02-16-2020, 04:25 PM | #3809 |
Drives: 18 BRZ tS
What do you mean by full conversion? I meant buy an actual tS. Did the tS get disallowed from STX?
Sent from my LG-H932 using Tapatalk |
02-17-2020, 08:15 AM | #3810 | |
Kyle H. - #89 STX
02-17-2020, 11:33 AM | #3811 |
Drives: 2015 Series Blue BRZ WRB
Can you explain a full conversion, and how to ensure you convert it properly? ex. you need XYZ and dont need ABC from a standard brz to a TS
02-17-2020, 02:39 PM | #3812 |
Drives: 2013 FRS
02-20-2020, 11:04 AM | #3813 |
Drives: '22 BRZ
Full conversion = full conversion. It's easier and smarter to just buy a ts if you want the aero (which doesn't do anything at autocross anyway)
02-20-2020, 12:35 PM | #3814 |
Drives: 18 BRZ tS
02-20-2020, 12:41 PM | #3815 |
In both Street and Street Touring, the rule is that you can convert a car from one spec to another if you do *all* the changes. So if you want package B and it includes an aero kit, springs, seats, and a giant subwoofer then you have to install all of those parts, not just the bits you like. If you want to mix and match, then it's time to move to Street Prepared, which allows update/backdate of any individual part from the same line in the class listing.
-- Bryan Blackwell --
2020 Hakone 86 -- KW V2 6k&9k/Karcepts Sway Bars/SPC&Diftech RCLA/SuperPro bshngs/17x9 RPF1/255-40-17 RT660/Hawk5.0 Pads/RacerX MC Brace |
02-20-2020, 07:22 PM | #3816 | |
I was asking more on clarification of say, all of the exterior pieces |
02-20-2020, 07:25 PM | #3817 | |
Drives: 2017 BRZ w/PP
XS-A might be a cheaper alternative but its region only |
02-20-2020, 07:51 PM | #3818 |
If you're serious about an XSA car I think you'll dump $10k+ into the engine, you'll want to push >350whp methinks, which will eat trannys. You'll be playing on 295-315 wide tires so you're not saving much on tires even though they're 200tw.
Does LPSP allow update backdate? I'd go play in DSP if cost was a concern, the car makes good power on E85 and not cutting the fenders should keep you on <275 tires. A 315/30/18 BFG is more expensive than a 275/35/17 A7. But if competitiveness isn't a priority play with whatever tires make you happy. |
02-20-2020, 10:32 PM | #3819 |
Drives: '22 BRZ
02-20-2020, 10:36 PM | #3820 |
Does something =/= makes enough speed to make up for my shitty driving
02-21-2020, 09:33 AM | #3821 | |
Totes. What's even more stupid is that TT Touring Classes can't benefit from Aero yet they want to drift away from Solo type rule classing to allow tuning in the lowest form of prep level there is to offer. But that's a soapbox for another day
Kyle H. - #89 STX
The Following 2 Users Say Thank You to M0nk3y For This Useful Post: | DocWalt (02-21-2020), strat61caster (02-21-2020) |
02-21-2020, 11:05 AM | #3822 | |
not to split hairs but youd be in XS B since removing the spare would drop you below the 2750lb limit of A |
Similar Threads | ||||
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 02:12 PM |
SCCA sway bar rules | gmookher | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 09-01-2012 06:48 PM |
Suggestion for vendor rules... | Tainen | Site Announcements / Questions / Issues | 31 | 08-15-2012 01:53 PM |
Rules for posting in this section | Hachiroku | User/Vendor/Sponsor Reviews, Feedback, Comments | 0 | 06-25-2012 11:02 AM |
