Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 02-15-2022, 04:14 PM   #365
slipstream8
slipstream8's Avatar
Drives: On order: 2022 ISM BRZ Ltd
Originally Posted by razgriz12345 View Post
hmmmm that's interesting was that for the all around or just front or rear? I got my combo from fitment industries I haven't bought them yet but they said it was within safe margins. What was the reasoning the salesperson gave for the +45mm? Would a 10mm hub centric spacer work on it? would changing it to 40r change that? im not questioning the sales person just trying to understand as i dont know much about wheel fitment.
See my photos of 17x9 ET35. 18x8.5 ET35 is only going to be 0.5" less poke. For me that is still too much at stock ride height. ET45 gets you an additional 10mm (0.39") less poke.
https://www.ft86club.com/forums/show...&postcount=349
slipstream8 is offline   Reply With Quote
The Following User Says Thank You to slipstream8 For This Useful Post:
razgriz12345 (02-15-2022)
Old 02-15-2022, 05:39 PM   #366
razgriz12345
Drives: 2022 brz limited (WR Blue)
Is there any chance you could a ruler on how much it pokes I just want to have accurate measurements to base a comparison on visually. I feel like that .5" less poke might be enough for me to see it as acceptable but I'm not sure. I was planning on going to les Schwab's later and seeing if they would be willing to fit a tire on a similar rim if they have one but I really like the set of rims I'm looking at but if it does poke to much it might be a deal breaker.
razgriz12345 is offline   Reply With Quote
Old 02-15-2022, 06:04 PM   #367
slipstream8
I don't have the wheels on the car anymore. From memory, I think the poke in the rear was a little more than a half inch from the outside of the fender. The brand of tires you choose will make a difference, too.
Old 02-15-2022, 06:04 PM   #368
86league
Drives: '13 BRZ Limited
II feel like that .5" less poke might be enough for me to see it as acceptable but I'm not sure.
8.5" vs 9" wheel at the same ET isn't going to give you 0.5" less poke - it will be 0.25" less poke and 0.25" more inner clearance.
My ARC-8 17x9 ET42 wheels with 245 SX2s on a friends 2022 poked on the rear and looked like it would have rubbed. Fronts looked fine. My wheel spec will be very close vs an 8.5" ET35 for fender clearance.
86league is offline   Reply With Quote
The Following User Says Thank You to 86league For This Useful Post:
Old 02-15-2022, 06:30 PM   #369
razgriz12345
oh I didn't realize that. I guess I will go back on the hunt for a different set of wheels then
I think that's a little to far on the back then thanks for the help
Old 02-16-2022, 01:26 AM   #370
86man
Drives: GR86
Guys, it's not the wheel/rim that's rubbing the rear fender, it's the tyres
Go with 235 or narrower if you don't want to cut up anything or run massive camber.
For clearance in the rear, as long as the offset is 45 or greater, wheel width (9.5, 9 or 8.5) is irrelevant as long as tyre is under 245.
86man is offline   Reply With Quote
The Following 2 Users Say Thank You to 86man For This Useful Post:
Frost (02-16-2022), timurrrr (02-16-2022)
Old 02-16-2022, 04:46 AM   #371
PMok
Codename: Stitch
PMok's Avatar
Alrighty folks. Time for some photos of bad fitment for the sake of education (and I thought it was worth seeing how this style of wheel looked on the new generation BRZ.)
These are Wedssport TC105N 17x9 ET35 with Yokohama AD08R 245/40R17 at stock ride height. It seems like there wouldn't be any rubbing at maximum compression, but the poke looks terrible.
The last photo is the clearance for the front shock.
Aww man this is disappointing to see... I have the exact same wheels on my gen 1 BRZ, and was hoping they could carry over to the new '22+ model when I got one.
Old 02-16-2022, 01:23 PM   #372
slipstream8
Yeah, it's a bummer. They are great wheels!
Old 02-17-2022, 08:50 AM   #373
TDCFPC
Drives: 2019 C7 GrandSport
Thanks for the pics and specs.
Your pics are with factory camber, correct?
For a track setup and -2.5 or -3.0 camber should make the top flush with the lip. Do you see any issues with potential rubbing on suspension components in your opinion?
TDCFPC is offline   Reply With Quote
Old 02-17-2022, 11:28 AM   #374
slipstream8
Correct--factory camber. I just put them on to see what the wheel design would look like on the second generation car, knowing from what others had posted that the offset would not be great.
-3.0 camber would put the wheel 0.445" closer to that shock perch in front, if I have the math right [tan(3°)=x/8.5"]. I measured the clearance there at roughly 0.6" with the factory camber.
Even with camber and a drop, I suspect the biggest potential problem area is still that bump inside the rear fender.
Old 02-18-2022, 12:06 AM   #375
gcmak
gcmak's Avatar
Drives: GR86
Would probably use a camber plate instead of camber bolts. Or a combo of both. Camber plate would keep the current distance between the wheel and the perch the same.
gcmak is offline   Reply With Quote
Old 02-19-2022, 09:33 PM   #376
trippinbillies40
trippinbillies40's Avatar
Drives: '22 WRB
Right, but some people wanting to compete will want as much rubber as possible.
trippinbillies40 is offline   Reply With Quote
Old 02-19-2022, 10:28 PM   #377
Scubadriver
Drives: 2022 BRZ Limited
I am very happy with the 17x9 ET48 in the rear. 245 is fine with stock camber. 255.almost fits. Front requires a spacer, but I decided that was inevitable.
I just put a writeup of a bunch of fitment testing of the 17x9 ET48 6ULs in another thread.
Scubadriver is offline   Reply With Quote
The Following 2 Users Say Thank You to Scubadriver For This Useful Post:
PNW Shaggy (02-24-2022), Xed32 (02-20-2022)
Old 02-20-2022, 07:33 PM   #378
dsc_pat
Drives: Too fast
dsc_pat is offline   Reply With Quote
The Following 2 Users Say Thank You to dsc_pat For This Useful Post:
jongers (02-21-2022), timurrrr (02-21-2022)
Rear wheel alignment issues... HELP! Rambo305kid Issues | Warranty | Recalls / TSB 10 07-05-2020 11:05 PM
Wheel Fitment Issues. Need help. hay_frs Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 04-06-2020 07:09 PM
Fitment issues Neal86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 05-07-2019 08:08 PM
Tire/Wheel fitment (rear) rikixass Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 01-17-2018 05:09 PM
Fitment Issues Silp3 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 01-02-2013 04:34 PM
