#365 |
Drives: Yes
It's probably just you getting used to the new engagement point. It's a spindle rod, so the nut being loose shouldn't necessarily allow the rod to rotate that freely by itself, it's just for added security and robustness. When I checked, I didn't notice any change in the pedal height.
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
| The Following User Says Thank You to chas3wba0 For This Useful Post: | 1Cor10:23 (01-10-2014) |
#366 |
Drives: frs
When the pedal is lowered, my pedal has 2-3 mm dead space at the top. It seems the pedal can be pushed in and pulled out of this deadspace without it moving the clutch plates.
Is it okay to move the cruise control sensor into the pedal to get rid of this wiggle space? It doesn't seem to be enough pressure to begin disengaging the clutch, but it does get rid of that annoying empty feeling at the top. Thoughts? |
#367 | |
Drives: swp limited
#368 |
Drives: frs
^^^^^ same here. I dont know if it was like that before but I could press the clutch pedal in for few mm. Other than that. I already got used to the new height.
#369 | |
Drives: Yes
| The Following User Says Thank You to chas3wba0 For This Useful Post: | vincent201089 (01-18-2014) |
#370 | |
Drives: frs
#371 |
Drives: 2013 SWP Limited BRZ, MT
After driving around for a year and a half i finally got to lowering my clutch pedal. At first i made it lower than the brake pedal, and although the engagement feels best here, I missed the compound bow springiness of the clutch. I made it flush or slighly higher than the brake pedal and got the springiness is back... This is where I'm keeping it. In-between normal and absurdly high.
| The Following User Says Thank You to Indestruct For This Useful Post: | ericmpena (01-26-2014) |
#372 |
Drives: Subaru BRZ Limited
It's never bothered me how high the clutch sat until I read this thread. Now I HAVE to adjust it! Thanks!
#373 |
After driving mine for 8 months, my clutch releases at almost the very top of the throw. Never had this happen in any other MT i have driven. What does this mean?
Sent from my Nexus 4 using Tapatalk |
| The Following User Says Thank You to jonbonazza For This Useful Post: | FirestormFlex (04-18-2016) |
#374 |
Much title. Wow.
Drives: 2013 BRZ Sport-Tech
After driving with my seat nearly all the way forward to help get my drunken idgit friends home, I can really appreciate this adjustment.
| The Following User Says Thank You to Deadspool For This Useful Post: | gonzo (01-26-2014) |
#375 |
Drives: SWP BRZ Limited MT
I'm so used to the stock setting now, but still plan on doing it this summer... funny thing is I was all ready to go for adjusting it 2nd week of buying the car last year, but I did not have the correct wrench size out of all my wrenches and decided to just deal with it.
#376 |
Troll Hunter
Drives: fr-s, tundra
Did this today. Tried all sorts of things.
But then I got it to the point I wanted, and the clutch started making a click noise when I put it in and pulled it out. Not like transmission noise, or anything like that. It was purely a pop like a part of the clutch assembly. It's not terrible loud, or sounds bad, but it's a bit obnoxious. I went back to stock height and am still getting it. I didn't move the sensor at all. any thoughts? It's definitely in the cabin. It seems like it may have something to do with the cylinder.
#377 | |
Drives: JAWS
| The Following User Says Thank You to JB86'd For This Useful Post: | 86-tundra (02-04-2014) |
#378 | |
Troll Hunter
http://www.ft86club.com/forums/showthread.php?t=57383 theres a video there too
| The Following User Says Thank You to 86-tundra For This Useful Post: | ericmpena (02-04-2014) |
| Tags |
| clutch adjustment, clutch helper spring |
| power steering feel adjustment | brillo | Engine, Exhaust, Transmission | 29 | 11-06-2017 04:41 PM |
| BRZ front camber adjustment confirmed | sparks | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 21 | 03-28-2013 11:17 PM |
| Any (easy) way to stiffen up the feel of the clutch? | Partial Stall | Engine, Exhaust, Transmission | 41 | 07-19-2012 03:17 PM |
| My Great Experience at Scion of Glendora *LONG, BUT AN EASY READ* | wanger | Scion FR-S / Toyota 86 GT86 General Forum | 5 | 06-02-2012 02:41 PM |
| ATS carbon clutch collaboration model prototype clutch 86 & BRZ | kanundrum | Engine, Exhaust, Transmission | 41 | 02-27-2012 04:48 PM |
