#365 |
Drives: '22 BRZ
Got up to two things today! Received my new wheels, 17x9 ET45 Enkei TS-V in Storm Gray. I'm really excited to see them on the car properly especially with my incoming coilovers from Shaftworks USA!
![]() ![]() ![]() I also installed extended front studs, linking that post and info here: https://www.ft86club.com/forums/show...&postcount=264
| The Following 4 Users Say Thank You to DocWalt For This Useful Post: |
#366 | |
Drives: 2022 BRZ WRB
#367 |
Installed my front license plate today using the JDM to US adapter from Amazon.
#368 |
Drives: 2022 Subaru BRZ 6MT IR
Same here - cheap at Canadian Tire, and last for quite a few uses.
Don't go for any other densities other than standard though. I tried some denser hockey pucks and they were too brittle, especially at -20C.
2022 BRZed, Red, Base, Manual, Simple
| The Following User Says Thank You to 22 BRZ For This Useful Post: | Midnightsky (01-16-2022) |
#369 |
Drives: 88 RX-7, 2022 BRZ
Late post-breakin oil change @ 1683 miles
![]() Second-guessed myself a few times reading the classic subaru dipstick, but 5 quarts ~6 ounces seems to do it when using an extractor and changing the filter. Please ignore the xpel tracwrap as I'm waiting for PPF. |
#370 | |
Hope you changed the oil filter too as any metal shavings from new will be caught by it. What oil brand did you use? Sent from my SM-G781B using Tapatalk |
#371 |
Drives: 22 BRZ
It'd be nice to see if someone could come up with a set of jacking rails this car (and any car, really). Really popular mod on S550 Mustangs. It's a reinforced bar that bolts under the car just inside of the pinch weld - allows you to place the jack anywhere you'd like on the side of the car, including the center, and raise it without damaging any pinch welds. Was really nice to jack from the center, lift the whole side of the car evenly, then place both the front and rear stands at once. Saved me some time swapping wheels at the track or autox.
https://www.steeda.com/steeda-s550-m...-555-5205.html |
| The Following User Says Thank You to otter For This Useful Post: | Midnightsky (01-17-2022) |
#372 | |
Unless you need the whole car in the air for some underbody work it's much faster that way. That's how I do my brake pad changes for the track. |
| The Following User Says Thank You to jvincent For This Useful Post: | Ohio Enthusiast (01-17-2022) |
#373 | |
Drives: 22 BRZ
#374 |
You'll need a low profile jack for the front/rear points but other than that they're super convenient.
| The Following User Says Thank You to jvincent For This Useful Post: | Midnightsky (01-17-2022) |
#375 |
Drives: 2022 BRZ
#376 | |
TRACKBREAD
What did you use to get 5V from the headliner wiring? |
#377 |
Drives: 2022 BRZ
I didn't. Power is routed from the glove box, up the side pillar, through the headliner, and routed through the same cable guide for the home-link mirror.
I have a power kit to wire in both constant power/ignition switch for parking mode which I'll get around to at some point. |
| The Following 2 Users Say Thank You to cpierr03 For This Useful Post: | Midnightsky (01-18-2022), Yoshoobaroo (01-18-2022) |
#378 | |
| WHAT DID YOU DO TO YOUR FRS TODAY? | KalbiCool88 | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 11-04-2015 11:36 PM |
| Do you know what today is? | Yruyur | Off-Topic Lounge [WARNING: NO POLITICS] | 26 | 01-21-2015 03:51 PM |
| just got my OFT today...help please! | carlitosway6891 | Software Tuning | 9 | 02-20-2014 11:05 PM |
| TODAY, TODAY, I GET IT TODAY!!!! :D | Trashed675 | Scion FR-S / Toyota 86 GT86 General Forum | 54 | 02-14-2013 02:16 AM |
| sat in a BRZ today | NESW20 | BRZ First-Gen (2012+) — General Topics | 8 | 03-31-2012 09:53 AM |
