#365 | |
Drives: Scion FR-S
#366 | |
Drives: DGM BRZ limited
Seems like everything related to multiple brushless motors involves trying to run two with the same ESC. |
#367 |
Drives: FR-S 10 #103 AT
In audiophile music they go through a process whereby they make sure that amps of the same type actually produce the exact same output when fed the same signal to keep the sound matched.
Could it be necessary to test the motors to make sure the same input produces the same output? e.g. power, rpm? Given the way the controllers work, the speed should be the same or the motor just won't run, but theory is one thing, reality is often something else.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid." |
#368 | |
Drives: White '17 86
I would guess very light oil, and very little oil is needed. Again balance might be the biggest issue. Never know till it is tried, tested, and broken. |
#369 | ||
The difference between this and "audiophile music" is with speakers, if they aren't matched cancellation will occur. With the motors, I expect them to self regulate to share the load because without load they would all be spinning faster. It won't be possible for one to be driven by another motor. Quote:
#370 | |
| The Following User Says Thank You to mid_life_crisis For This Useful Post: | rusty959 (09-10-2013) |
#371 | |
#372 | |
Drives: Scion FR-S
#373 | |
#374 |
Drives: '13 GBS Subaru BRZ
Sorry there haven't been any updates recently, I've been dealing with health issues and waiting for parts to arrive (I love McMaster-Carr).
I have been starting to test motor/controller/battery setups. One note for those who are planning to use the charge in parrallel/discharge-in-series concept. Many (maybe most) of the RC brushless controllers have a startup delay. For the one I'm using this is about three seconds. Mine also won't start the motor until it sees a neutral input signal. Three seconds is nothing if it powers on when you start the car, but if it only gets power when the system activates then it could be an unacceptable delay. The good news is that the capacitors in the brushless controller can keep it from rebooting if power is removed and restored very quickly (like a relay activating) so this might help with a work around for this issue.
| The Following User Says Thank You to neutron256 For This Useful Post: | rusty959 (09-17-2013) |
#375 |
Thanks for checking on the quick power removal, at least we know one controller can handle a quick period without power. I still need to be careful about finding one that can handle not only short times without power but also a 3x change in voltage.
They aren't the controllers ill be using in the end, but the ones I have laying around have the same neutral input/3 second thing going on as I remember from using them previously. Ive bought some fun stuff to assist in my testing etc, such as some 1/4 inch aluminum, aluminum rod for the motor/gear adapter, and some gears. Assuming everything is here by weekend as it should, I should have a chance to get on a mill over the weekend and make a test setup to throw some motors on. I also picked up an infrared temp sensor which may be of use. I need to get started on my cnc mill soon, thats a big project in itself and is what is going to hold up my e-charger setup from getting very far. But, Ive been busy as most people are.
#376 |
Alright so Ive got some good news and bad news.
The good news is that I got some parts in the mail: ![]() ![]() The other good news is I may be buying a house a bit sooner than expected, so ill have a better work area. The bad news is I may be buying a house a bit sooner than expected, so I need to be putting as much money as I can into things like a down payment and other necessities, which hinders this project quite a bit. Ill be continuing what I can with this though, we will see what happens. I'm still planning on setting up that test this weekend. |
| The Following User Says Thank You to rusty959 For This Useful Post: | neutron256 (09-20-2013) |
#377 |
Drives: GBS BRZ
This is an interesting topic. I'd like an electric supercharger for DE days, but the math doesn't work out for a lap-averaged energy draw (the alternator doesn't make enough power even if it operates at 100%). A really good alternator might be able to give 2 kW average power, so if you are on the throttle roughly 50% of each lap, then you have a max of 4 kW to drive a supercharger. So not very much.
With regard to the gears, keep in mind that some superchargers are gear-driven and they have a lot of gear whine. Then there are belt-driven units that can be unreliable because of the belts. ...and then there is Rotrex, with their cool non-newtonian fluid in a planetary traction drive. If you had the money to fabricate parts to direct drive a Rotrex, then your electric motor options would greatly increase because you could drive at 10-15 krpm and still have the compressor wheel turn 90 krpm. None of the other superchargers even come close to this speed, so it seems likely that a complex Rotrex-like traction drive is necessary to get such speedups on the drive. You might also want to look at sourcing the compressor wheel from a supercharger rather than from a turbo. Although in principle the wheels should be equivalent, it seems like the supercharger manufacturers get the maps that have the plateau a lower speeds. |
#378 | |
Drives: GBS BRZ
Yes, MOSFETs switch slower, but as of around 2005 it is not really an issue below say 10 kHz, and at low battery voltages they have much lower voltage drops than IGBT. This is why MOSFETs are still used in so many ESCs. Switching noise will most likely not be an issue, especially if you drive at 20 kHz, and there is no point in going to higher frequencies for this project. The bottom line is that you should let the design dictate the details. If you want to drive at 70 V, then maybe an IGBT looks pretty good, but if you are driving at 20-30V, you can use automotive grade MOSFETs and get higher efficiencies. |
| Tags |
| hairdyerperformance, only pulls hard one gear |
| Full throttle Electric Supercharger Build Thread | fenton | Forced Induction | 11315 | 04-07-2025 07:42 PM |
| DUP THREAD MODZ PLZ DELETE KTHX | SloS14 | Forced Induction | 0 | 07-09-2013 06:41 PM |
| Electric Turbocharger | Shankenstein | Forced Induction | 91 | 06-24-2013 03:47 PM |
| Electric 86 | frosty86 | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 11-10-2012 03:16 PM |
| WRX Electric turbo | Neilus | Engine, Exhaust, Transmission | 42 | 05-03-2012 10:20 PM |
