#365 | |
Drives: 2017 BRZ PP (White)
Super late, but did you need spacers for the back wheels as well? Would you recommend a 5mm spacer? or 3mm clears them just fine? thanks! |
#366 |
Drives: 17 BRZ
Enkei RPF1 18x9.5 et38 fit with AP racing brakes
(does this mean it clears brembos also?) ![]()
#367 |
Drives: None
No
#368 |
Drives: 17 BRZ
#369 |
Drives: 2018 BRZ
Does anyone know if Enkei RPF1 in 17x7.5 ET48 fit? The list doesn't include them in 7.5 width.
#370 | |
Drives: 2017 BRZ PP, 2004 WRX
Go with the 8" width if it's a street car and you're not trying to stick to some rule set like for autocross. I know in street class RPF1's are what a lot of people run due to the weight and going up to an 8" wheel isn't an option.
#371 |
Drives: 2014 Subaru BRZ (Limited)
Does anyone know if the STI 17”x7” wheels will clear the PP Brembo kit with a spacer? If so, what’s the minimum size spacer I would need?
TIA |
#372 |
Drives: GR86 Trueno Edition
Are the 2018 Brz tS brembos same as the 2024 GR86 trueno?
I assume that the 18” Sti on the 2018 tS will fit nicely the 2024 gr86 but who know if they changes anything. Sent from my iPhone using Tapatalk |
#373 | |
Guilt free parts vulture!
Drives: 2024 GR86 Trueno Halo 6MT
The 2024 tS are identical to the trueno except color; not sure about the 2018
#374 |
Drives: None
#375 |
Drives: 2020 BRZ Sport Tech RS
Another one to add:
Konig F3S forged 17x9" ET42 will clear the Brembo's according to Konig customer service (I inquired by email).
#376 |
Drives: Scion FR-S 10 Series
Adding the to the knowledge base, I learned the hard way that Enkei RPF1 18x9.5 +38 DO NOT fit.
![]() Even though many other versions of the RPF1 do fit, this particular variant has extra concavity to the spokes. And while this does look great, it causes the spoke to interfere with the inside edge of the caliper. I did eperiment with spacers, here is a pic with a 5mm spacer... ![]() with the 5mm spacer, it is still just barely touching. You could maybe get away with a 7mm spacer, but I feel 8mm minimum is necessary. The problem is with 8mm, the effective offset is +30, so you get a lot of poke and you would have to add a good amount of camber. I ended up getting a new set of wheels. Will make a separate reply. |
#377 |
After finding my RPF1's not to fit, I replaced them with a set of Work VS-XX
Fronts are 18x8.5 +32 [A-Disk] Rears are 18x9.5 +39 [O-Disk] The rears fit no problem, but the fronts require a 6mm spacer for proper clearance. This actually works out nicely as it brings out the wheel so the outer fitment matches the rear. ![]()
#378 |
Drives: 2018 BRZ 6MT
TE37SL 18x9.5+45 fits with 3mm spacer.
Does NOT fit without spacer. |
| Tags |
| brz, performance package, wheels |
| Finding wheels to clear brembos | jojosbrz | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 21 | 11-13-2018 08:46 AM |
| Performance package Brembos | Ernest72 | Want-To-Buy Requests | 2 | 07-14-2018 08:06 AM |
| Performance Package Brembos Freezing to Wheels? | texastwurkt3am | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 12 | 02-23-2018 08:31 AM |
| What pads fit the Performance Package Brembos? | mistople | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 11 | 01-03-2018 05:15 PM |
