Old 04-19-2022, 12:29 PM   #3809
Zara browne
Drives: i have not any car,
To get the best type of knowledge, this website will help in many matters. So, must visit it and get benefit from the data.
Zara browne is offline   Reply With Quote
Old 04-19-2022, 12:34 PM   #3810
spcmafia
spcmafia's Avatar
Drives: 2018 Subaru BRZ
I have not any car. I fckn love these bots.
spcmafia is offline   Reply With Quote
The Following 2 Users Say Thank You to spcmafia For This Useful Post:
p1l0t (04-19-2022), weederr33 (04-19-2022)
Old 04-19-2022, 04:33 PM   #3811
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Better than the one that drives "Japan"
The Following 2 Users Say Thank You to x808drifter For This Useful Post:
p1l0t (04-19-2022), spcmafia (04-19-2022)
Old 04-19-2022, 07:26 PM   #3812
spcmafia
spcmafia's Avatar
Originally Posted by alphasaur View Post
If you're not doing heavy overclocking you're fine with a quality 6-700 watt psu.
I currently run an rm850x with a 6900xt, 5900x, rx480 on a big water loop with lots of fans 3x hdds and 2x nvme drives. At peak I believe I pull ~650 from the wall.
Hey what operating temps are you seeing? I got 85C while a doing a quick match. Should I have the GPU at balanced settings and not Quiet?
Old 04-19-2022, 11:02 PM   #3813
soundman98
ProCrastinationConsultant
soundman98's Avatar
at least remove the hyperlink, otherwise, you're spam!
Old 04-19-2022, 11:27 PM   #3814
alphasaur
friendly
Drives: 17' 86
Hey,
85c is perfectly fine I wouldn't worry unless you go over 90c core and over 100c junction.
I'm on water so I'm usually ~40-45c core and 55c junction.
Seek comfort in discomfort.
alphasaur is offline   Reply With Quote
The Following 2 Users Say Thank You to alphasaur For This Useful Post:
p1l0t (04-22-2022), spcmafia (04-20-2022)
Old 04-20-2022, 08:46 AM   #3815
spcmafia
spcmafia's Avatar
Hey,
I wonder if the temperature reported by Warzone is core or junction. I'll have to enable the AMD performance monitor to look at temps. Right now I have it on balanced and temps were in the high 70s and low 80s. It is an absolute monster though, I might need to set a limit on the FPS to prevent screen tearing, I was in the upwards of 240 FPS at 1440 on normal, around the same at 1080 on Ultra settings.
The Following User Says Thank You to spcmafia For This Useful Post:
p1l0t (04-22-2022)
Old 04-20-2022, 10:12 AM   #3816
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Put down the diagnostics and play the game!
If nothing’s throttling, it’s fine. The temps in the factory fan curves and boost clock tables are conservative enough. Unless your fans are maxed out and you have throttling/crashing issues don’t worry about temps.
The Following 5 Users Say Thank You to Yoshoobaroo For This Useful Post:
alphasaur (04-21-2022), p1l0t (04-22-2022), spcmafia (04-20-2022), weederr33 (04-20-2022), x808drifter (04-20-2022)
Old 04-20-2022, 11:56 AM   #3817
spcmafia
spcmafia's Avatar
That's the thing, even thought this card is pretty amazing in terms of performance, some games are not optimized for the AMD drivers. Warzone to be exact still suffers from stutters. It has been reported that the game will crash and the GPUs not functioning correctly.
I also don't know if it's throttling because the in-game performance monitor can only show me so much on what is actually happening, I had to do the same with the 3070ti, took some tweaking, but I got it to where the temps where consistent along with performance. Had I switched to another NVIDIA GPU I would probably be fine, but I switched companies so I have to re-learn everything.
p1l0t (04-22-2022), Yoshoobaroo (04-20-2022)
Old 04-22-2022, 10:17 AM   #3818
spcmafia
spcmafia's Avatar
Sold the 3070ti within hours of posting on my workplace forums. Asking $600, got the same amount. Not great, considering what I paid, but I guess it just gives me joy to being able to give someone a long awaited GPU. Can't bring myself to up-sell things.
p1l0t (04-22-2022), Yoshoobaroo (04-22-2022)
Old 04-22-2022, 11:54 AM   #3819
I have ALWAYS used AMD/ATI video cards, all the way back to the VGA Wonder card. I have never had a video game issue I'm aware of, but of course unless I was using both I might not realize it was a problem and not a feature.
p1l0t (04-22-2022)
Old 04-23-2022, 11:49 AM   #3820
spcmafia
spcmafia's Avatar
Well, got the temperature thing sorted out. The BIOS fan curve settings were set to stock. Mainly because my radiator is front-mounted and linked to the CPU, it only cools as much as the CPU needs and not the whole case. Is a little louder now, but the temps have significantly gone down all around. CPU sits around 42C and GPU around 65-68ish at core.
p1l0t (04-24-2022)
Old 04-27-2022, 10:22 PM   #3821
spcmafia
spcmafia's Avatar
Re-did the cabling and synced everything thru iCue. Computer is set!
The Following 5 Users Say Thank You to spcmafia For This Useful Post:
Dadhawk (04-28-2022), p1l0t (04-28-2022), soundman98 (04-27-2022), Spuds (04-29-2022), weederr33 (04-28-2022)
Old 04-29-2022, 01:00 AM   #3822
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Currently working up a new PC build.
RTX 3080s are almost reasonably priced...
Spuds is online now   Reply With Quote
The Following User Says Thank You to Spuds For This Useful Post:
spcmafia (04-29-2022)
pc master race, u no have 3080
gamers lounge Touge_ninja Off-Topic Lounge [WARNING: NO POLITICS] 25 01-21-2014 05:32 PM
GT Acadamy Gamers Banned from Britsh GT Pro-Am WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 16 02-11-2013 07:37 PM
