thought this card is pretty amazing in terms of performance, some games are not optimized for the AMD drivers. Warzone to be exact still suffers from stutters. It has been reported that the game will crash and the GPUs not functioning correctly. I also don't know if it's throttling because the in-game performance monitor can only show me so much on what is actually happening, I had to do the same with the 3070ti, took some tweaking, but I got it to where the temps where consistent along with performance. Had I switched to another NVIDIA GPU I would probably be fine, but I switched companies so I have to re-learn everything.
| The Following 2 Users Say Thank You to spcmafia For This Useful Post: | p1l0t (04-22-2022), Yoshoobaroo (04-20-2022) |
#3818 |
Sold the 3070ti within hours of posting on my workplace forums. Asking $600, got the same amount. Not great, considering what I paid, but I guess it just gives me joy to being able to give someone a long awaited GPU. Can't bring myself to up-sell things.
| The Following 2 Users Say Thank You to spcmafia For This Useful Post: | p1l0t (04-22-2022), Yoshoobaroo (04-22-2022) |
#3819 | |
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
| The Following User Says Thank You to Dadhawk For This Useful Post: | p1l0t (04-22-2022) |
#3820 |
Well, got the temperature thing sorted out. The BIOS fan curve settings were set to stock. Mainly because my radiator is front-mounted and linked to the CPU, it only cools as much as the CPU needs and not the whole case. Is a little louder now, but the temps have significantly gone down all around. CPU sits around 42C and GPU around 65-68ish at core.
| The Following User Says Thank You to spcmafia For This Useful Post: | p1l0t (04-24-2022) |
#3821 |
Re-did the cabling and synced everything thru iCue. Computer is set!
![]() Sent from my iPhone using Tapatalk
| The Following 5 Users Say Thank You to spcmafia For This Useful Post: | Dadhawk (04-28-2022), p1l0t (04-28-2022), soundman98 (04-27-2022), Spuds (04-29-2022), weederr33 (04-28-2022) |
#3822 |
The Dictater
Drives: '13 Red Scion FRS
Currently working up a new PC build.
RTX 3080s are almost reasonably priced... |
| The Following User Says Thank You to Spuds For This Useful Post: | spcmafia (04-29-2022) |
| Tags |
| pc master race, u no have 3080 |
| gamers lounge | Touge_ninja | Off-Topic Lounge [WARNING: NO POLITICS] | 25 | 01-21-2014 05:32 PM |
| GT Acadamy Gamers Banned from Britsh GT Pro-Am | WingsofWar | Off-Topic Lounge [WARNING: NO POLITICS] | 16 | 02-11-2013 07:37 PM |
